Question about Pool & Spa
BCE Clifton 6x4 folding pool table and not a spa or swiming item
Please inform me 15 minutes prior delievery
  • 3,382 Answers
Sure but you might inform the people who are delivering or who you purchased the item from.
Posted on Dec 10, 2014
3 Suggested Answers
  • 106 Answers
SOURCE: Hi! I have a Hayward Pro pool/spa system with
This is tough cause I can't see the valve setup. I have to assume they are manual valves. Normal operation probably takes some water out of the pool and spa than puts it back into both. To heat the spa, set the intake valves(the ones in front of pump) to take water from only the spa. Set the jets(valve(s) on output side of filter) to send water back to only the spa. The pool will be out of the loop. Normal operation usually has water taken out of pool and spa than put back into both. Make sure to put more water back into spa than you take out, (Adjust valve)
Posted on Apr 23, 2010
  • 990 Answers
SOURCE: pool-spa control problem
You will probally have to replace the air tube that runs from the spa to the equiptment. With time you will build up condensation in the tube and that will cause the problem you describe.
Posted on May 14, 2010
Testimonial: "thanks, i will try that"
How do I fold my intex 15' X 36" round pool liner to put away for the winter?
fold carefully youll never get back in original box wrap in a tarp
Sep 17, 2014 | Intex Easy Set Pool 15x36
Installed new pump unit starts and runs for 15 minutes then trips breaker what should I check
When the pump nears the 15 minute mark, check the housing to determine whether it is running hot. Also listen for changes in pumping sounds as something may be causing restriction.
Nov 22, 2013 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Who often should I backwash sandfilter
I would let it run for about a minute depending on how clogged it was. Our backwash drain is very visible so we can see when the dirty water has left the filter, usually about a minute or two.
Apr 06, 2013 | Hayward SAND FILTER, PRO SERIES
Could you find the compound sentense lets go to swiming pool. its hot inside the house
"Let's go to [the] swimming pool, it's hot inside the house."
Mar 13, 2013 | Pool & Spa
Does not work at all
Thank you for posting your question here on Fixya.com.
For information on getting your dolphin serviced please visit www.arrowpools.net and select the dolphin button along the bottom of the site. Complete the questionnaire and we can proceed from there. I assume by check you have verified that there is the correct output voltage across pins 2 and 3 at the socket. The remaining items are the cable and the motor unit itself. Neither is considered a do-it-yourself repair item. Providing the units serial number can help with estimating any chance of warranty coverage as well as possible repair pricing prior to sending it in for repair. If you are not in the upper East coast / mid-West area, we can refer you to a service center in your part of the country.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Apr 13, 2010 | Dolphin Maytronics Advantage
Expected life time of Sta-Rite heater?
Overall heater life is often dictated more by the pool maintenance history and chemical usage than location. Generally speaking up here in the Midwest you can expect 12 - 15 years of service life from a heater. More if it gets pampered with such treatment as proper winter covering and regular cleaning and maintenance. Far less if chemical issues arise in a pool and are not dealt with properly. A heater can fail in a matter of weeks if water conditions are that poor.
So, to answer your question; with proper installation, maintenance and water treatment I’d put it at 15 – 18 years before the heater will have spent itself from wear.
If this answer does not fix your problem or you are not sure about part or all of this post, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 23, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Dolphin pool cleaner stops after 3-5 minutes
It is usually either the power supply or the motor unit or both. None of those items are considered do-it-yourself repairs. For information on sending the unit in for service you can check with the manufacturer at www.maytronicsus.com or try us at www.arrowpools.net. If the unit is several years old and in need of repair and also the replacement of wear items such as brushes and/or tracks, it can be cost prohibitive to fix. It is helpful if you get the serial number from the units casing when you contact us or Maytronics so we have an idea of how old it is.
Nov 03, 2009 | Smart Pool Inc Dolphin Diagnostic...
Spa Pools, setting up spa pool with chemicals etc
Hi curlyall,
I'm Harvey the Master Plumber.
Your problem is: You have just brought a secound hand spa, you are woundering what sort of chemicals etc are required, there are no instuctions with it
If your spa is the type that you fill once, then you must treat it just like a swiming pool. Go to the local pool supplies store. They will be happy to set you up. Don't forget PH testing kit! Test it every day. And I prefer non chlorine chemicals. It's also helpfull to have a small submersible pump in case you need to replace the water sometime. Happy soaking!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 06, 2008 | Home
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
