SOURCE: INOP low beam and high beams
The problem is the headlight switch itself - it's one of the most common failures on these cars. The part, brand-new, is about $158 from ECSTuning.com. Replacing it involves removing the airbag and steering wheel - not difficult but a little nerve-wracking due to the power of the airbag.
If this is something you want to tackle on your own, reply back here and I can give you a step-by-step on doing the work yourself. Or you can go to a shop/dealer and just have them do it. They'll probably charge you at least two hours' labor, even though it's a 40 minute job. Let me know what you would like to do.
SOURCE: Low beam headlights don't work
I know this is not your problem, but my low beam stopped working, both bulbs failed, no burn marks or broken element. Just had to tell someone
SOURCE: low beams dont work, only high beams do. 02 tacoma
If there is power there, then it has to be the bulbs. The trouble that most people have is, they don't see how both bulbs could burn out at once... and they're right. They don't. But you see vehicles with one headlight all the time. They don't know it unless you tell them or they happen to see it themselves. Then the second light burns out, and they think it's a major catastrophe, when in fact, it's just bulbs. The high beam still works because the bulb is double filament. The only other thing it can be is the dimmer switch, and since you switched it to high, it appears to be working. However, if it's not bulbs, it still could be the switch.
SOURCE: 2000 impala-low beams don't work but high does
sounds like the problem is the dimmer switch, get a price on the dimmer switch. If you have to, get one at a junk yard . It's cheaper.
