Question about Lux Thermostats CAG1500 Digital Programmable CleanCycle Heating and Co
How do I get the heat to come on if the words fan and heat are flashing?
    Master:
  • 602 Answers
The heat is set to on but the blower fails to start. To protect the unit the heat will not run without the blower. The start capacitor for the blower is the most likely failure.
Posted on Nov 10, 2014
Why does my fan and heat words keep flashing and the heat is not turning on?
When the blower motor fails to start: To protect the system, the heat is prevented from starting and the lights flash a warning
Nov 06, 2014 | Heating & Cooling
Why is the air conditioner flashing HEAT
a half hour is to much time!!, insuficient gaz installacion OR leak gaz installacion ,,
Dec 06, 2012 | Mitsubishi MSH09TW Air Conditioner
Heating sequence failure.
check for flashing trouble codes on mother board
Oct 27, 2017 | Heating & Cooling
Fan blows but no heat. Green light flashes four times
If the fan blows and green light flashes. When the green light is fix, it means the time is set to start your heat pump. Check your electrical control and wiring for any damages including the terminal lugs, capacitor, or relay. Check also if the thermostat is working. If your heating comes from heating coils, check continuity of the heater wire including the overload. Replace any defective parts.
Sep 01, 2011 | Heating & Cooling
Hi! I have Asus m2n-vm hdmi motherboard, about month ago i've got problem: if computer works more than 12 hours, it freezes and works normally just after few hours "rest". Also, after shutdown...
Hi lvadim1993,
In other word your PC works intermittently. Here is what you have to do. Check and remove the processor cooling fan and heat sink clean the cooling fan and heat sink. If you have a thermal compound remove the old thermal compound and put a little amount at the center of the heat sink. Reinstall it back the processor cooling fan and heat sink and make sure It install properly even and snag tight. re plug in the cooling fan connector to the motherboard. If you have a video card remove and clean the video card connector and the cooling fan and heat sink with air blower same also to the memory card. Use the air blower to clean the motherboard and the entire internal of the PC. Reinstall the video card and the memory card and make sure that they are install properly. replug in the video cable and the pc power cord and turn on the PC. this will work. the computer is just over heating. I hope that this information will help you solve the problem.
HRH
Jan 05, 2011 | Computers & Internet
Thermador oven will not self clean.The blower fan does not turn on, and the word HEAT never appears when LOCK stops blinking. In other words, after following steps 1,2 and 3 fan and heat never happens.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 23, 2010 | Thermador Ovens
My samsung HT-Z310 is flashing blue with the word protect on the display and the fan does not come on straight away is this the problem?
See the link below for an explanation of protect mode. The fan does not need to start immediately as it is load dependent. The fan will kick in based upon the output volume level or heat level. If you are interested in repairing this, I would suggest that you invest in a detailed repair estimate. Report the results here and we'll walk you through the actual repair.
Dan
Nov 01, 2010 | Audio Players & Recorders
"cool on " flashing..no heat or cool air blowing
when its flashing its in a 5 min delay mode if you wait 5 min and still flashing you may need a new stat. but give it a full 5 min.
Sep 20, 2009 | Heating & Cooling
This is a heating and cooling through the wall heat pump. It works normally when heating is selected - the heat pump runs and both speeds of the fan blow warm air. But nothing runs when cooling is...
You have a bad board or bad switch. I would say board. You can have service tech check this out. There is only so far you can go without knowledge of Controls ad electricity. Russ
Jul 21, 2009 | Heating & Cooling
Flashing Red/Green. No error code on screen, but contact M$.
Check the back of the xbox make sure everything is put in.
Dec 31, 2007 | Microsoft Xbox Console
Lux Thermostats CAG1500 Digital Programmable CleanCycle Heating and Co Logo
195 people viewed this question
Top Lux Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Lux Heating and Cooling Expert? Answer questions, earn points and help others
