Question about Home
<!-- from fixya rte -->What do I turn to get the water hot. - Home
    Problem Solver:
  • 17 Answers
Sounds like the hot water valve is turned off, If you are in A House with A basement go down and touch the pipes in that location and see if you can find A hot one . Then follow it along until you find A valve.Put your hand on the other side of the valve and see if it is hot be careful they can be very hot if it is hot continue along to the next valve and so on. If your in an Apt there should be A valve under your bathroom sink turn it on.This should be your first step in A House or Apt.
Good luck
Posted on Nov 07, 2014
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
I cannot figure out why my hot water no longer gets hot. I unplugged my timer 3 years ago and never had a problem. Now, no hot water unless timer is on and circulating.
Best solution is to remove the circulation-system crossover located under sink and see if problem is solved.
After removing crossover piece, try hot water tap.
Another way to check if this is the problem: Turn off cold water shut-off located above water heater. No need to turn off power or gas to water heater. Now, no water should flow when you turn on hot water tap because hot is turned off.
Open hot water side of double handled faucet. If water still comes out the hot side, then crossover is the problem.
After removing Taco crossover, you can still have the problem if a single handled faucet has the same type of crossover issue.
Repeat test to see if water comes out of hot side when water to water heater is shut off.
If water still comes out of hot side, then put ear against each single handled faucet and see which one has sound of moving water. That will narrow down the suspects.
Mar 27, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
Jun 21, 2010 | Admiral AW22 Top Load Washer
Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm: Unit isn't turning on when I turn on the hot water...
Has it ever run? Is cold water going to cold water inlet? Hot out to hot water piping? Power ON? Control pad on? gas pressure correct?
May 16, 2010 | Rheem Tankless Hot Water Heater...
No hot water
more than likely tripped the high temp switch. This is made as part of the upper thermostat, replace the thermostat and it should start making hot water.
Mar 07, 2010 | RELIANCE ELECTRIC WATER HEATER
Miele CVA610 error reads expel air but when we do as manual suggests (run hot water & milk frother) no water comes out.
- Make sure that the filled water container is in the appliance.
- Turn the program selector to "On" with lighting and place a container under the hot water spout and another
under the steam spout.
- Press the hot water button, turn the steam selector counterclockwise and dispense hot water until it flows in
quiet, continuous streams.
- Press the hot water button again.
Turn the steam selector clockwise to o, to turn off the water.
If this doesn't do it for you, you are doing it wrong!
Oct 06, 2009 | Miele CVA610
Pilot light is on, but no hot water. thermostat is turned all the way up to HOT.
my gas hot water systems pilot light is on but yhe burners dont ignite when i put the hot water on,so in turn im not getting any hot water
Sep 09, 2009 | Rheem Water Heaters
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Bath tub faucet will only run hot.
if the hot comes out when you first turn on you have hooked up hot and cold backwards
Feb 11, 2009 | Home
WATER IS NOT HOT
Hi mac3493,
I'm Harvey the Master Plumber.
Your problem is: WATER IS NOT HOT
The hot water for your d/w comes directly from your hot water heater. Sometimes the pipe length from the hot water hearter is very long, so when you turn on the d/w it's filling up with the water that 's been sitting in the water lines. By the time the hot water gets to the d/w it's already full. All is not lost. When you're ready to turn the d/w on, first turn on the kitchen sink faucet and let it run till the water is hot, then turn on the d/w.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 19, 2008 | Whirlpool Dishwashers
Home Logo
43 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
