Question about Toshiba RDXV59DTKB Rd Xv59dtKB Dvd Recorder / Hard Drive Recorder
My rdxv59dtkb switches off after about 5 minutes. All the coloured lights flash as it's doing this. Help
After it's been on for about 5 minutes the signal to the tv goes off and all the lights for the dvd,vcr and hdd flash repeatedly until the machine goes to standby.
  • 8 Answers
Could be a humidity or moisture problem
Posted on Feb 23, 2015
2004 Alero wont start!
sound like theft security problem.when you try ten minutes did you leave ignition switch on position for ten minutes until the security light turn off then turn off ignition switch for 5 seconds then try starting vechicle.when you do 10 minute trick security light has to turn off or disappear when you see security light go off turn off switch 5 seconds then try starting vechicle.
May 22, 2013 | 2004 Oldsmobile Alero
Kenmore ultra wash 6651393 control lock light flashing
I would try turning the breaker off for 5 minutes to see if it will reset.
Jun 09, 2012 | Kenmore 15899 Built-in Dishwasher
My commercial cool air conditioner goes off after 5 min. The stop light is flashing? I can't get it to go on?
It's going thru the defrost cycle. Once that ends, the unit should restart. If it doesn't wait until 3 minutes have elapsed, after the stop light goes out and restart the unit. If that fails, turn the Master ON/OFF Switch to OFF & unplug the unit. Wait 15 minutes, plug the unit back in and turn the Master ON/OFF Switch to ON. The unit should have reverted back to the original factory settings. If so, reset the controls as you like.
I hope this helped you and thanks for choosing FixYa.
Jul 24, 2011 | Haier CPN14XC9 Air Conditioner
Shows different color complete blue or red scrren at connection
shake vga cable at different places & observe.........if colours becomes normal or it comes & again it goes...then vga cable is deffective.......either you have to change full vga cable or you have to repair that cable itself................after shaking cable also if no improvement then......hit your monitor lightly on left side or righr side or on top & observe ...........if colours becomes normal or it comes & again it goes...then following is the situation...............after 4 or 5 yrs in some monitors on main board at some soldering joints crack develops....then due to loose contact colour problem comes (1 of the sympton) ...........when we hit that lightly then those loose contacts joins temporarly & again colour comes nomally for some time............so solution is ......monitor main board & crt circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no improvement then..following is the situation.....................on CRT circuit board ( circuit board that is fixed to tube) ''red green blue'' - video output IC ( some thing like LM2469TA ) will be there - it should be replaced - usually it will be fixed to heat sink ------- before changing IC all the components on CRT circuit board should be checked ( after switching off monitor ).........this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )
Apr 11, 2011 | SAMTRON 55V 15" CRT Monitor
I am working on a 1999 olds alero that wont start just rolls over . The security light is not flashing. I have changed out the ign, & the crank sensor. I started once then i stut it off & tryed it...
IF YOU REPLACE CRANKSHAFT SENSOR IT HAS TO HAS TO BE RELEARNED USING TECH 2 SCANNER.FOR THE IGNITION KEY REPLACEMENT.TURN IGNITION SWITCH TO THE ON POSITION FOR 10 MINUTES WITH ENGINE OFF.WHEN SECURITY LIGHT TURNS ITSELF OFF.THEN YOU TURN OFF IGNITION SWITCH FOR 5 SECONDS.THEN START THE ENGINE.
Jan 20, 2011 | 1999 Oldsmobile Alero
Frigidaire FES367FCC. Oven is flashing F90.
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 11, 2010 | Frigidaire FES367 Electric Kitchen Range
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
RED LIGHT FLASHING after local power cut in East London
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Aug 27, 2009 | Epson Perfection 4990 Flatbed Scanner
Self-cleaning error message f90
unplug the range.
wait 1 minute.
wait 2 minutes.
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Toshiba RDXV59DTKB Rd Xv59dtKB Dvd Recorder / Hard Drive Recorder Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
