Question about Garden
Looking for proper spark plug for CTC mastercraft snowblower 10-33 model 318 961 515 older model
    Top Expert:
  • 2,044 Answers
Pull the Old one out and purchase an E3 Spark Plug. They work great on Smaller engines. There are only a hand full of plugs for small engines...
Posted on Nov 07, 2014
Owners manual for Mastercraft 12HP, 30 snowblower
Try Googling (Mastercraft)(31AE983H515)(manual) without parens.
Jan 17, 2018 | Garden
I need a manual for a mastercraft 12 horsepower snowblower 30 in cut
Try Googling (Mastercraft)(model)(manual) without parens.
Jan 11, 2018 | Mastercraft Garden
Mastercraft Snowblower 8hp28inch cut.Snowblower starts to miss and run rough after it is warmed up what is the problem
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=manual+for+a+Mastercraft+8+Hp+snowblower
Feb 05, 2016 | Garden
I need to know the length of belt required for a mastercraft 15 hp 46 inch deck. the belt drives the blades
Take a string and palce it as you would the belt, then measure the string
May 11, 2014 | Garden
I have a 8/26 mastercraft snowblower Model No.
Have you checked all belts and belt tensioners? If so, you will have to tip unit up and take bottom plate off of unit. The drive system consists of a rubber lined wheel that makes contact with a friction plate once handle is depressed for drive. As you change gears you can see rubber drive wheel changes position in relation to friction disc to change speed. If belts are good, I would look in this area for problem. These rubber lined dive wheels do wear out and are replaceable. Also, on some models you can adjust further. Hope this helped. Happy wrenching!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 09, 2013 | Garden
My mastercraft "deluxe" 8 hp, 26" snowblower won't
Could be dirt in the carb. If this engine has a fuel cup on the bottom of the carb take it off and clean it out and clean the fuel jet. It is the little screw that has a little hole through it. If this has any dirt in it the engine will not run. A lot of engines I get in this is a quick fix as most people do not run the old fuel out before they store it for the summer. Check the spark plug as well and see if there is wet gas after trying to start. Maybe your choke is not working.
Oct 26, 2017 | Garden
Mastercraft Maximum Compound Mitre Saw
built by canadain tire company their customer service number is 1-866-746-7287 they should be able to get u replacement part and or advise who in ur area can
Jan 25, 2010 | Saws
I need a manual for a Mastercraft 8 Hp snowblower P/N 316 582 515
Jim
Dec 03, 2009 | Garden
Mastercraft snowblower will not start
if old gas was left in the tank and not flushed it makes the carb stick and won't allow the proper gas flow to the motor...I would first test the plug by verifying it has spark..if it does what i do at times is quickly spray some quick start in the plug chamber and reinsert the plug and try to restart...this at times will get the spark going and allow the motor to start.....you can also try to spary some in the carb before starting...just a squirt or two....the best thing to do is actually clean out the carb as it is likely the issue.....hope this helps
Dec 18, 2008 | Mastercraft Garden
Garden Logo
114 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
