Question about Sharp Atomic Dual Alarm Clock Spc315 PP3074
How do I set my sharp atomic clock. Put in new batteries and set time and date on back of clock but the outside temp is not registering?
I put in new batteries. Hit reset button and set time and date after selecting time zone ea. The outside temp is not showing. There are new batteries in that also
  • Sharp Master
  • 3,382 Answers
That makes scence, you have to have an outside temperature probe. If it is wireless it also needs batteries. Check manual for more details.
Posted on Dec 08, 2014
How do I reset time and date on SioScan Atomic Clock? I need Arizona time zone - i.e. no daylight savings time
Put it into settings and then adjust time/date. It's not related in any way to temperature.
Apr 24, 2015 | Home
Even with brand new batteries inserted into the Reciever, I still can't get an outdoor temperature. Why ?
Make sure they are both set to the same channel (normally channel 1) put them next to each other then press reset on the temperature unit only.
www.serendipity-gifts.co.uk
Jun 19, 2012 | La Crosse Radio Controlled Atomic Clock
No visible outside temp. on SkyScan
Read some other posts on the net and they said to put in new batteries.........bingo!  That did it!
Aug 23, 2009 | SkyScan 86709 Atomic Wall Clock
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
Remote that gives outside temp does not work put in new batteries, still does not work!
Pull the batteries out of the clock, wait a minute, and then put them back in. That will reset the link between the two. The temperature should be OK in just a few minutes. The clock will read the wrong time and date until it resets during the night. The next day, all will be well.
Apr 20, 2009 | La Crosse Radio Controlled Atomic Clock
Outside temp on skycam atomic clock
Try changing the battereis in the CLOCK. When the batteries in the clock start getting low, the clock does not pick up the outside transmitter.
Nov 10, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Instructions for setting Sharp Atomic clock
Remove backup battaries
and re insert new/or-goodbattaries in the battarey comportmane as correct +/- sign.
show the time if its start from 12:00AM
press startbutton -get time adjust mode -select correct Time and press set to mnormal mode.
Nov 03, 2008 | SkyScan 86709 Atomic Wall Clock
Changed batteries
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Sep 07, 2008 | SkyScan 86709 Atomic Wall Clock
Sharp Atomic Clock Daylight Savings
I have misplaced the manual for my sharp Atomic clock, need to reset the time zone and shut off the alarm. How can I obtain a new manual?
Mar 10, 2008 | Baby Gear
Resetting the atomic clock to the correct time zone, and outside temp to work.
For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
Good luck,
Doc
Dec 01, 2007 | Baby Gear
Sharp Atomic Dual Alarm Clock Spc315 PP3074 Logo
653 people viewed this question
Top Sharp Kitchen Ranges Experts
William Miller
William Miller
Richard Lane
Gil Shultz
Are you a Sharp Kitchen Range Expert? Answer questions, earn points and help others
