Question about Samsung 1.8 Cu. Ft. Over-the-Range Microwave
Samsung microwave model smh8187stg will run whenever it is plugged in with door closed. Yes, it actually heats up without any button being pressed. Have replaced the assembly control panel but this
Had a service tech come in and this was the part he suggested, DE94-01614C, I purchased the part and installed it being that it was 6 connecting wires and 3 screws. The part has not corrected the problem.
  • 150 Answers
Well the relay to energise the magentron is stuck on closed. You have main board problem. First check that board, the microcontroller is responsible for the relay via a switching transistor of FET. You have a shorted FET/TRN as well. Can't believe the tech did not check that. Thanks
Posted on Nov 08, 2014
MicrowaveSvc
  • 9047 Answers
SOURCE: Samsung Microwave model # SMH7178STD just stopped working.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find Samsung-specific parts here: http://www.samsungparts.com/search/search.asp
Posted on Nov 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave samsung suddenly stoped working
UPDATE
The -SE-error is a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 21, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Door handle broke off
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can get Samsung parts here.
Posted on Jul 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Samsung MW1080STA Microwave Oven
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You can order Samsung parts here.
You can find your nearest Samsung-authorized service center here.
To find out if yours was recalled, please call Samsung's Service Division at 800-932-3837.
Posted on Nov 21, 2008
reyjoshua07
  • 1157 Answers
SOURCE: SAMSUNG MICROWAVE, MODEL SMH9187ST, WHEN NOT
Hi dschema,
You have a door switch issue. There are three behind the panel. If you can lift and hold the door and it starts one of them is bad for sure. You would be better off replacing all three or have a repair man replace them because a microwave can hold 3000v even unplugged.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 20, 2011
Why does my samsung MW725WB starts up on its own
Try putting a cup of water in the microwave to see if it is really heating, or if it is just making noise. If it is really heating on it's own whenever the door is closed, then you have a stuck relay on the control board, and you probably have to replace the control board. If it's just "making noise" (running but not heating), then it is probably a bad door switch.
Sep 08, 2014 | Samsung Microwave Ovens
Smh8187stg model
from the service centre -
Jan 01, 2014 | Samsung Microwave Ovens
Ge microwave fan runs when door is closed and light still on
There are one or two door switches that are probably defective, that must be replaced.
May 08, 2012 | GE Microwave Ovens
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwwave is not heating,
Hello
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol (like the "Start" button in the photograph).
Oct 05, 2011 | Sanyo Microwave Microwave Oven
My Maytag Microwave, Model MMV 4205 BAS has an issue. As soon as you close the door, there is a humming sound. This is without pressing [Start] or entering any time. I have tried pressing the [Stop/Clear]...
did it come into contact with water at anytime, if yes than this is probably the reason ask an electrician to come and have a check or if it is working fine you can continue using but make sure that no liquid will spill over inside
May 12, 2011 | Maytag MMV4205 Microwave Oven
MW8119SB cooks when door is closed regardless of settings
Clear the cook cycle when you remove the food. Some microwaves pick up where they left off, so you don't have to keep pressing buttons.
Aug 07, 2009 | Emerson MW8778 Microwave Oven
Keypad Problems
Sometimes a keypad may not work because the door switches are faulty. When the door switches are working correctly it will allow the keypad to operate. They tell the microwave that the door is closed and the unit is dafe to use.
Many models have 3 door switches, it's wise to get all 3 replaced at once.
Mar 27, 2009 | Samsung Microwave Ovens
WST3501 Problem
We have had problems like this before. Most likely the smartboard is defective.Check with manufacture to see if there is a recall.You should be able to find them on the web.
Nov 02, 2007 | Microwave Ovens
WST3501 Problem
I would like to know if you still have the instruction book for your WST3501? And if so is there anyway you could email me a copy of them I have lost mine. Please and Thank you mndutch@yahoo.com
Oct 15, 2006 | Westinghouse WST3501 Microwave Oven
Samsung 1.8 Cu. Ft. Over-the-Range Microwave Logo
94 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
