Question about Cell Phones
How to get my kist if contacts saved in my gmail back up
Recently replaced speedometer sensor on my 2005 Chevy Tahoe speedometer still does not work do you know how to fix it
Yes , replace the stepper motor inside the instrument cluster . The speedometer sensor as you call it is actually a VSS - vehicle speed sensor. If the transmission shifts good an engine runs good it's not the VSS bad. You have to know how it works to fix it . The VSS is an input to the PCM/ECM - engine computer , The PCM/ECM calculates engine speed then sends this info to the instrument cluster over the serial data communication bus . GM has had bad stepper motors in that year vehicle . How to repair GM Instrument Cluster Speedometer Gauge Stepper
Apr 08, 2016 | Cars & Trucks
I cant access my gmail account in order to retrieve my contacts i don't remember the password
Depending on how your phone was setup. Your contacts should be saved into your Gmail contacts.
Since you lost your password, you will need to use the Google Accounts recovery webpage to reset your password. NOTE: You will need to answer questions to get back into your account. If your answers don't match up you can't get in.
https://www.google.com/accounts/recovery/
Sep 17, 2014 | Google Gmail
How to add contacts to my Gmail?
You can add contacts to your Gmail account by following the steps below:
1.Once you have logged in to your Gmail account, click "Gmail" drop-down menu on the top-left corner of the webpage and go to "Contacts".
2.Now, click "New Contact" button on the top-left corner.
3.In the page that comes up, fill in the information about the contact you wish to add. The details will get saved automatically.
These links can be useful:
https://support.google.com/mail/answer/8933?hl=en
http://www.wikihow.com/Add-Contacts-in-Gmail
Hope this will help you.
GuruAid.com
Sep 08, 2014 | Google Gmail
Why can't I download my gmail contacts list?
Yes you can! Open your contacts list (Button GMAIL>Gmail Contacts Tasks), then hit the "MORE" button, select "EXPORT", and follow directions. You will be asked to select which contact list, which format, and the where to save the list.
Aug 12, 2014 | gmail.com
How do I get my gmail contacts transfered to my Microsoft Outlook 7 contacts?
OK
try these steps:
  1. Log on to your Google Gmail account.
  2. In the left column, click Contacts.
  3. On the right side of your screen, above the message count, click Export.
  4. Click Outlook CSV (for import into Outlook clients).
  5. Click Export Contacts.
  6. When prompted to download the export file, click Save.
  7. Choose a location on your computer to temporarily save the file. The default file name is gmail-to-outlook.csv.
NOTE You can delete this file after your contacts are imported into Outlook.
  1. Click Save.
  2. In Outlook, on the File menu, click Import and Export.
  3. Click Import from another program or file, and then click Next.
  4. Click Comma Separated Values (DOS), and then click Next.
  5. In the Import a File box, browse to find the file you downloaded in step 8, and then double-click the file.
  6. Click one of the following:
    • Replace duplicates with items imported
    • Allow duplicates to be created
    • Do not import duplicate items
  7. Click Next.
  8. In the folder list, click the Contacts folder where you want the imported contact information to go, and then click Next.
  9. To add or remove fields to determine the way the contact information is saved in the new imported file, clickMap Custom Fields.
Thanks to:
Microsoft at:
http://office.microsoft.com/en-us/outlook-help/transfer-contacts-between-outlook-and-google-gmail-HA010222048.aspx
Jul 07, 2014 | Microsoft Office Outlook 2007: Windows
Lost my contacts etc on galaxy rush
Were they saved as "phone" contacts, or were they backes to a Google/GMail account? If they were backed up, you can simply tell it to sync, and it will restore them. If they were only saved to the phone, they are probably gone.
Sorry. Good luck. :-(
Nov 03, 2013 | Samsung Galaxy Rush Boost Mobile
Is krispy kist same as cretors
Cretors purchased Krispy Kist many years ago, so yes.
Jan 30, 2013 | Cretors Hot Air Poppers Model 685
How do I save my contacts from mi iphone?
If you have a Gmail account, go to Settings > Mail, Contacts, Calendars > Import SIM Contacts
I assume this would work no matter what email account you have set up in the phone, but I can only speak for Gmail, myself.
Dec 21, 2012 | YouTube Videos
Can I download my phone contacts to my computer so I have them if I loose my phone
Since HTC Hero runs on the Android Operating System, you can configure your phone to sync with your GMAIL account. This way, your contacts will be saved in your list of Contacts in Gmail and you can then download them if you want to.
To configure syncing with Gmail (if not already done), do as follows:
  1. Go to Settings --> Accounts and Sync
  2. Click on the Gmail a/c link that you'd want the contacts to be saved to.
  3. Select "Sync Contacts" (checkbox). Once you tick the checkbox, your phone will continue syncing with Gmail at regular intervals.
  4. If you want to sync immediately, press MENU and choose "Sync Now"
  5. You'll be able to see visual confirmation of the syncing process.
Once the syncing is completed and if you want to download a copy of your contacts, use Gmail to Export your list of contacts from the Contacts section of your Account.
Hope this was helpful. If so, please consider rating this solution.
-best regards,
M
Mar 12, 2011 | HTC Hero Smartphone
Can the g1 sync contacts to the sim card
The G1 can definitely import contacts from the sim card, to do this you press menu while in the contacts application and then press import contacts. However I don't think it can save contacts on the sim card, because it already automatically saves them to your GoogleMail. So at least your contacts are backed up onto your GMail account.
Jun 08, 2009 | HTC G1
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
