Question about Onan Cummins 4.0 KY-FA/6747 RV QG 4000 EVAP 4000K C.A.R.B Compliant G
My onan 4000 generator won't crank. Fault light has non-stop fast flashing.
Battery and all power systems ok. Will crank when sol. is jumped out but no fuel etc. it just cranks. Won't go into fault mode.
  • Renee F
    Renee F Feb 18, 2015
    Hi sean keough, I want to help you with your question, but I need more information from you. Did you get it fixed?
2 Suggested Answers
  • 51198 Answers
SOURCE: Onan 5.5 generator cranking over very slow and finally the starter makes a grinding sound.
replace the dead battery
Posted on Apr 23, 2018
Onan 4000 won't turn over
check for bad battery, loose terminals ,dirty terminals , faulty starter relay
if it is not starting check for oil level is correct ( low oil level sensor turns off ), diesel -air in system
Jun 11, 2016 | Onan Microquiet 3600 & 4000 Generator
How to clear the code fault on my Onan 4000 generator. What causes a fault & why???
what model is it KY KV need that and Spec. If it blinks 3 times it indicates a lower service fault. While blinking hit the stop button 3 times fast, then read the code. It will blink, pause then blink again and repeat. What is that code and I can help you. IE 4 blinks pause and 3 indicates code 43
Nov 13, 2014 | Watts Onan Portable Generator - 4000 ,...
How to correct over crank fault??
Over crank is failure to start, check fuel and ignition, why it isnt starting
99 suzuki vitara v6 turns on all power but wont
the starter uses 10x more elect. power than the head lamps
or 100x more than dash lamps. it means little.
what matters most is jumper cable starts.
does it crank with jumper cables to a running, donor car,(aaa jump)
no bad starter
no, bad starter key line( immobliizer or such) ask how to test.
yes, cranks great, now.
that means the battery was dead,
i charge the battery and it now cranks, due to lights left on or
charge system failure, if battery goes to 13.3 to 15v running good
if on the charge system failed. (causing battery discharge)
if after charging a battery it will not crank car, its a bad battery (jumps ok)
Sep 09, 2014 | 1999 Suzuki Vitara
96 Monte carlo z34 won't crank over unless I jump
Sounds like a problem with the key switch, probably the security system. You may only have power to the fuel pump when the engine is cranking.
Is the security light on or flashing ?
Jun 29, 2013 | Cars & Trucks
Onan 4000 generator
Check the rotor slip rings and brushes first, the rings should be clean and bright
Jun 24, 2013 | Watts Onan Portable Generator - 4000 ,...
Why won't my 2012 Suzuki Grand Vitara start?
ill answer for NO ELECTRICAL POWER :
sure and is easy with any DMM meter, got one? any $20 DMM.
my guess;1
engine will not crank
dash lamps out.
head lights out. dead.
post systems of electrical system , all parts that work and those that dont work, and problem is easy.
cleaned battery terminals.
tried borrowed battery that reads, 12.6vdc ? (charged is 12.6)
2012 that is in warranty car.... ?
my guess on 2012
jumping a car, that is battery jump starting.
a battery can short, and no jump start on earth will start shorted battery in car. but does lay down some big sparks, or burns up cheap walmart cables.
if the car will not crank, say just that, my starter motor will not crank
jump started from live running other car.
if true then make sure headlights work , if they dont work fix that first.
HL must always work, even keys in pocket.
best is to put a fully charged battery in the car, jump starting can cause
surges that can damage sensitive electronic$$$, do jumps as a desperate measure,
with a charged battery,
1: Head lights work, no fix that , use voltmeter
2: cranks robustly.
no , wiggle shifter lever, (on A/T cars the park switch blocks cranking) On M/T the clutch blocks cranking.
with any dMM
measure battery voltage before crank and during.
12.6v good. reseted.
cranking.
0 to 10v bad (weak battery or shorted starter motor)
11 and above good. and must crank, if not , starter is bad.
to prove starter is bad, check voltage at starter solenoid coil wire lug.
it must be at 11v cranking , below 8v it chatters, and fails.
if at 0v cranking this lug that means the Key start line is failing.
A/T switch not closes, or bad ignition switch.
May 25, 2013 | Suzuki Grand Vitara Cars & Trucks
Onan generator microquiet 4000
Check the pickup tube in the vehicle, the fuel pump is suspect. If you check the fuel pump pressure and it is ok, then try installing a test check valve between the fuel delivery hose to the generator. If it solves the problem the pump is losing it's prime internally, so replace the fuel pump.
May 24, 2013 | Onan Microquiet 3600 & 4000 Generator
I jumped car off it crunk on its own fora day,then batt went dead again,this time it won't jump off. It wants to crank but won't turn over.
not sure what you said but.
seems the battery is discharging,? 12.6v is fully charged,
own a voltmeter?
try a good loaned battery , does it start the car,?
i think you meant?
i can jumper cable start my car at any time. (off another running car)
but after running my car, the battery discharges and it will not crank at all. right?
this means ,the charging system on your car is bad.
if the starter cranks great, then the engine is flooded or is in great need of a tune up (sparkplugs etc)
if flooded try the super secret in the op guide, crank with throttle wide open , this magic trick cuts all fuel injection allowing the flooding
to purge away, and eventual starting.
my guess 2 is the car wont start, so you crank the battery flat
you jumper start it and it runs. (luck)
then day 2, same deal cranks ok but wont start.. ever tune up the engine?
Feb 08, 2013 | 2007 Suzuki Forenza Sedan
Onan Cummins 4.0 KY-FA/6747 RV QG 4000 EVAP 4000K C.A.R.B Compliant G Logo
160 people viewed this question
Top Onan Electrical Supplies Experts
Lawrence Oravetz
Jeff Hogancamp
Jeff Hogancamp
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
