Question about Saws
How do I change the angle of the blade on a pcb220ts porter cable portable table saw
I just want to know how to make adjustment to the height and angle if the blade
rowdy45176
  • 2176 Answers
SOURCE: dewalt 10 inch portable table saw blade height adjustment very st
What I would do is clean area with air (wear safety glasses) then I use a spray type of dry lubricant on the threads and also the plates that the motor slides on. You can also use WD-40 in a pinch. Hope this helps
Posted on Dec 10, 2008
efs_perpends
  • 1996 Answers
SOURCE: Table Saw Blade Won't Cut Straight
Inside the saw, on the end of the trunnion is a stop that is adjustable to zero the saw in to exactly 90 degrees. Either there is sawdust or something accumulated there or it needs to be adjusted. You say you cleaned it out, So you'll need to unplug it an have a look up in there. See how there's a geared piece of steel that moves when you crank the saw over to 45 degrees. Usually there's a bolt or stud with a locking nut on it, either on the trunnion itself or the lower surface of the table top. You need to break the nut loose and screw the bolt in or out to adjust, then crank the saw over to hit it, check for square with a known square, crank it all the way out of the way and readjust, etc. Until you get it right. Make sure to tighten that lock nut when you're done.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
  • 5 Answers
SOURCE: craftsman model 708100 table saw tilt lock won't stay locked
Try removing the lock knob and putting a toothed lockwasher on the shaft. reinstall the knob.
Posted on Dec 21, 2009
miket756
  • 2702 Answers
SOURCE: MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Posted on Mar 28, 2010
philwalker78
  • 608 Answers
SOURCE: Fox F36-522B table saw: The blade
Hi, there is no lever or knob adjustment as such but if you look underneath where the motor and blade shaft mount in the carrier you can loosen the mounting bolts and twist the carrier in the direction required to align the blade then re tighten them.1 mm out of parallel is only half a mm of twist. Hope this helps, regards Phil.
Posted on Aug 20, 2011
How do you higher or lower the blades of qualcast hover mower
There are not any levers or anything to adjust blade height.
You change blade height by placing spacers above and/or below the blade. You have to remove the blade and relocate the spacers on the blade bolt to move the blade up or down.
Jul 01, 2014 | Garden
Blade does not square up on c10fsh miter saw
To square up a mite saw blade, you need to eeither move the table or adjust it to be square if it is out in the mitre angle, or if it is out in the bevel angle the whole saw head needs to be adjusted, and this is done via the bevel adjustment at the back of the saw. There may be a bevel stop bolt to return the saw back to 90 degrees if moved to a different bevel angle. Usually the blade itself is not adjusted bu either the saw table or the bevel angle of the saw head itself to correct these issues.
Feb 28, 2011 | Hitachi Garden
09 ram 2500 over heating with plow on going down the road. have had this truck for 1.5 years and this is a new problem. never did it before. dealer changed thermistat today and still doing it
have you changed height or angle of the blade resulting in reduced airflow into the radiator lately???try different angles and blade heights for more air flow
Feb 04, 2011 | 2004 Dodge Durango
Extension pole sways back and forth while the fan is on
One or more blades is out of line. Get a ruler or a stick and mark the distance from the tip of one blade to the ceiling. Hold the stick in place and carefully rotate the fan until the next blade is near the stick. Do this until you have all four marks on the stick. It is important to try not to alter the position of the extension pole in between blades. Now you will find that one or more blades are at different heights. Carefully bend the worst blade until it is closer to the rest. If teh blade holders are cast, this may not be possible and you may have to pack the blade angle with washers or cardboard until they are right.
If by some chance they are all close, then it may be the "attack angle" of one blade. This is harder tot detect but sometime you can pick which balde by eye and adjust by trial and error until it is better.
Cheers,
Glenn.
Nov 07, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Hi, got a Craftsman 20 Hp 42 inch cut , the Deck will not lay flat, it is always on a angle. any ideas ? No matter what the cut height is set at.
Hi tubbed,
Most of these decks are held on at three points. Two are in line 90 degrees from front to back. The other is attached to the height adjust lever.
The first two are adjustable to change the type of angle problems you are having. Make sure you have the engine off when checking. Adjust until the desired angle is reached.
Also, if the model your problem is categorized under does not match your model, the cause of the angle and the solution may be different.
Best regards
Mike
Jul 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do you set the mower blade height on a riding mower. The mower deck is set by the height adjuster but how about the blade
The blade height is not adjustable on any of the tractors I have worked on or owned. The blade seats against a shoulder on a spindle and held in place by a nut. Sometimes replacement blades are not shaped the same as the original and changes the blade cuttnig height but other than in those circustances there is no adjustment.
Jun 18, 2010 | Garden
Blade does not cut straigt. How do I adjust the
There shoul be a scale and a crank or screw used to adjust the blade angle on the front of the saw blade feed bushing. Make sure you set this to 90
Feb 26, 2010 | Dewalt & Variable Scroll Saw
Husqvarna gth main belt keeps breaking
Make sure the mower rake angle is not too much,On level floor point one of the blades in a front rear orientation,measure height of blade from floor the front measurement should be no more than 1/4" lower than the rear measurement.If the front of the mower is too low the angle the belt has to run is too much and the belt will twist and wear rap[idly.To raise the front of the deck there are either one or two adjustment rods that attach the front of mower deck to frame tighten this adjustment up to raise the front of mower deck.
Jul 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Can the blade height be adjusted on the flymo 300 compact?
the blade shape can not be changed they are heat treated and if bent they will break, the only way to change the blade height is by changing the blade adapter.
Apr 05, 2009 | Garden
Bought model 3400 skil table saw. have no manual. can't find control for tilting blade. how do i tilt blade
This model does not have a knob on the side.
There is only a locking lever on the front next to a single rotating wheel for height adjustments. To tilt the blade simply twist the locking lever to the left and push the height adjustment wheel to the right. It can be a bit stiff at times to move.
Feb 26, 2009 | Skil 10" Table Saw 3400
Saws Logo
67 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
