I have a Bush tv 30-32 inch and everything is stretched i know you can press the button to change size i press it it comes up like its changing but it actually doesnt any suggestions ?
  • 5,499 Answers
The stretching you describe is probably the widescreen option and it is set on auto! You need to go to settings and look up screen and change the setting to suit the TV screen you are using!
Posted on Nov 07, 2014
circuitcity
  • 137 Answers
SOURCE: Random ARC Picture Size Change
What Brand TV do you have? What cable box are you using?
Posted on Dec 08, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cannot change volume or channels
Unplug the television from the wall outlet, and then replug it after 60 seconds.
Posted on May 16, 2008
jerryg50
  • 1667 Answers
SOURCE: Screen stretched on JVC AV-28WT5EKS TV
There are some parts that have failed in the horizontal scan amplifier. You will have to have the set serviced by a TV service tech to determine the exact failed parts and have them replaced.
Jerry G.
Posted on Jun 28, 2008
SOURCE: bush 26
To switch off sub-titles on Bush 26" HD ReadyTV - the following has just worked for me 19.1.10
1) Select Features on Menu options
2) Switch Analog Subtitle to Off
3) Change Subtitle Type to Hearing Impaired
Good Luck - Geoff - Newcastle
Posted on Jan 19, 2010
walesarumi
  • 6993 Answers
SOURCE: jvc 57 inch tv. kid did something to change picture size.
what was pressed on the remote is "Zoom" button, that's why the picture size is large.
So try to identify the Zoom button on your remote by pressing every button on your remote in order to get the zoom button function.
I hope you understand my message.
Good luck.
Posted on Apr 13, 2010
Hi my TV bush 50/211f not turning on still standby red light, I m change supply board still problem today I am changing main board and turn on. light change to Blue 10 sek back red and again
try this Press and hold the on/ off button Whilst holding unplug the plug from the wall Continue holding for 30 seconds Plug in the plug whilst continuing to hold the on/ off button Continue to hold for a further 30 seconds And the screen should come back on, good luck
shaun
Mar 11, 2017 | Bush Televison & Video
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
My bush tv picture has suddenly doubled in size for no reason try changing the size with 16:9 button but makes no difference and ideas
if can not get with adjustment, you may have bad component in the main board. check for leak or bulged capacitors in vertical and horizontal section.
Aug 18, 2012 | Bush Televison & Video
There is about an inch on each side of my screen that is cut off and I can't see it. What do I do because I don't have the remote? I have the Insignia NS-27HDT 27". thank you.
you need to set pix format you might try using a universal remote or check menu on tv for pix format and size like full zoom etc.
Oct 10, 2010 | Insignia NS-27 TV TV
27 inch Zenith TV Vertical too big
If you are using a DTV coverter box, you may have changed the aspect ratio with your remote control. look for a button marked "aspect" or "picture size" use that to change size.
If you have a cable box, you may have a similar button.
Or you may find a picture size adjustment on your TV remote.
If you do not have "aspect" button on your remote try going to set up menu and look for picture size.
Older TVs used to have a vertical size adjustment at the back. look in the manual.
If none of the above, you have a biiger problem with the TV internal parts needing attention
Mar 03, 2010 | Zenith C27A24T 27" TV
Bush 26" hd ready digital LCD tv brought argos today have gone into menu to turn off subtitles but every time i change chanel there they are. I know by pressing to subtitle button i can get rid of them but...
Nov 21, 2009 | Bush Televison & Video
Stuck in Standby
change the horizontal output transistor .its busted.
Aug 14, 2008 | Bush 5693D 24" TV
Panasonic TV 50 inch plasma
Dear RyanVa21;
Try changing the picture size with your set's remote, press the aspect ratio button. The remote must be the original Panasonic remote.
Please let me know if that did it.
Thanks!
Richard
Nov 08, 2007 | Panasonic TH-50PX75U Plasma HDTV
Bush LCD15TV001
press the channel up and down together the menu will come up then you can use the volume up and down to toggle on what you want.if that does not work you will have to call the tech to lift off the eeprom from out of the set and resolder it back,so that the tv could reset it self.good luck.
Apr 12, 2007 | Bush 1433BLU3 14" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
