Question about Car Audio & Video
How do i hook my 2 15" memphis mojo to 1ohm - Car Audio & Video
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
  1. For that wiring all you have to do is wire all four positives together into one wire. And all four negatives together into another wire then back to the amp check with a meter to make sure you have the right impedance this will only work if your speakers are dual 4 ohm. Otherwise you end up with 2 ohms.
Posted on Nov 30, 2014
2 Suggested Answers
  • 58 Answers
SOURCE: where can i get a mojo 15 reconed
You'll find out it will cost you way more to rebuild the woofer than to replace it.
Posted on Jul 30, 2010
Car amplifier just shut off and goes on and off when it wants
Driving the amplifier too hard causes it to go into protect mode to prevent damage. The amp periodically recovers and operates normally until the next overdrive peak hits it.
Apr 21, 2014 | Clarion Car Audio & Video
What would the best way hooking up a 15" memphis dual voice coil sub ran with a 1000 watt memphis d amplifier??
If the amp is a 2 channel I would hook up each voice coil to a different channel. Also, make sure you hook your amp up as close to the sub as possible. With a sub that size you need to eliminate any delay in signal transfer because the sub is so larg.
May 02, 2011 | Car Audio & Video
Where can i get a mojo 15 reconed
Jul 29, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Whats the best way to hook up my L7 10''
Hello ereza25,
The best way depends on what amp you are using to power the sub. With dual 2ohm voice coils, you can wire to either a 1ohm or a 4ohm final load. If you are sure that your amp is stable down to 1ohm, that wiring will provide the best power to the sub. But if the amp is not rated at 1ohm (many aren't), then the 1ohm wiring will result in overheating and possible damage to your amp.
The wiring diagrams are here. Hope this helps.
Jun 28, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I want to hook up my 2 quad coil woofers to a 1ohm amp but
I would look up "series" and "parallel" wiring on the net. Parallel will lower your ohms, which is good- especially for you since your amp is 1ohm. use 1 channel of your amp (unbridged...bridging an amp could increase output, but will Raise the ohms) connect the positive terminal with a wire that goes to the positive on your first sub, and from there, connect a wire from that same positive terminal to the positive terminal on your second sub. do the same thing with the neg. wire. This is called parallel wiring.
Mar 22, 2009 | X-10 Memphis 15-PRC41 Power Reference 4" x...
Soundstream rub 500-1 mono....
U need to make sure your subs are wired correctly. And u need to make sure all your speakers are at the same ohm load. If u hook up two subs on one channel and two more on the other one u need to make sure that your subs are all 2ohm or 4ohm subs cause if u got two 4ohm subs ran parrallel then u will have a 2ohm setting and if both of them are 2ohm subs them your load will be a 1ohm load witch could harm your amp unless its an 1ohm stable amplifier.
Nov 21, 2008 | Soundstream RUB500-1 Car Audio Amplifier
Car Audio & Video Logo
64 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
