Question about Motorola MC55/MC65 1-SLOT ETHERNET MODEM AND USB CRADLE REQUIRES POWER SUPPLY PWRS-14000-148R US AC LINE CORD 23844-00-00R AND CABLE FOR COMMUNICATION
Cloning of mc65
And I need to know how we clone this scanner
  • Official Brand Answer
  • 3,100 Answers
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Posted on Dec 17, 2014
Hello. I purchased the Thermaltake Blacx Duet-Dual Hard Drive Docking Station and am currently attempting to clone to 2 SATAs. How do I know when the cloning is complete?
Your doing a cloning of two large drives using a USB device as I have the same docking station. Cloning a 2TB drive will take some time depending on how much data and number of files on the drive being cloned. USB even 3.0 protocol is dog slow!
Give it time and do not interrupt the clone once started.
Dennis
Apr 14, 2017 | Thermaltake Computers & Internet
How can i download whatapps on c1-01
whatapps is a mobile only device app not for pcs'
Jun 13, 2012 | Computers & Internet
What is the four digit code for my pro 404 scanner
I plugged a 1/8 phono plug in the PC/IF jack over and over repeatedly and this fixed mine.
Jan 10, 2012 | Radio Shack Radio Communications
I have a pro 97 hand held cant get it out of clone mode
Your scanner is designed to automatically enter CLONE mode when a cloning cable is attached, and to exit CLONE mode when the cable is disconnected. If you do not currently have a cable connected, you will need to INITIALIZE your scanner to return it to normal operation. NOTE: Initializing the scanner will erase/delete all programmed data and return the scanner to its original factory settings. Before starting this procedure, be sure that you have a record of all programming information so that you can reprogram your scanner.
To INITIALIZE the PRO-97:
1. Turn the scanner OFF.
2. Turn the scanner ON. "Multi-system Trunking Scanner" appears.
3. Press the 0 (zero) key while "Multi-system Trunking Scanner" appears.
4. Press the 1 (one) key.
5. Press the ENT key. "Initializing please stand by" appears on the display for about five seconds.
Do not turn the scanner OFF until the initialization process is complete. When it is complete "M000" will appear on the top line of the display, and "Bank 0 Ch 00" will appear on the third line of the display.
Once the process is complete you can begin to reprogram the scanner.
Bill B
Listening in since the 60's
Oct 06, 2010 | Radio Shack Pro-97 Handheld Scanner
How do i clone my own desktop?
you just need to know all the settings and the programs you have into one ...and look for the installers and configure it in the same way ...after that set it like the other ...if it has the same specs will be just like the other ...also you might use a program that does this ...
http://blog.taragana.com/index.php/archive/top-10-hard-drive-cloning-backup-software/
Oct 26, 2009 | Dell Inspiron 1501 Notebook
Need to reprogram hand held pro 96
Radio Shack can "CLone" your scanner with one in the store - try that first to see if it will work and let me know.
Aug 19, 2009 | Radio Shack Pro-96 Scanner
MY pro-94 said on the screen lu,red or something like that !
Could the display be saying "wired"? This is what it shows when it is in cloning or programming mode. If it is showing this and there is no programming or cloning cable attached, check the programming jack to see if it is damaged.
Aug 10, 2009 | Radio Shack Pro-94 Scanner
How to clone a kenwood TK 3160
Ok. I have looked through the service manual for both the 2160 and 3160 and can not find anything that indicates that you can clone with just a cloning cable and not use software. However the 2170 and 3170 say to turn the power on While pressing the B button which yours doesn't have. Try turing on the radio while pressing any one of the side buttons.
Hope this helps.
P.S. The software is reasonably easy to get and IS much easier to use.. dan
Dec 09, 2008 | Kenwood...
Vertex 180 cloning
from my own experience, vertex customer service in california has been excellent. try giving them a call. 714-827-7600
Feb 20, 2008 | Radio Communications
Motorola GP2000
http://www.batlabs.com/gp2000.html
Cloning
These radios support cloning parameters between a master and slave radio.
Cloning only transfers the user's settings from the master radio to the slave. Things like tuning values, serial number, etc. are not changed.
To clone a master radio to a slave (target), perform the following:
    • Make sure both radios are off
    • Connect the cloning cable between the two radios through the programming port
    • Turn on the slave radio
    • Press and hold the "A" button on the master radio and turn it on
    • The master radio will display CLONE if cloning can proceed, otherwise an error will be displayed
    • The slave radio will display PROG while it is being programmed
    • When cloning is complete, the master radio will display END and the slave radio will reset automatically
    • Disconnect the radios from the cloning cable
Feb 15, 2008 | Motorola Multi Unit Charger with Cloning...
Motorola MC55/MC65 1-SLOT ETHERNET MODEM AND USB CRADLE REQUIRES POWER SUPPLY PWRS-14000-148R US AC LINE CORD 23844-00-00R AND CABLE FOR COMMUNICATION Logo
130 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
