Question about Coby TFTV3227 32 in. LCD TV
How do I turn of stereo sound
How do I get the mono off and turn it to the stereo option I cannot highlight that option in the menu
Stuck in Mono
try and press the mono again it might go to stereo
Apr 17, 2014 | Philips MX5100VR System
Sound very poor
there could be a few issues. It could be the speakers themselves. I believe this tv has an audio out. I would hook it up to a stereo and see if it that improves it. It could also be something internal like the amplifier. You have a couple options but I would just use a stereo for sound. If you still need more assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
Oct 18, 2008 | Philips 42MF130A 42 in. Plasma EDTV
I have a L46FHD37 lcd tv how can i reset it
The Sound menu lets you adjust audio output. To access the Sound menu, press MENU on the remote, and then select Sound from the Main Menu. The following audio items can be adjusted:
Equalizer The five-band graphic equalizer lets you adjust the audio frequency settings. You can select one of the five-band Equalizer Presets or create your own personal preset.
Sound Preset Allows you to choose a specific Sound Preset. Press the right arrow to cycle through the options: Standard, Movie, Voice, Music and Personal.
Frequency Range Displays the different graphic equalizer bands set for each Sound Preset option. Choose a band and make adjustments. When you make adjustments, the Sound Preset option automatically changes to Personal. Press the left or right arrow button to select the frequency (100Hz, 300Hz, 1KHz, 3KHz, 10KHz) you want to adjust. Then use the up or down arrow button to adjust the level. When you're done adjusting the levels, press the MENU button to exit.
To view the frequency range of another Sound Preset option, press the right or left arrow until no band is selected and Frequency Range is highlighted. Then press the up arrow to highlight Sound Preset.
Sound Type Controls the way the sound comes through your speakers. The options available vary according to the input selected.
Mono (available for regular TV viewing only) Plays the sound in mono only. Use this setting when receiving broadcasts with weak stereo signals.
Stereo Splits the incoming stereo audio signal into left and right channels. Most TV programs and recorded materials have stereo audio. The word Stereo appears in the channel banner when you tune to a program that is broadcast in stereo.
Sound Mode Provides special processing through your speakers (depending on the setting you chose as your Sound Type). The available sound modes are:
Off Does not give any special sound processing.
SRS WOW Gives a surround effect with more bass. (available for models L42FHD37, L46FHD37, and L46FHD35) SRS TurSurround XT (available for models L42FHD38, L46FHD38, L52FHD38, and
L40FHD380) Dynamic Bass Improves bass output. Displays a choice list of available settings you can adjust: Off and On.
Balance Press the right or left arrow buttons to adjust how much audio is sent to the left and right speakers.
Auto Volume Level Reduces the annoying blasts in volume during commercial breaks, and also amplifies softer sounds in program material. Eliminates the need to constantly adjust the volume.
Internal Speakers Turn on or off the internal speakers. If you have a device connected to the AUDIO OUTPUT jacks on the back of the TV and you want to control the sound by the device instead, uncheck the box.
If you would like for me to send you the user manual, please send me an email to LBrown18062@hotmail.com. Put "RCA L46" as the subject and I will send it to you.
Mar 30, 2012 | RCA L46FHD2X48 46 in HDTV TV
I have no volume on certain channels
The most common problem with no volume only on certain channels is the TV is programmed for 2nd Audio, also referred to as SAP which is a feature activated to transmit a second language such as Spanish. If you push your menu button on your remote control you can toggle over to Audio Menu. Then find the feature that allows you to adjust the sound for Mono, Stereo or 2nd Audio (SAP). Adjust the menu to highlight Stereo and that should cure your problem.
Hope this helps with your particular problem.
Dec 05, 2010 | Philips Magnavox 42MF521D/37 Television
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
Audio only has mono how do you change it
If you open the menu,there should be an option for sound.If you have a universal remote,you will probably have to do it with the buttons on the TV.SAP and stereo are about the same.It most likely cycles through mono,stereo,SAP with the volume button.Good luck!
Aug 05, 2010 | Sharp Televison & Video
I cant get my tv 2 switch from mono 2 stereo
If it doesn't have a strong enough signal the TV won't detect the stereo signal in the first place. If that happens the stereo option wont be highlighted.
Sep 10, 2009 | LG 42LG50 42 in. LCD HDTV
20" RCA television
Greetings de_on,
Per your owners manual I found you should have an option in your Audio menu labeled MTS. You should be able to adjust the MTS by selecting it and press the + key.
There should be three options under MTS: Stereo, Mono, Auto SAP. You would probably want to select Stereo as Auto SAP will engage the Second Audio Programing which will cause other sound problems.
Hope this helps.
Jon
Go Ahead. Use Us.
May 12, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Akai LCT2070 Stereo Sound
This tv is kind of got a mind of its own the only time you can adjust it on mine is on cable that comes in stereo actually it usually switches by itsself after it reads the broadcasted sound. Hope this helps.
Nov 09, 2007 | Akai LCT2070 20 in. EDTV-Ready LCD...
Coby TFTV3227 32 in. LCD TV Logo
43 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
