How to remove program from tv screen? When l press confirm nothing happens and when l press exit it bring up installation guide on TV screen. I press exit and bring up program.
    Top Expert:
  • Televison & ... Master
  • 74,198 Answers
Try a reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Nov 07, 2014
tvtek
  • 1284 Answers
SOURCE: TV GUIDE PROGRAM
Is your TV connected via a cable box or directly to cable without a box? The guide information normally comes from the local PBS station so it is possible they don't run that service anymore.
Posted on Feb 04, 2008
  • 5 Answers
SOURCE: hitachi 42hdt79 tv guide on screen with not remember tv guide lis
Mine did/does the same,,,while in standby it also did/does produce a clicking sound intermitently.....now Pic and sound cycles on/off every 10 seconds or so. Intestingly...I could go on....but whats the point........JUNK Hitachi says "to bad" 26 months old and $800 to fix. Buy another brand........
Posted on Jun 07, 2009
  • 6 Answers
SOURCE: No power to TV
vizio does not sell their service manuals to the public.
Posted on Jul 15, 2009
SOURCE: LG TV - TV Guide Function Stuck
I have the same issue on an LG TV. The TV Guide is completely black with a small picture in the corner. It's as if the software is no longer working.
Posted on Jul 31, 2009
SOURCE: Cannot remove tv guide banner from Sony bravia 52'
Click on the display button (upper left corner) as a short term fix - it will turn it off immediately - not sure of how to permanently solve this though.
Posted on Nov 07, 2009
My universal remote control is programmed but when I press the input button it doesn't work
Make sure the TV button is pressed on the remote before trying to change the input. Please confirm if this helps.
Mar 27, 2014 | Universal 8-in-1 Remote Control, Touch...
Tip
TROUBLE SHOOTING AND SERVICE ADJUSTMENT
Troubleshooting Guide
Self-check function
When phenomena like "the power fails from time to time" or "the video/audio fails from time to time" can not be confirmed at the time of servicing, the self-check function can be used to confirm the occurrence and to limit the scope for the defective circuits.Also, when "the power fails from time to time", display on the screen can be used to confirm the occurrence and to limit the scope for the defective circuits. Any programmed channels, channels caption data and some other user defined settings will be erased and return to factory setting.
How to access
Access
Produce TV reception screen and, while pressing [VOLUME-] button on the main unit, press [SLEEP] button on the remote controller unit simultaneously.
Exit
When one of the buttons for channel selection etc. is pressed, the display returns to the normal screen.
For more check the link below
Electronics Equipment Repair Center
Ajin Gopakumar Google
on Feb 16, 2015 | Panasonic TC-19LX50 19" 1280 x 768 800:1...
The channel guide only shows no information available most of the time
sidbashford
You are getting that message because the receiver is not updating the Electronic Program Guide (EPG). Try unplugging the receiver from your electrical outlet for about 10 seconds (make sure all lights on receiver go out) and plug back in. This will cause the receiver to reboot and re-acquire satellite signal. Allow it also to download the program guide. After you get your channel back, pull up your guide, go into the future to see if it updated.
If it did not update, you'll need to run a check switch test. Press Menu on your DISH remote; should have Main Menu on TV screen. Press 6 (System Setup), 1 (Installation), and 1(Point Dish). Highlight the CHECK SWITCH button on the upper right of the screen and press the Select button on remote. On the Installation Summary screen, highlight the TEST button at the bottom of screen and press the Select button on the remote. This will initiate the test. Allow the test to complete. Once completed, exit out of each screen till you get to Acquiring Satellite Signal on TV screen. After acquisition completion, allow it to download the program guide. If this doesn't fix the problem, you may need a new receiver. I hope this helps.
Ray Calo
DISH Network
Feb 26, 2011 | Televison & Video
I cannot get 3/4 of my channels. Says i am not suscribed. I just installed a replacement receiver. Service tech to come out sat.
Hi dillis1940I see you can not get ¾ channels, I am very sorry they are not showing. Thereare some things you can check when this happens, the first thing you will wantto do is unplug the receiver for 10 seconds and then after plugging it back init will reacquire the signal and download the program guide. If after that itdid not bring back the channels you will want to press the buttons ofMenu-6-1-1 and select Check Switch and TEST, after the test completes exit outof all menus and the receiver will reacquire the signal and download theprogram guide and you will have all your programming.
