Question about Video Game Consoles & Games
How do I connect my ps3 to an lg. 50pm1m? Is there an HDMI port I'm missing?? We cannot find one. Thanks.
How to connect sony ps3 to toshiba 32av500a
Use any HDMI cable to to this.
Connect cable to the "HDMI" port on the back of the PS3. Connect the other side of the HDMI cable to the "HDMI" port on the Toshiba TV. If the Toshiba TV has multiple HDMI ports, make note of which port you plugged the HDMI cable into.
Change the Toshiba TV to its "HDMI" video display mode. Press the "Power" button on the PS3 to turn the console on. The PS3 will automatically detect the HDMI cable. Select "Yes" to use the audio and video from the HDMI cable. Select "Yes" to have the PS3 automatically use the optimal settings for the Toshiba TV. Select "Yes" to accept the recommended resolution. Press the "X" button to save the settings
Dec 22, 2012 | Toshiba Televison & Video
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
I have an LG DVD Reciever HT462 which i want to connect to my PS3. My PS3 is all set up correct as I have spoke with Sony. I have the PS3 connected via a HDMI cable to my TV and an optical cable running...
It would appear from what you have said that you have everything connected properly. Maybe a silly question, but make sure you select the digital input on your LG to get the sound from the PS3. If there is still no joy, unplug the optical from the back of the LG unit. Look at the end of the Optical cable that should still be connected to the ps3. Is there what looks light a red light there? if so it means that the optical is getting to the LG system and the LG sytem's digital in port is Duff. If there is no "Red Light", unplug it from the PS3 and look directly at the optical out port on the ps3. Is there a Red Light there? if there is, you need a new optical cable. If there is no red light, you need to enable the digial output on the ps3. If you have and it's still not "red". the optical port is duff.
Jan 07, 2011 | LG Audio Players & Recorders
My lg tv will not go into hd mode, i have a hdmi
upgrade software file needed from lg using usb port.
Feb 02, 2010 | LG 42 in. Flat Panel LCD HDTV
How would i know if my HDMI ports are working or not?? Tried to connect a PS3 to it but nothing. Thought it may have been the cable so checked someones that i know is working and still nothing. Checked...
As you already checked PS3 and HDMI cable,
select HDMI input in TV and connect PS3 via HDMI cable. TV should show PS3 picture.
And if still no joy then HDMI input port in TV is bad and need to replace input board/ main board.
Jul 08, 2009 | LG M227WD-PZ LCD TV
LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
Try different settings.
I hope this helps.
Mar 28, 2009 | Televison & Video
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
PS3/HDMI issues
the cable you purchase does not support the connection on your set.
Jan 23, 2007 | Samsung TX-R2779H 27" TV
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
