Question about Sharp EL-520X Advanced Scientific Calculator White BP package of 5
My calculator shows a1 how to fix back to normal
How to calculate an average on a cell by cell basis ?
In cell B1 put the formula =AVERAGE(A$1:A1)
Copy the formula then paste it into cells B2 through B5000
You can use any other column, of course.
Jul 22, 2014 | Microsoft Excel Computers & Internet
How do i calculate a difference in a percent?
If the value in A1 is 100, and the value of A2 is 120, then the formula =(A2/A1)-1 will return 0.2. If the cell containing the formula is then formatted to display as percentage it will show as 20%.
Dec 13, 2013 | Microsoft Excel for PC
How do I get the numbers to appear normal. They are showing as expontential figures i.e. 1.6859 04?
To switch out of scientific notation and get back to fixed decimal notation, press the f key followed by the number of digits you want to the right of the decimal point. For example, to get the 12C to show dollars and cents, press f 2.
Dec 21, 2010 | HP 12c Calculator
How to calculate an amount in cell up to a constant amount
Lets say you want Cell A1 is the number that you want to determin which column you want it to go in...try this formual you might need to tweek it or message back and tell me what you need ----First Column----- =IF(AND(500,000>=$A1,$A1>=0),A1," ")
----Second Column----- =IF(AND(2,000,000>=$A1,$A1>=500,001),A1," ")
-----Third Column---- =IF(AND(5,000,000>=$A1,$A1>=2,000,001),A1," ")
so this way it will only appear in the column that it fits in and you can replace A1 with the formula
Jun 25, 2009 | Microsoft Excel for PC
Show two decimal places
Input the following and try:
  1. Press 2ndF and . the point button. This changes the screen to FIX DEG
  2. Press 2ndF +/- 2 Answer shown is to 2 dec. pl.
  3. If you want it to 5 decimal places, Press 2ndF +/- 5 answer shown is to 5 d.p. and so on
For normal, just take calculator out of FIX so just DEG shows.
Couldn't find you a YouTube video, so text will have to do.
crimsonnightt@hotmail.com
Apr 01, 2009 | Sharp EL-738 Scientific Calculator
Calculation of end date in format dd/mm/yy
Assuming you put the start date in cell A1, put this formula:
=DATE(YEAR(A1),MONTH(A1)+15,DAY(A1))
in the cell where the result wanted to be appeared.
P.S.: If this information was helpful, please rate this solution.
Mar 12, 2009 | Microsoft Office Excel 2003 for PC
Microsoft Excel Calculation
for example if your numbers are in cells A1, B1 and C1
=MIN(A1:C1)+MEDIAN(A1:C1)
only works for 3 numbers as you requested.
Sep 01, 2008 | Microsoft Excel 2000 Step by Step...
Formula for calculating the days beween months
for example, cell A1 has date (01-01-2008) and cell A2 has current date (08-24-2008) and cell A3 shows total days, is that you want to know? if yes, apply formula as under...
cell A3......(properties set as General to show digits)................ =SUM(A2-A1)
Aug 25, 2008 | Microsoft Office Professional 2007:...
Multiple arguments in excel
Okay, here's a possible solution--based on my interpretation of your problem.
Suppose you have some value in cell B1, and the month (either Jan, Feb, or Mar) is stored in cell A1. The formula in C1, which performs calculations based on which month appears in A1, is as follows:
=IF(A1="Jan",B1*0.25,IF(A1="Feb",B1*0.3,IF(A1="Mar",B1*0.4)))
In this example, the value in B1 is multiplied by .25 if the month is Jan, by .3 if it's Feb, and .4 if it's Mar.
Nov 09, 2007 | Computers & Internet
Sharp EL-520X Advanced Scientific Calculator White BP package of 5 Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
