Question about Casio TE-2200 Electronic Cash Register
My TE 2200 register keeps saying wrong mode except when in x1 mode. However the drawer will not open at all on any program even x1. How can I get the drawer to open or get this error to go away. I hav
Need to open drawer
flexion1
  • 737 Answers
SOURCE: how to program tax rate for te-2200
Hi. If you bought it new then your dealer should have set all of the system options for you so it is strange that the tax is not programmed. Normally you would only need to set the rate when your tax rate changes. Has it been calculating tax at all? Did it come from your dealer with a standard program in it?
Posted on Nov 27, 2008
flexion1
  • 737 Answers
SOURCE: Need free programming manual for Casio TE-2000 cash register
Hi. I don't have any downloads, but I know this model, so I can help with programming.
Mark
Posted on Dec 24, 2008
  • 202 Answers
SOURCE: CASIO TE2200 Error E010 while drawer is closed
This type of problem is normally caused by a switch. When the drawer opens, the switch closes and the machine goes into 'drawer open' mode to prevent another transaction. The switch or the switch activator has probably failed.
Remove the entire drawer assembly, meaning everything that comes out when the drawer is opened. Use a flashlight and look at the inside rear of the drawer opening to see if you can see the switch. It may be a lever or a button and it may be in line withe the drawer or in may be off to one side. When it is located, try to press on the button or lever. If you can and the machine goes back to 'normal mode' the problem will be identified and you will know that the switch is good. Now you need to locate what actuates the switch to see why it is not making contact. Look on the part of the drawer that should come in contact with the switch. If a small, thin piece of plastic has broken off, tape a small piece of a hard substance in that area. Close the drawer to see if the 'open' message goes away. If id does not, try a thicker piece. Repeat until the 'open' message goes away. When that happens, glue the last piece in place.
If the 'open' message does not go away when the button or lever is press, it indicates that the switch is bad and needs to be replaced. Most of these switches make contact when the button or lever are not pressed. In the short term you could locate the switch and disconnect one wire. That would simulate the button being pressed. You would just need to remember to not start another transaction until the drawer is closed.
Good luck, and please let me know how it works out.
Posted on Feb 22, 2009
flexion1
  • 737 Answers
SOURCE: Casio TE-2200 Error 037
Hi. Try this:
Turn key to program mode.
0
CASH
SUBTOTAL
SUBTOTAL
0
CASH
SUBTOTAL
Then turn back to REG mode and try it.
Mark
Posted on Apr 02, 2009
jackcity
  • 33 Answers
SOURCE: I am trying to program department keys in the
If you see the machine shows "PGMX", press [Subtotal] [Subtotal] & it will stop printing after a few seconds.
Posted on Sep 28, 2009
Error mode x1
Press subtotal to exit whtever you were doing and then turn your key to Reg and operate
May 22, 2014 | Casio TE-2400 Cash Register
Casio te 2200
Hi Good Day!
Before you reprogrammed it, check everything first,
if there is a reset setting, try to use it before you reprogramming it.
Mar 26, 2014 | Casio Parts Cash Register PC Desktop
Brand new te 2200 and it will not register anything?
I suspect the cable from the cash drawer is plugged into the wrong port.
Dec 13, 2013 | Casio TE-2200 Electronic Cash Register
How reset the cash register TE 2200
Are you trying to reset the daily report?Try turning key to Z1 then press CASH button
Dec 13, 2011 | Computers & Internet
Hi, I have a Casio TE-4500F and am having problems configuring the clerk interrupt function. If I Iog into the register using one clerk number say 1 - CLK#, as soon as I have pressed a PLU key to start a...
Are you new balancing before you try to log the second clerk on? Make sure you don't have the check tracking selected. You can use interrupt or tables, but not both.
If anyone is looking for a Casio TE-3000, 4000F, or 4500F manual, c-tech can help
TE-3000S operation manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_users_manual.html
TE-4000F, 4500F operation manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-4000F_and_TE-4500F_users_manual.html
TE-3000S, 4000F, 4500F programming manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_and_TE-4000F_and_TE-4500F_dealers_manual.html
Oct 19, 2010 | Casio Parts Cash Register PC Desktop
Casio te-2400 cash register- making transactions
Try this: Turn key to program mode 0 CASH SUBTOTAL 3 SUBTOTAL 0 CASH SUBTOTAL
This should remove the preset amount from the CASH button. Now it should work normally when finishing the sale.
Now turn back to REG mode when entering the price, DO NOT use a decimal, so type 2000 for 20 dollars. Now press a PLU (item) button. SUBTOTAL Type the amount received (NO DECIMAL, so 5000 for 50 dollars) Press CASH Change should be displayed, and drawer open
Looking for a manual for a Casio TE-2200, TE-2400 cash register? Go here:
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Jul 10, 2010 | Casio Parts Cash Register PC Desktop
My casio TE2000 elec cash register, after I turned my key to PRG ( program ) and pressed 'total' key, it said V.4137 INIT....1 , does that meant it no longer usable this register?
Seems like u need to re-program ur Cash Register...
before that, Please try...
1. Key turn to OFF
2. Keep pressing [Receipt Feed] button
3. Key turn to PGM
4. Release [Receipt Feed] button
5. Press [Subtotal]
6. Key turn back to REG & try to use
Mar 02, 2010 | Casio TE-2000 PC Desktop
On the TE-2200 casio cash register, the reports on
I've never heard of this happening.
Is the rest of the machine running in english (REG mode)?
Oct 03, 2009 | Casio Parts Cash Register PC Desktop
Hi. Try this:
0
CASH
SUBTOTAL
SUBTOTAL
0
CASH
SUBTOTAL
Mark
Apr 02, 2009 | Casio Parts Cash Register PC Desktop
Casio TE-2200 Electronic Cash Register Logo
70 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
