Question about Konica Minolta Minolta Bizhub C353 Copier
Konica Minolta Bizhub C353 wrinkles all papers
All papers are wrinkled. I've been looking for something being stuck somewhere and I found it finally, so this is not exactly the question. There was a paper inside the fusing unit wrapped round one of the rollers. Not visible at the first look. I had to remove whole fuser (it's hot!) and carefully remove the paper. How to do that (see the service manual page 89): 1. Open the front door and remove connector cover on the top right (the fuser is of course connected to the machine) 2. Disconnect 3 connectors 3. Open the right door 4. Remove two screws that hold the fusing unit 5. Remove the fusing unit itself, hold it tight it's quite heavy
    Habit-Forming:
    New Friend:
  • 106 Answers
Turn off & un plug your C353 tomorow much better it already cool you can easly performed the manual says.
Posted on Nov 14, 2014
"tray 1 cannnot be use currently " bizhub c-353
Utility/counter, touch details, stop00 stop01, touch system one, trouble isolate, select draw #1. set to unset. Turn main power off. wait 10 seconds, power on, go back in same procedure this time set to set. Power off again wait 10 seconds power on. ENSURE THER IS NO PAPER STUCK BEHIND THE TRAY FIRST, if this does not work get a qualified tech to look the problem
Jun 17, 2014 | Konica Minolta Minolta Bizhub C353 Copier
Why is bizhub 450 is warping the paper after copying?
Have tech come out and look at the fuser unit and check the temp setings
Apr 25, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
C0202 bizhub c353
open the draw check for any paper behind it, THEN REMOVE ALL OF THE PAPER SITTING ON THE LEFT SiDE OF THE DRAW
NOT A STORAGE AREA. for 11 x 17 paper
Feb 05, 2014 | Konica Minolta Bizhub C353 Copier
KONICA MINOLTA C353 ERROR CODE C-5102
hi tracey, 5102 is a main motor failure, it is possible for there to be paper jammed tight in the fuser unit, if not this will pretty much be guaranteed to be the main motor
Nov 11, 2013 | Konica Minolta Bizhub C353 Copier
I have Konica Minolta bizhub C353 and the paper keeps getting jammed after several prints. I just cleared code error c-3421 but it keeps getting jammed. Any help.
First Are informing the copier of the proper paper weight
? The paper weight is on the outer wrapping of the paper such as 75 g/m2 or 90 g/m2 etc. did you tell the machine that? Did you select the same weight when you sent the print job over to the machine in your print properties/perferencies ? They have to match! Check the orientation of the paper also ensue they match landscape or portrait? they have to match in the computer also.
Oct 10, 2013 | Konica Minolta Konica Bizhub C353 Drum...
Envelopes wrinkles after running through printer
Minolta does recommend stuffing the lip inside the envelope before running. But I think it only helps with jamming. Plus high humidity can cause wrinkling.
Mar 14, 2013 | Konica Minolta Office Equipment & Supplies
"konica minolta bizhub c353 error code c-4154"
"konica minolta bizhub c353 error code c-4154" help
change the chip and the imaging unit and still the same
what else I can do ??
help me please?
Thank you ...
Mar 09, 2013 | Konica Minolta Office Equipment & Supplies
Copies coming out wrinkled
Try cleaning the paper fed registration rollers with isoprophyl alcohol with fine cloth.
Dec 18, 2012 | Konica Minolta bizhub C250 All-In-One...
Konica minolta 1400
Sounds like there is something stuck (staple?) in the paper path. Having never seen this model of printer I can only guess. I would take a flashlight and look into the paper path.
Nov 09, 2008 | Konica Minolta PagePro 1400 Laser Printer
Konica Minolta Minolta Bizhub C353 Copier Logo
161 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
