Question about Roland CUBE Street Amp Combo
Roland street cube won't power on due to battery acid leak
I put some poor quality batteries in it on the weekend and returned to it today after zero usage to find that they had spewed frothy acid all over the battery compartment. I Removed them, wiped it down then re-inserted some new batteries. The thing wouldn't switch on so I then tried the mains power which also yielded no joy. Any ideas? Has acid got into the thing itself? Is it just a blown fuse? Cheers guys.
    Habit-Forming:
  • 135 Answers
Make a thick past of baking soda and water. rub it on the corroded parts. after a very short time it should clean up the contacts.. make sure to dry all the parts when you're done.
Posted on Jun 06, 2015
    Top Expert:
  • Roland Master
  • 3,107 Answers
Most likely the acid ate the internal power supply, but if you can dis-assemble it and clean any trace of gunk with a toothbrush and electronic cleaner, including the fuse and it's contacts, maybe you'll get lucky.
Posted on Nov 12, 2014
2 Suggested Answers
rabbitbrains
  • 575 Answers
SOURCE: hello my roland street cube
That is the first thing to check. They are most likely inside the circuit board. Remember to replace them with the same voltage and amperage ratings.
Posted on Apr 30, 2011
Testimonial: "thanks...."
My Roland Street cube amplifier has a bad speaker- where can I find a replacement speaker?
Rubber cement is an excellent for minor speaker cone damage but if you feel that a replacement is required, try MCM Electronics online. They carry lots-o-speaker replacements. Be sure to match wattage and impedance (ohms) of the speaker though as these are important spec's.
May 21, 2014 | Roland Cube-st Battery Powered Amp Cube...
My roland cube street starts making this really weird loud noise
Hi, Quick Check. Very often the input socket which is soldered directly to the circuit board, will have a broken solder joint. This is common on a very large amount of equipment. Try waggling the plug about and seeing if the noise comes and goes.
Easy fix, re-solder joint. Permanent fix, connect socket to board with flying leads, or fix socket to board with hot glue or epoxy resin.
All the best, Chris the Fader.
Mar 23, 2013 | Roland CUBE Street Amp Combo
Roland cube street water damage repair
What part of it got wet will determine the course of action.
If the whole unit were submerged, the unit may prove more time consuming to try to fix than to locate a used one. However, I have salvaged imersed laptops before. the procedure is not much different- make sure the unit is as dry as you can possibly make by blowing a fan on it for an extended period of time.- Days.
Once dried, use some contact cleaner on the jack contacts and interupts, any manual control and any switch.
You can then apply power. If nothing lights up, check and replace fuses as needed. Also check the power supply board for failed caps or rectifiers.
Once the power supply is known to be functional, systematically check the LCD display and the aspects of the amp that it controls. This board will be the most vulnerable and most likely to be the source of most issues you will encountr.
If the display survived intact, and amp does nto work, apply a signal to the inputs and trace the signal through the amp with a set of headphones set up with test prods. The problem will be where the signal stops.
Apr 26, 2012 | Roland CUBE Street Amp Combo
Roland Micro Cube Amp fuse blew out. How do you fix it?
have a look here:
http://www.ehow.com/how_8698510_fix-roland-cube.html
although it doesn't mention the fuse you will probably find it. Sometimes there is a fuse access on the outer case.
Jan 11, 2012 | Roland Micro Cube Battery Powered Amp...
Hello my roland street cube won't power on, either with dc or batteries....adapter working .could a fuse be blown inside circuitboard? thanks
Feb 13, 2011 | Roland Cube-st Battery Powered Amp Cube...
The unit is in excellent shape, not used much and has been kept in the oringinal box. I got it out today and the power won't come on? I put brand new batteries in it and still no power. It has been...
Check for corrosion on battery contacts. If this unit can use an AC adapter, often the switch contact in the power plug that connects the batteries when adapter is removed gets bent and fails to connect the batteries.
Dec 19, 2010 | Roland Boss Dr670 Dr Rhythm W Bass Sounds
The display of my roland XP-80 is Zero, & theres no pragrams or voices, patches display... & the worst is there`s no sound because there is none in the display Pls. kindly give me an advise thank...
The procedure at this link shows you a battery replacement procedure that should work for you:http://ztup.com/Roland-D110-Battery-Replacement-Guide.htm You will need to design new user patches if you didn't back them up.
Jul 06, 2010 | Electric Music
Roland CUBE Street Amp Combo Logo
112 people viewed this question
Top Roland Music Experts
Vito Vacirca Jr.
Rabbit Brains
Rabbit Brains
Matthew Spark
Matthew Spark
Are you a Roland Music Expert? Answer questions, earn points and help others
