Question about Clarion NX501
Undefinedthe unit works fine but the screen has gon darker hard to see in the day lite
My son's DS Lite stopped working last night. The unit was working fine and the battery light turned red so he put it on to charge. After about an hour the light was green so he tried to start the console...
It sounds like the battery is dead. You can order a replacement battery direct from Nintendo at http://store.nintendo.com/webapp/wcs/stores/servlet/ProductDisplay?productId=108205
Jan 27, 2014 | Nintendo DS Lite Console
Dark line down the middle of my flat screen tv
Most LCD and PLASMA sets use two boards (some combine them into one board) that drive the Display Panel (the entire front screen unit) so I would suspect one of yours is bad.
The other unpleasant possible cause is where the left board is connected to the Display Panel (entire front screen unit) you have a problem inside that Display Panel and that is fatal as there is no way to get INSIDE the panel---it can cause both lines and a dark picture on one side of the screen.
May 25, 2012 | Sylvania Televison & Video
How to download daemon tools
Below are two links for downloading Daemon tools for free.
http://daemon-tools.en.softonic.com/
http://download.cnet.com/DAEMON-Tools-Lite/3000-2646_4-10778842.html
Thanks for using Fixya.Have a good day.
Apr 01, 2012 | HP Computers & Internet
When I turn my Nintendo DS Lite on, the touch screen works fine but the top screen just goes plain white. I've tried turning it on and off but that didn't work. The screen is just white and that...
sounds like It is broken.
unless you get the startup screen beefore it goes out white i'd say something was damaged in the screen or the wiring connecting the screen to the unit.
If you see any lines on it, It was most likely over extended open and the wires inside have become frayed or damaged. If you try fully opening the top screen and push inward you may have temporary relief of this issue. could try puling out also but either way this would just be to test if thats the issue. dont pull or puch to hard as you could damage the unit further.
if it is a pure white screen the screen may have cracked or had something spilled on it which would damage the screen beyond use.
Either way, the system is damaged and needs to be replaced or repaired. Price wise it is more advisable to just buy a new unit rather then purchase parts and repair it.
Jul 02, 2011 | Nintendo DS Lite Console
Screen is too dark, barely can see the print. Is there an adjustment to use? was working fine a few days ago, then, has been getting darker.
Most computers have a key combination to increase brightness. This is usually Fn+UP for brighter on Fn+DOWN for darker. If this is not the correct key combo, look for keys that have symbols looking like the sun or a light, those keys combined with Fn will change the screen brightness. This can also be changed in Windows, if that is the OS you are using. Go to Start->Control Panel->Power Options and an opiton for screen brightness will be there. Also, right clicking the battery/power cord icon in the system tray can get you to the power options.
May 08, 2011 | Acer Aspire 5630-6288 Notebook
A black air like bubble on the center of my DS screen.
its due to stabbing the screen or pressing it with your fingers too hard.
Jul 08, 2009 | Nintendo DS Lite Console
Screen gets darker as viewing. after an hour you can hardly see
poss heater circuit for crts. ck for orange glow neck of crts. loose plug ? bad solder?
Dec 13, 2008 | RCA D52130 52" Rear Projection Television
Screens going dark
Wow you have a serious problem. Your LCD screen is losing power probably from a leak or bad wires or connections. If you stil have your warrenty, I would try to take it back.
Oct 16, 2008 | Nintendo DS Console
Picture gets darker
Apparently there is a loose connection somewhere. Please have unit checked out by a pro tech
Aug 01, 2008 | Sony KP-51HW40 51" Rear Projection...
Clarion NX501 Logo
63 people viewed this question
Top Clarion Audio Players & Recorders Experts
John
John
xxxxxx xxx
Anthony Kelly
Anthony Kelly
Are you a Clarion Audio Player and Recorder Expert? Answer questions, earn points and help others
