Question about Music
Program4pc dj music mixer 5.4.0.0 activation key
2 Suggested Answers
  • 20 Answers
SOURCE: how can i open the music file for my digital dj
I don't know what you are trying to do. But your mixers needs analog inputs such as cd players or turntables.
Posted on Mar 10, 2010
Please send my program 4pc dj music mixer activation key now
You need to contact the manufacturer, Fixya did not sell you the item and we do not have the activation key.
Jan 06, 2017 | Music
How do you use the headphones with cd turn tables?
you should have a headphone out on the mixer or you need a mixer
Dec 10, 2014 | Behringer Ddm4000 5-channel Digital Midi...
My 800 watt powered mixer was working fine until a keyboardist plugged in his keys and amp. The sound would fade out. When it was unplugged, it worked fine. Later that even, another DJ with an 800-watt...
All sound equipment has to operate without overloads in any given place. The power source should always be examined at commercial gigs and worked out with other performers along with management. The only fix is to do these checks up front and make safe arrangements.
Mar 18, 2013 | Music
How do i connect thump 15 A powered speaker to powered mixer?
You failed to give us the most important information... what brand and model of the mixer? Youwill use balanced interconnect lines to a balanced MAIN output jack, assuming it exists...
Aug 05, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Im thinking about buying a djx750 and have rokit 5 monitors. would this work? what is the best way to connect them, to have good sound? it is just for a home dj setup, all on one desk, two cd decks,...
Here is alink to the manual:http://www.behringer.com/EN/downloads/pdf/DJX750_P0956_M_EN.pdf You should have no problems hooking them up (RCA to RCA). I've been using a Behringer XenyX1222FX board in my recording system for about 4 years now and have been quite satisfied with it's reliability. Try to find a dealer who will demo the mixer for you.
Aug 24, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Amps ? stereo intergrated amps ?
Since the mixer has a line level output, yes you can use a home stereo for the "AMP". Use the AUX IN, TAPE IN or CD IN on the stereo and connect the speakers as you normally would.
Dan
Feb 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How can i open the music file for my digital dj pro mixer
Feb 12, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
My effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Faulty effects behringer djx700
The effects on the PMP powered mixers flash UNTIL you push in on the selector knob. This way you can dial in the next effect number and then push in later to activate when you want it... Could yours possibly be the same technique?
May 16, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Music Logo
52 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
