Question about Ubisoft Cold Fear
<!-- from fixya rte -->Cold fear has stopped working - Ubisoft Cold Fear
Gas pedal sticking
spray wd40 on both ends of the throttle cable-at the peddle and at the throttle body-penetarting oil displaces water which may be causing the freeze-up- cheers Denny
Nov 26, 2013 | 1998 Isuzu Trooper
Cold fear has stopping work
Try using 3d Analyzer . Run the gama with 3d Analyzer and check "emulate HW TnL caps" and "emulate pixel shader caps" . check force SW TnL and if it doesn't works your pc/laptop/netbook just can't handle the game requirements. I have the same issue here.
Aug 11, 2013 | Ubi Soft Entertainment Cold Fear for...
What does this mean?
Water vapour formed during the combustion process from water in the air. More noticeable on a cold engine on a cold morning. If you have fears of something more serious have a cooling system check done to test for head/gasket problems.
Apr 27, 2013 | Cars & Trucks
Starclima air conditioner
I have two sayonara starclima air con units hot and cold air in our house in Denia Spain. Both units work well but have only got two remotes, one is broken completly and the second one works when wiggleing the batterys. contacts are corroded and I fear this remote will fail soon. Can I purchase new remotes and how do I program them. I suggest the machines are probally 15 years old.
Jeremy
Jun 20, 2012 | Boating
A/C conpressor will not work
due to water in the a/c unit the bearings seize up ,I had a ford xlt which did that trick and burnt out the belt with the engine trying to turn it
Jul 05, 2010 | 2000 Saturn L-Series
Maytag MSD2556AEW; Fridge and freezer not cold
Without actually putting gauges on the system to see what is really going on, I would say that your compressor has failed. There is a good chance that it is something inside that has broken. Turning it off and back on will give it another life sometimes but like youexperienced it is usually short lived.
I assume that you have checked that the condenser fan is running underneath the fridge. Also that the condenser coils are not completely plugged with dirt. These things can also make your firdge od wierd things...
This should give you a couple of things to checkout, but I fear that the compressor is bad and you will need to replace it or get a new refrigerator. If you choose to replace the compressor get a full price quote before the work is done, as it may not be worth doing if you have an older refrigerator.
I hope that this helps you to solve your problem.
Thanks for using Fixya!!
Heatman101
Nov 25, 2009 | Maytag MSD2756G Side by Side Refrigerator
02 Liberty having cold flashes!
1st check the coolant level. If it's low, it won't circulate thru heater core, and result is little or no heat. Let me know what u find, we can continue.
Dec 09, 2008 | 2002 Jeep Liberty
Display freezer
sound like your compressor ain't running. also you can try putting the thermostat on the highest number and see if there's cooling if not, suspect a defective relay/overload or capacitor.
if you see any mechanisms on the line with an button press it should restart the system.
Apr 19, 2008 | Master Bilt (DD26CG)
Graphics card
In order for Cold Fear to run properly, your PC must meet or exceed these minimum requirements:
Opertaing System: Windows 2000 / XP Only
Processor: 1 GHz processor minimum, (2 GHz recommended)
RAM: 256MB RAM minimum, (512MB recommended)
Video Card: DirectX 9 compliant 64MB (128MB recommended) see supported list *
Sound Card: DirectX 9 compliant
DirectX Version: DirectX 9 included on disk
DVD-ROM: 8X or better
Hard Drive Space: 2.2 GB
Peripherals: Mouse, keyboard, Windows compliant game pad.
* Supported Video Cards at Time of Release
Nvidia GeForce 3/4/FX/6 series (GeForce 4 MX not supported)
ATI Radeon 8500/9000/X series
These chipsets are the only ones that will run this game. Laptop versions of these chips may work but are not supported
NOTICE: This game contains technology intended to prevent copying that may conflict with some DVD-RW and virtual drives.
Also, make sure that no other programs are running.
Dec 09, 2007 | Computers & Internet
Ubisoft Cold Fear Logo
111 people viewed this question
Top Ubisoft Video Game Consoles & Games Experts
Mishan Kasiparsad
Josh Hannegan
Josh Hannegan
Level 1 Expert
Are you an Ubisoft Video Game Console and Game Expert? Answer questions, earn points and help others
