Question about RTO PasLode 900420 Impulse Framing Nailer
Why want my paslode sink nails all the way nto the wood
    Top Expert:
  • 2,044 Answers
Air Pressure, Worn Spring
Posted on Nov 07, 2014
  • 14 Answers
SOURCE: nail gun
have you activated the fuel cell by pressing the black nozzle down onto the cylinder?
Posted on Aug 04, 2009
rowdy45176
  • 2176 Answers
SOURCE: Paslode cordless nail gun which way does the
chamfer side goes towards the nails/magazine
Posted on Aug 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: nail comes out another hole
are you using the right nails and are they inserted properly if this is an angle gun? Also look for a jammed nail that might be causing this. look at the magazine bolts to make sure they are tight. You can go to Paslode.com for the owners manual and troubleshooting guide.
Posted on Sep 20, 2009
  • 67 Answers
SOURCE: will the paslode 900420 discharge two nails at the same time.
Stick with the paslode brands nails... the money you save using other brands is off-set by higher maintenance costs and tool down-time
Posted on Sep 13, 2010
taylor2745
  • 3 Answers
SOURCE: the fan on the paslode frame nail gun won't shut off any advice
I left the unplugged battery in the nailer and went to nail again later. The battery fell to the floor and broke. Unplugging isn't a good answer. I replaced the molded circuit, but the fan still runs whenever the battery is plugged in.
Posted on Oct 10, 2014
Paslode 18 gage finish nailer wont sink nails all the way
How old is it. Check the nail drive area to see if it is sticky etc. You may have to take it apart to fully check that out and/or to clean it and lube it. TRY spraying it with WD40 first.
Sep 12, 2014 | Omega Paslode 901000 Impulse Cordless...
Paslode im250
There should be a depth adjustment on the gun. This allows you to control how deep the nails sink. The adjustment is usually on front face of gun and just above the tip. You might want to contact paslode to see if they can give you any ideas .
Feb 27, 2014 | Tools & Hardware - Others
Paslode framing nailer: compressor powered, hisses but will not shoot nails, appears to be in the sliding mechanizism that touches the wood first before it will shoot, help
I've used paslode for years and whenever there was a "hiss" of air and no fire- it was o-rings- When were the o-rings changed last? And how do you know they are in 'good shape'? You can't tell by just looking at them. If that isn't the problem then I can't help. Just as an aside- do you oil the gun (down the air intake nipple) every time you use it? Lack of oil will wear out o-rings fast. Sorry if this isn't overly helpfull but most gun problems are o-ring or seal related unless you've worn out or damaged a mechanical part.
Feb 10, 2013 | Air Tools & Compressors
Paslode 900600 Trim nailer not sinking nails
The firing pin can be completed or part of it crooked worn and can have a little burr on its way and stuck in the cylinder somewhere o-rings worn and hardened, have a tilting piston on the firing pin somewhere in the cilinder
Jul 27, 2017 | Air Tools & Compressors
Paslode cordless fires nail but doesn't sink all the way.
The manual give clar instructions on how to adjust this...
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Mar 04, 2011 | RTO Paslode 902000 IM250 Ii Cordless 16...
Can i use full round head 3-1/2 passlode nail in this nailer
The FC350A uses a 30- to 34-degree collated clipped head nail which is very similar to the Paslode 34-degree round head nail. Paslode's nails are unique because the round head nails collated very close together and the head of the nail is offset to the shaft unlike Porter Cable full round head are further apart and the head is centered on the nail. What does all this mean? The Paslode round head nail may work however the driver will deliver the blow off center to the shaft of the nail, This could cause the nail to bend as it enters hard wood and possibly jamb the gun. You should be able to exchange the nails (with small restock fee) at a major fastener store (not Lowes or etc. ) with out having purchased them at location because the Paslode nails are very popular and with todays economy the store will gain a new customer. If however you would like to try using the nails, try the following. Remove the head of the gun to expose the driver. Install the nails as usual and with **** of small hammer quickly and firmly push driver all the way down the cylinder to see if nail is easily pushed out of bottom of nose. (You can push driver back up with long thin screwdriver or allen) If successful, replace head and connect to air however lower pressure to 40-50 psi and nail into soft wood increassing the pressure little at a time with each test untill full pressure around 90-100psi. Good luck
Jul 19, 2010 | Porter Cable Cable No. FC350A Clipped Head...
Paslode nail gun isnt firing every time, remove battery, nails etc... and it will fire 4-5 times before stopping
Cant help really but I strongly advise you not to fire the machine under any circumstances without nails and a piece of wood to try it on. tremendous damage to the mechanism can result.
Jun 15, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
Aug 11, 2009 | RTO Paslode #650027 2500CT Placement Nail
Paslode 5350/90S PM Powermaster Bends nails over
USUALY THIS IS CAUSED BY TO LOW OF AIR PRESSURE(NEED AT LEAST90-100PSI)OR NAILING INTO SEASONED HARD WOOD SUCH AS OAK,OR THE WRONG DEGREE PITCH OF THE COLLIATED NAILSHOPE THIS HELP'S.PLEASE RATE THIS .
May 16, 2009 | Air Tools & Compressors
RTO PasLode 900420 Impulse Framing Nailer  Logo
76 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
