Sharp xl-hp535 shows err-cd 1 the rest of the trays showing discs even though no discs actually in trays is my problem solveable
SOURCE: cd changer won't open
try to open by hand,see if the tray is stuck.
opening by hand is you turn the motor.
if you put a power supply direct to the motor the pcb will be burnt
(giving a bigger problem).
Look for mechanical problems.
Posted on Mar 09, 2008
AREA51S4B
  • 30 Answers
SOURCE: screen only shows "cd"
possible tray stuck, will cause this problem, if you can get the case off, 2 screws on the bottom and 4 or 5 on the back case , if it is jammed the unit will not initialize..I am talking from experience with model and simular models ..I have repaired alot
Posted on Nov 05, 2008
snakehead
  • 1074 Answers
SOURCE: My sharp cd player is showing error 11. door will
dismantle your cd player and set it up back and it will automatically reset itself. if does not then have a tech repair it as your aduio output is damage or the momory chip needs to be replaced.
Posted on Apr 18, 2009
SOURCE: Hi,
I have this unit as well and the disc MUST say CDR Music on them.
Normal CDrs will play,but not record.
Lance
Posted on May 17, 2009
  • 86 Answers
SOURCE: Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Posted on Oct 09, 2009
My radio/CD player constantly says "ERR" and CD's won't play anymore. It doesn't show the time or the radio station either, just "ERR". I can hear it, like it's trying...
HI lisasmith566 IT is not a fuse problem .
the problem is your the CD part of the radio
must likely the cd is stock or more likely the cd drive motor is defective .
FIRST try pushing eject on radio and see CD comes out if not you need a new radio .
good luck vote
Jul 27, 2011 | 2003 Chevrolet Tracker
Cd component not working
Hi Bearo
Here you can find an online manual,
And here the specific troubleshot section.
When you say the tray dosent open, is there a CD inside, or is it empty?
Jan 02, 2008 | Sharp XL-ES50 CD Shelf System
6 Disc Changer > Err
Don't waste your money and buy those repair manuals. There is an easy fix for this. The rootcause is most likely related to your disc tray (crooked carrier or broken spring). Just get a small screwdriver and take out the two black srews of the inner faceplate, covering the cassette tray itself. Please make sure you do not drop those tiny screws. Use a magnetic tip screw driver. Take the faceplate off. You will see a litlle lever in the center. Just push it aside and your cassette will pop out with no problem. That simple. So don't waste your money!!!
Apr 17, 2009 | Car Audio & Video
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
On my JVC TH-60 disk drawer will not open?
hello the problem you have is that the tray is not in time so the security switch dont let to open this try to get ifo how put on time or align the mark on main spindle against the small one hope you undrstood saludos
Jan 08, 2009 | JVC XL-F154BK 5-Disc CD Changer
Pioneer cdxfm128 12 disc changer
Err 11, Err 12, Err 14, Err 17
Dirt or a scratch on the disc stops the laser
beam from being able to focus.
Dirt or a scratch on the disc hinders the track
Clean or replace scratched disk.
There ya go, clean or replace the cd that is displayed.
Nov 15, 2008 | Car Audio & Video
Sharp XL-HP535
Hi try this.....
Put the system in standby (ie off but plugged in) then whilst pressing down the record button and the X-BASS/DEMO button, press the PRESET DOWN (i.e.left hand one) button until "CLEAR ALL" appears, then power on your system.
This gave me some functionality back i.e. i can play normal wave CD's but not mp3 ones....
Hope this helps
Oct 18, 2008 | Audio Players & Recorders
My cd player shows err whenever I put in a cd even if i put in a new cd it still shows err.
Your cd shows error whatever you put a cd ,,the problem is in the mechanism in the roller,that moving back and port bringing the set .The roller is under the tray which you going to put the discs. The old grease their is hardened already that cause abnormal travel of roller . Clean that by using a lighter fluid or like that fluid ,in order to take the old dirt grease and replace it with a new one , a first class grease type-A grease put only little amount in the roller. Wipe the lense witha use of cotton buds without any chemical. Try this solution so performance will be better...feel free for asking further assisstance rate me as fixya....
Jun 19, 2008 | Audio Players & Recorders
"Err" message
i had err 2 screen. removed case (about 10 screws, took just a few minutes) and found 1 disc was had been knocked out of the tray. removed all discs. replaced case. works fine again
Dec 29, 2007 | Denon DCM-280 5-Disc CD Changer
ERR 308
Open and check. Could be a mechanical problem - a jammed disc, or broken drive belts.
Oct 02, 2006 | Sharp CD-BA120 Shelf System
42 people viewed this question
 Grubhead
Grubhead
