Question about Delphi 1985 - 1988 Ford Ranger Fuel Pump Strainer FS0026 Ford Fuel P
Why does the fuel pump on 1993 ranger not shut off when switch is in on position
  • 5 Answers
It should energize the line and go silent. You may have a bad valve switch and it doesn't build pressure
Posted on Nov 07, 2014
Why does the fuel pump on 1993 ford ranger with a 4.o engine not shut off when switch is in on position & engine not running. takes ether to start it & then it floods REAL BAD.so what shuts th
You need to check fuel pump relay. Usually located under hood and I believe pass side fender well. That's odd for pump to run all the time unless relay has stuck on or has been jumped to run. (By that I mean someone has wired in run position) the computer usually grounds relay to turn on fuel pump
Nov 29, 2014 | Ford Cars & Trucks
The Fuel Pump Relay is located: Under hood, driver side, front side of shock tower, rear of battery, mounted in fuse/relay box
Nov 07, 2014 | Cars & Trucks
Intire fuel system shut down put new fuel pump on it wont come on injecters wont fire either shut off switch is on
On those trucks there is a Fuel system safety switch. Usually under the kick panel of the passenger's seat.
Apr 03, 2011 | 1993 Ford Ranger SuperCab
No power to the fuel pump
Your inertia switch is located in the right hand kick panel at the top, hard to reach with panel on, you can check it to see that it is in fact pushed in, but they sometimes burn out in this position, try using a jumper wire across the connections of the inertia switch and see if your pump runs, if so replace the switch, try the same for your ranger. Hope this helps, let me know
Dec 09, 2009 | 2004 Ford F150
Cranks but won't start,new fuel pump,no power going to pump
look at inerata reset switch check for power at the switch
Jun 23, 2009 | 1993 Ford Ranger SuperCab
Ranger fuel problem
There is a fuel cutoff switch on the passengerside floorboard, towards the right kick pannel, there will be a little red button on top of it, check to see if that is tripped, also when you turn the key to the on position listen to see if you hear the fuel pump prime up, just a short buzzing noise from the underside of the cab, if you dont hear it, that is a good indicator that your fuel pump maybe bad, i would also check the pressure at the fuel rail, chrome or black colored bar located near the fuel injectors.
May 05, 2009 | 1993 Ford Ranger SuperCab
1993 ranger 4 cyl.runs fine then wont restart for couple of hours
lisen for the fuel pump to run when it acts up. if u cant hear it then replace the fuel pump relay
Dec 21, 2008 | 1995 Ford Ranger Supercab
Delphi 1985 - 1988 Ford Ranger Fuel Pump Strainer FS0026 Ford Fuel P Logo
Top Delphi GPS Experts
Vernon Taylor
Are you a Delphi GPS Expert? Answer questions, earn points and help others