Feb 26, 2011 | DISH Network Televison & Video
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Black and white tv
Hello
Your RCA, system setup has changed I thinks.To change this you have to go to the Menu option surf for system settings, and change the system reception to "AUTO".
Setup
The Setup menu allows you to access the GUIDE Plus+ system setup information. To access the
Setup option:
1. If the GUIDE Plus+ system isn't on your screen, press GUIDE on your remote control.
2. Press MENU to select the Menu Bar.
3. Use the right arrow to highlight the Setup menu selection.
4. Use the up and down arrows to select Change system settings, Review options, or
View demo.
Change system settings Confirms the settings you completed in the GUIDE Plus+
system setup are correct.
Review options Displays the GUIDE Plus+ system auto display options.
On Automatically displays the GUIDE Plus+ system when you press the ON•OFF
button on the remote control.
Off Disables the GUIDE Plus+ system from being displayed when you press the
ON•OFF button on the remote control.
View demo Runs the GUIDE Plus+ system demonstration
Note: If you have not completed your GUIDE Plus+ system setup, these options will not be available. A
screen will prompt you to complete your setup.
Getting In & Out of the GUIDE Plus+ System
To enter the GUIDE Plus+ system:
• Press GUIDE on the remote.
• Press and hold MENU for 2 seconds on the front panel.
To exit the GUIDE Plus+ system:
• Highlight a program and press OK to exit the GUIDE Plus+ system and tune
to the channel.
• Press GUIDE to exit the GUIDE Plus+ system and tune to the channel
displayed in the video window.
• Press CLEAR to exit the GUIDE Plus+ system and return to the original
channel
OK.
Dec 04, 2010 | RCA 32V420T 32" TV
My receiver wont stop recording after the program ends it will just keep recording how do i stop this
My name is Anthony Thomas with DISH Network Customer Service. This issue is usually due to a faulty program guide with "No Information Available" or incorrect information as to when the programming ends. This can be caused by a faulty Electronic Program Guide (EPG) download, a faulty box, or by signal loss. By pressing the guide button to bring up the guide, and then pressing the numbers 999 and then browse (the right arrow by select) it should give a message that says "The guide information is outdated, download from satellite now?" or something similar. Try it and see if that helps.
If not, that means there is likely a signal issue or an issue with the DVR. To check signal, Press Menu (top left corner of remote under SAT, has three horizontal lines on it), and then press 6-1-1 like you are changing the channels. That should get you to Point Dish. Check Switch will be an option on the right side. Select it and then select TEST at the bottom of the Install Summary screen that will show up. Select YES if there is a warning about TV2, otherwise it will bring up a 058 message saying to wait while test is done. The message 058 will disappear by itself. If a warning 836 message appears, your issue may require a technician due to signal loss. If not, select done to exit Install Summary, Done again to exit Point Dish, and then press the 0 button three times to select the cancel option. This should put you to an "Acquiring Satellite" Message(Attention 015/535 message) and then download the guide (Attention 330). Check it then. If it still doesn't work, the box may need replacing. If it works, you are all done! Hope this helps!
Sep 23, 2010 | DISH Network DVR-625 DTV Receiver /...
Does not allow me to record a live tv showit says: error: unable to aquire program guide information what can i do to record it?
Guest,
Are you still having problems recording live TV shows? You can try unplugging the receiver from the power outlet for 10 seconds and plug back in. This will make the receiver reboot and then acquire satellite signal. Once the acquisition is complete, a program guide download will take place. Allow the download and see if the receiver will allow you to record.
If it doesn't, then run a check switch test. Press your menu button to bring up the main menu. Press 6, 1, and 1 on the remote which will take you to the Point Dish screen. Upper right hand corner of TV screen is a button, "Check Switch". Maneuver to that button and select. You will now be at the "Installation Summary" screen. At the bottom of screen, select "Test" button. Allow the test to run. After completing, it will automatically take you back to installation summary screen. Check for any errors windows. Exit completely out of all menus till you are back to "Acquiring Satellite Signal". Allow program guide download after acquisition, then check if you can record.
I hope this helps.
Ray Calo
DISH Network
Jul 15, 2010 | DISH Network DVR-625 DTV Receiver /...
TV Guide System not working
In order to receive the TV's Guide system, the cable should be connected directly to the TV instead of the cable box if you are still using it.
How do you have the cable box connected to the TV?
Jan 24, 2009 | Pioneer PDP-5060HD 50 in. Plasma...
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
