Question about Dryers
I HAVE A HAMPTON BAY 526 012 60 IN INDUSTRIAL FAN. IT CAME WITH A 4 SPEED SWITCH. THE SPEEDS ARE TOO FAST. I WOULD LIKE A VARIABLE SWITCH TO OPERATE IT LIKE A KNOB STYLE. WILL THE FAN OPERATE PROPERLY AND NOT BE DAMAGED IF I CHANGE TO A KNOB STYLE
    Top Expert:
  • Dryers Master
  • 3,698 Answers
No. That type of a/c electric motor has nt start windings and ned the extra current to start it. The varable speed device would work after starting it on full power but you woudl hav eto remember to do this each and every time, that you started it, or run the risk of burning up the motor. In addition , the air flow may not be enough to keep the motor cool enough, at lower speeds.
Posted on Nov 17, 2014
SOURCE: 3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Du-uh!
Posted on Jul 24, 2008
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
  • 37 Answers
SOURCE: Bay Model # 526-012 Fans what size speed control
I can't see any reason why a Leviton fan speed control couldn't be used on any ceiling fan, after all, I don't even think Leviton makes ceiling fans. Second, you may be able to try using the 1.5 amp fan speed control and see if you can get by. The worst that could happen is the speed control wouldn't work or would only work for a short time and be junk.
Posted on Jan 24, 2009
  • 52 Answers
SOURCE: No middle speed.
Replacing the pull switch (reostat) should have solved your problem. Try going to the internet at www.google.com and in the Google search box enter "Hampton Bay Fans homepage". If any of these suggestions have been helpfull, please rate my solution. Thanks D. Lange
Posted on Apr 24, 2009
  • 163 Answers
SOURCE: Hampton bay fan only is working at one speed,
if its a hamptom bay fam get all numbers off the top of the fan and call home depo main office all hapton bam fann have a life time warrenty #is 1 800 654 0688falow all promps
Posted on Jul 26, 2009
Had to disassemble a Hampton Bay ceiling fan to install a new light pull switch. Hung from a paperclip while fixing but it dropped and disconnected a number of wires. Rewired by my best guesses and now fan...
If you bought the switch from Lowes, most likely it's the wrong switch. Even if it looks the same on the outside, it could be different on the inside. As for the other wire, push it into the empty slot of the switch & see what happens. There has to be 4 wires in the switch. Black usually goes to L
Jan 04, 2015 | Hampton Bay Dryers
Fan not moving fast
mcdevito75 here, The small pull chain you use to turn the fan on is also the fan speed switch, simply pull that cahin 1 more time and then 1 more time after that for various fan speeds.
Jul 25, 2010 | Hampton Bay 24002 Ceiling Fan
I have a hampton bay ceiling fan which will only run on the fast speed. I have changed switches but still only the fast speed. I have touched each wire to the load wire to see if it was the swith but no...
Hello Brother,
Installation:
Hang your ceiling fan on the Quick Connect fan bracket and wire the ceiling fan according to the manufacturer's instructions. The three wires coming from your ceiling should match the three wires coming from your ceiling fan: black (positive or hot), white (neutral or negative) and green (ground wire).
Use the high, medium and low keys on the remote to adjust the Hampton Bay fan speed, then use the light key to dim the light and the off key to turn off the fan.
For REMOTE CONTROL FANS you cannot use with any variable speed or slide wall switches. The remote control function must be used with on & off switch outlets only.
Speed Controls Click here Capacitors Link
I hope This Helped you,Thanks for Contacting FixYa...
Apr 22, 2010 | Hampton Bay Heating & Cooling
Hampton bay fan, wall mount remote control
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
No middle speed.
Jul 31, 2008 | Hampton Bay Sidewinder 04890 Ceiling Fan
were crossed.
Du-uh!
Jul 23, 2008 | Hunter 23852 Classic Original Ceiling Fan
Fan speed too fast
Is there a light switch control or just straight power to the fan? They do sell "Fan" controll switches just like a regular dimmer, but for a fan. If there is just straight power u would still be able to install a remote that could lessen the speed. Even if it is just pull chains. the remote would have three speeds and if u kept the pull chain on low, maybe the low remote speed could work.
May 22, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Wiring a Hampton Bay ceiling fan
Hi Rexter,
I would pull the cover off of the Light switch and look at the color of the wire leaving the Variable speed device. I only assume the red wire is from that. I do not like to assume anything. So you must verify that a red wire leaves the Variable speed device. If it does, then i am assuming you dim the lights with this Variable device. The fan has its own built in Variable speed setup. In the case that the red wire belongs to the variable device, wire the Red to Blue(light), and Black to Black Whites to white. Green to Ground. bare wires to ground.
Nov 30, 2007 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
87 people viewed this question
Top Dryers Experts
