Question about Kitchen Ranges
My oven preheated fine and when I put the stuff in the oven the broiler element was still on and wouldn't go off. Do you know what would cause this?
Today I decided to try it again and it preheated fine and I never noticed the broiler element coming on at all. It seems to be working. We have replaced the temperature probe twice because it coded but this time it didn't code.
    Prodigy:
    An expert who has answered 500 questions.
  • Kitchen Ranges Expert
  • 646 Answers
It sounds like the broil relay contacts welded themselves shut (closed). You will need to replace the Electronic Oven Control (EOC).
Posted on Nov 27, 2014
catriver
  • 878 Answers
SOURCE: Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Posted on Sep 07, 2006
aborcass
  • 2651 Answers
SOURCE: oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Posted on Mar 26, 2008
  • 1214 Answers
SOURCE: LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Posted on Jan 24, 2009
SOURCE: GE JBP30 oven bottom element not working after being replaced
I would be looking at the bake relay on teh coven control board. Using a voltage meter test the output voltage when energizing the bake feature. Be sure to remove the bake element wire coming from the bake element to the control. Test this terminal without the bake element wire attached. From the terminal with one meter probe to the neutral on the terminal block (where your cord attaches to), you should read 110 volts when energized and 0 voltge when shut off. What are you reading? If I can help further, I am here.....
Waiting to hear from you,
Eric Campion
Posted on Feb 15, 2009
SOURCE: Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
i dont know want is wrong with it when i turn the oven on it keeps saying e2 and f3 i dont know what that mean please help me one on .... :(
Posted on Nov 28, 2009
Oven takes forever to preheat. Only the bottom oven element comes on during preheat.
Try checking the heating elements on the top might have come loose
Apr 22, 2016 | Ovens
Turn my oven to preheat, broiler comes on and not the bottom element. Checked the ohms on element and it did move the meter.
Check the broiler element, and see if get the same reading.
Does the oven heat on normal "bake" settings? If so, the bottom element is fine, and it's the "brain" not telling the bake element to get hot.
Jun 08, 2015 | Ovens
I have a GE 24 inch wall oven model number JRS04B0W5BB that when bake is selected the broiler element comes on and then after awhile it looses temp and does not cook anything.
Ovens often use broiler element to preheat, then shut off when set temp is reached. Check fuses for and bake element itself.
Dec 01, 2014 | Ovens
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
I have a ken more range and the broiler stay on the control for the broiler need to be replace but i don,t want to put lot,s of money in it i disconnect the top element can i use my oven to bake or do i...
NOOOOOOOOO
you may be able to disconnectr the element
after doing so trey heating your oven
some need the broiler to preheat properly some dont
b ut do not connect them together
Sep 18, 2009 | Kenmore Kitchen Ranges
My oven has increased only 65 degrees in almost an hour....what does it mean when it heats up, but SLOWLEY??
The broiler element on the top of the oven comes on during the preheat cycle to speed things up and then only the lower element keeps the temperature steady. One of those elements is bad, probably the broiler. Try using the broiler and see if it works. If not, you need to disconnect the elements from the oven and check them with an ohm meter. If gthe elements check out ok, then it must be the temperature sensor/thermostat.
Jun 25, 2009 | Frigidaire FEB27S5A Electric Single Oven
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Oven Wont Preheat
does the bottom element get hot? could be a bad heating element.
Feb 01, 2009 | GE Kitchen Ranges
Oven will not heat - Thermador SMW272 Electric Oven
since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
Dec 12, 2008 | Thermador SMW272 Electric Double Oven
Kitchen Ranges Logo
90 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
