Question about Refrigerators
Sears june 93 fridge stopped dead 20+ hrs now running why
  • Refrigerators Master
  • 744 Answers
Hello Suanne;
My name is Peter. I am a retired field service refrigeration technician.
When you plug in a new refrigerator it takes the refrigerant 24 hours to equalize, create a high pressure 160 PSI liquid side and a low pressure 60 PSI vapor side.
I have never experienced this before. I think you are very lucky. I suspect you may have had a restriction in your refrigerant system and it cleared itself.
Or, your defrost timer may have gotten stuck and freed it self after repeated attempts to start and stop.
Look in your freezers upper right hand corner. Is there ice or heavy frost buildup? This is where most restrictions occur.
Posted on Nov 09, 2014
Compressor running continuously. Hearing surging sound. Both fridge & freezer not cooling.
there may be a blockage in the evaporator tube in the fridge sections and the only way to establish what the fault is will be to have fridge technician run test on it
Jul 25, 2015 | Fisher and Paykel Active Smart E522B...
My refrigerator has a red light on indicating. Cooling off has been on for 8 hrs
could mean the compressor and or evap fans have stopped running..... try unplugging for 20 - 30 seconds, plug back up and see if unit restarts..... if its still dead ... and your sure u have power to unit, I would go to the main control board and start checking power................. good luck and I hope this helped.......... ken
Sep 30, 2014 | Refrigerators
Fridge freezer stoping after 24 hrs
most of these freezers have an automatic defrost cycle.
after so many hours of chilling it will stop and run a de-icing cycle.
this is accomplished by one or two heating elements.
if one of the elements is burned out it will not run the defrost cycle.
and will ice up quickly.
depending on the model the heaters will usually cost about 15 to 20 dollars and they are easy to replace.
look up the model of your freezer and download the pdf files they will usually have a pictorial diagram showing the location
a defrost timer usually does nt fail on them unless it is physically damaged.
Aug 31, 2013 | Freezers
Im getting a blinking 93 and my water wont clear up.
93 is stand by mode indication of the cycle completed.. You may need to increase the cycle time.. The manual is very conservative!!! I have a 14000 gallon pool and I run my intex salt system during the summer at 10 to 12 hrs pump and 8 to 10 hrs chlorination in between those 12 hrs and my pool stays very clear. But..... If you don't clean the unit and let it alarm for low flow, low salt or not run the unit log enough, you WILL HAVE GREEN WATER!!!
Hope this helps, If it does, please rate the tip!
I
Jul 24, 2011 | Intex Saltwater Chlorine Generator 2000...
I have the Haurex Italy Promise Women's Crystal Watch. I bought it in June of this year. The watch stopped running today. This may not be relevant but I do not wear a watch very often, keeping it more...
It is unusual for a quartz watch to stop so soon (presumably the battery is now dead?).
I suggest you contact the makers local customer care center and discuss it with them.
You can find their local service center by going to http://www.haurex.com/collezione.asp?id=93 and clicking on "after sales service". If you have any proof of purchase date, then it should be still under warranty if it needs repair.
Dec 16, 2010 | Haurex Watches
The original motor in my 93 grand cherokee 5.2L seized in June. I bought a good junk yard 5.2L motor from a 98 Grand Cherokee and swapped over the 93 intake and all related electronics. The engine is back...
are you sure those intakes are inter changeable?
if you still have the 98 intake and your 93 block ,sit there and look for any differences in holes or hole locations.
another way to check is when it is running remove the oil fill cap and see if it stalls or picks up speed.
Nov 21, 2009 | 1993 Jeep Grand Cherokee
GE Arctica intermittant clicking sound, panel flashes "hrs"
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
