Question about Ricoh Aficio Office Equipment & Supplies
Ricoh copy, printer,fax sp100sfe all in one is showing error code sc541. how do i clear
I tried to clear by using stop/clear key, 107 and start.and it gave me maintenance mode for fax
    Master:
  • 409 Answers
This was translated from Russian by Goggle so.....read it carefully they construct sentences differently than we do...
SC-541: The temperature of fuser defined thermistor
is less than 0 ° C for 5 s.Temperatura fixing reaches + 15 ° C (
center) or + 12 ° C (at the edges) 5 times for 2 min after the lamp Fuser.
Login to the service-yellow, 107 red (hold 3 seconds) 5-810-1.
Enter SP 5-810 (SC code reset) and select "1". Then hold down the Original type key and the OK or! key at the same time (this does not require the main switch to be turned off and on).
If the reset - does not help, clean the thermistor!nail varnish cautiously take off with it, only - film does not tear ... can also cautiously cloth soaked in acetone scrub
Google Translate
Posted on Nov 07, 2014
Three in one copy, fax and printer ricoh sp100sfe is showing error sc541 .how do i clear it
this was translated from Russian by Goggle so.....read it carefully they construct sentences differently than we do...
Nov 07, 2014 | Office Equipment & Supplies
SC542 PROBLEM IN PRINTER
SC 541 is a fixing unit error, clean the thermistor and then reset the code by pressing clear(yellow) then 107 and hold stop(red) key for 5 to 10 seconds then the display change. now turn off the machine from main switch, wait for five second and then turn on the machine.
this will reset the SC541. in case if the problem exist change your thermistor and check the thermostat.
Oct 31, 2014 | Ricoh Aficio CL3500N Laser Printer
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Aug 28, 2014 | Office Equipment & Supplies
Ricoh error sc541
Fuser Error. Check fuser thermistor. reset fuser error. go to service mode press clear modes, 1, 0, 7, hold clear/stop. once in service mode turn off main power switch on the left side. turn back on.
Aug 05, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
I have nashuatec1805aficio, it have sc541 error display on the screen.I have tried clear by using yellow key then 107 then red key hold down for 3sec.after that i press 1 on SPmode display then it display...
sc541/541 is a fixing problem, check if your thermistor or thermal fuse are defective, if yes replace them or clean the thermostat/thermistor. then reset it by pressing the yellow key then 107 then red key hold down for 3sec.after that press copy sp then exit turn off machine after 10 sec on. hope this helps
May 28, 2011 | Ricoh Aficio 1035 Copier
Ricoh jp 5000 errore code message ec 5-51
Its a MP5000 right??
You have Loose connection of pressure roller thermistor.
Try this:
Press the clear mode key (yellow key)
Use the keypad to enter "107"
Old down clear/stop for at least 3 secounds (red key)
Enter the service mode (on the touch screen press "copy mode")
Exit all the way to return to the copy window.
Turn the machine off/on.
If doesn´t work you have to call technical assistence.
Feb 12, 2011 | Ricoh Office Equipment & Supplies
What does functional problem SC541-00 on a Savin copier 2035DPE
SC541 is a defective thermistor, clean or replace the two thermistors (Edge and Center) on your fusing unit. after replacing or cleaning reset the SP Code 1. On the operation panel, press Clear Mode ". 2. Use the number keys to enter 107. 3. Press and hold Clear/Stop # for three seconds. 4. On the touch-panel, press Copy SP. then turn off and on the machine
May 18, 2010 | Office Equipment & Supplies
Gives code sc541 on Ricoh 1035
Clean the fuser thermistors.For reset enter in the service mode : press total clear (yellow)key-107-clear(red)key,touch SP mode,open the front door and turn OFF the power switch.Unplugged the machine,wait 10 sec.,plugged the cords,close the front door amd turn ON the power switch.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
SC542
sc 542 is when the machine cant warm up to temperature for whatever reason usually entering service mode via clear 107 clear stop and rebooting clears the code if that dosnt work then the next step is call a service engineer
Feb 19, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
100 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
