Question about Danby DFF9102W Mid-Size Refrigerator White
<!-- from fixya rte -->Change defrost thermostat on model dff9102w - Danby DFF9102W Mid-Size Refrigerator White
  • 138 Answers
Danby, has recall on defrost timer . please try that on ,if still you like to change defrost thermostat open the back cover in freezer you can seeit
Posted on Nov 12, 2014
MASTER BILT FREESER M.N. THC27 DOES NOT GO ON DEFROST?
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
May 12, 2011 | Master Bilt Freezers
Side by side freezer frost in the back and food thawed out....the freezer is a 9 and fridge 5...What should i do? it is a couple of years old...
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Jun 13, 2010 | Freezers
The alarm went off indicating that it the temperature had risen above the recommended level for keeping food frozen and safe. However, the temperature knob is set to the highest possible level.
DEFROST PROBLEM
Feb 26, 2010 | Frigidaire Freezers
Freezer in side by side isn't freezing, but the other part is OK. What to do?
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Oct 04, 2009 | Freezers
Frigidaire side by side works fine for a couple of days then it starts to get warm, milk gets warm n ice starts melting. i unplug for a day n i when i plug it back in tll work for a couple of days...
Sep 25, 2009 | Freezers
Foster freezer keeps going into alarm: (code:DEF).
Check to see if the defrost system is working.
Sep 24, 2009 | Freezers
Sides of freezer are hotter than normal. no air sound when closing door,is this a defroster problem?
First check the condenser fan underneath near the compressor. It should run when the compressor runs.
Sep 24, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
My upright freezer won't self defrost. Frost builds up right awa
Sep 19, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Food thawed, freezer running. I moved packages from in front of air ways and turned thermostat to coldest setting & it didn't change anything, freezer still at 32-33 degrees. help
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Freezers
I have a upright freezer model number is ffu11fkodwo and the name is frigidaire commercial.The problem is that ice is building up inside the freezer.I know its an automatic defrost cause I made sure before...
It sounds like one of the defrost components is bad. Could be a defrost timer, defrost heater or a defrost thermostat. If you are at all handy you can change these parts yourself.
Aug 28, 2009 | Freezers
Danby DFF9102W Mid-Size Refrigerator White Logo
112 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
charles
Are you a Danby Freezer Expert? Answer questions, earn points and help others
