Question about Kitchen Appliances - Others
I need enginer - Kitchen Appliances - Others
  • 3,961 Answers
I are one. Could you describe the problem?
Posted on Nov 07, 2014
Installing a used engine in my boat
This is a random choice for your engine.
You would really need the model and probably the serial to get the correct specs.
The Perkins Model AD3.152 engine used in Massey Ferguson 135 tractors built between 1968 and 1975 had the following torque specs.
45 hp
1211 ft pounds of torque at 1300 RPM
Max RPM was 2000
Feb 16, 2013 | Cars & Trucks
How to oil pan out
what engine type if you have the 3.4 engine you need a engine lift or engine support fixture you have to remove engine mount and engine mount bracket.also 3.8 engine you need engine lift to raise engine to remove engine mounting bolts.
Feb 09, 2013 | 2000 Oldsmobile Silhouette
Sugar in a gas Tank
no you have to drop your gas tank clean it out. if you didn't start then just clean gas lines. if you started it then you need a new engine. the sugar gets in the engine and turns to syrup. bad engine.
Jan 28, 2013 | Ford Cars & Trucks
Need engine diagram serious 2 engine 3800
I did not find a single page for an engine diagram but this link should provide a serious of images of engine diagrams for a 1997 LaSabre
Aug 19, 2012 | Cars & Trucks
My engine make a noise,we told me cause he was runing without enought oil in it
Anytime your run the engine without oil, you are damaging the engine. Good chance, the your engine is about to blow. You need to make sure the oil is filled properly. Is the check engine light on? If so, you need to get it to Autozone for a code scan. More then likely, you have internal damage, probably a knocking rod or piston/valve damage. Hopefully, it is not to bad. You need to try and take care of it because the engine can go at anytime. If it does, the whole engine will need replaced.
Feb 14, 2011 | Nissan Maxima Cars & Trucks
Saab 9-5 need to give alittle throttle for cold engine start
the idle air control valve may be bad or just needs cleaned out. idle air control valve acts the same as a choke. if it is messing up it will cause engine not to run right.
Jan 27, 2010 | 2008 Saab 9-5
My car was turning a corner nad my car died, the check enging light came on, does this mean my car needs anew engine?
Does not mean you need a new engine, it mean's the the ECM, the car's engine management system has detected a issue that caused your engine to stop running. Have the car scanned for the DTC code which would indicate the issue that needs to be addressed to have the engine run 100% again. It could be as simple as a dirty fuel filter that needs to be replaced. Good luck and keep me posted, be glad to answer any questions you may have.
Jul 23, 2009 | Kia Rio Cars & Trucks
Hoa do i rebuild my motor
You buy a remanufactured short block and have your heads done.
Jul 20, 2009 | 1991 Isuzu Pickup
Fuel requirements for a Stihl 131 Polesaw with the 4mix engine?
hi Ray
For your polesaw Stihl HT 131 with 4 mix engine you need a fuel/ oil mixture.The lubrication of the engine is realised through the fuel/ oil mixture(you need a superior quality of the oi for the mixture ).Buy it from an authorised Stihl dealer shop.Any other oil is not needed on the 4 mix engine.
best regards savumihai71
Dec 05, 2008 | Garden
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
