Question about Whirlpool Microwave Ovens
What causes my microwave to show 'door' when I press start and not work?
Gmc305prs01
    Master:
  • 442 Answers
That's a code to warn you the door is not secure. If it will not close completely try checking to make sure any screws on the door hinges are secure and the door is not loose. Since most don't allow you to check this yourself you may be out of luck. If there isn't a door problem and it closes securely then you probably have a defective contact switch that signals when the door isn't closed and will need professional service.
Posted on Nov 07, 2014
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
Oster microwave starts when door is closed but no buttons pressed
This is usually caused by a door switch that has come loose or out of adjustment.
Jul 19, 2014 | Oster 0.7 Cu. Ft. Countertop Microwave -...
Microwave Cooktop / Night Light not working
I would check the door switches with a digital meter, set to ohms, disconnect one wire from switch and test for open and short by pressing door switch, if you hit one that tests the same when pressing and releasing, switch should be replaced.
Mar 06, 2012 | GE Microwave Ovens
I have a Maytag OTR Microwave oven that doesn't work. After I close the door and set the time and start, I see the time countdown, but I don't see the microwave starting. I can get the microwave to start,...
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
See our file on door switches here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 30, 2010 | Maytag Appliances Over-the-Range Microwave...
Sharp carousel convection/grill/microwave maybe R990
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Jun 03, 2010 | Panasonic NN-S254BF Microwave Oven
My General Electric microwave shows RESET on the console but none of the buttons are responding even though i have plugged and unplugged it a couple of times
Good day Sir, here's troubleshooting tips.
Problem: Oven will not start
possible causes: power surge/plug not fully inserted/door not securely closed/start pad not pressed.
Jan 24, 2010 | General Electric Microwave Oven
Microwave oven screen reads "Door" when I press the start button.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 03, 2008 | Microwave Ovens
My microwave is not working and the repair in scheduled for April 3rd. This is not acceptable. Please helop me to find how I get in touch with the department that handles scheduling.
My Panasonic 1300 W Microwave will not turn off. When I open the door after cooking it restarts and when I open the door before cooking it starts. I can stop it by pressing stop/reset before opensing the door after cooking has stopped but if I press this befroe opening the door to put a meal in to start cooking it will turn on by itself. What's causing this and is it worth fixing?
Mar 19, 2008 | Microwave Ovens
Does not start !
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 02, 2007 | Danby DMW139 Microwave Oven
Microwave Ovens Logo
57 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
