Three in one copy, fax and printer ricoh sp100sfe is showing error sc541 .how do i clear it
Machine is showing error sc541.please can you help
    Master:
  • 409 Answers
This was translated from Russian by Goggle so.....read it carefully they construct sentences differently than we do...
SC-541: The temperature of fuser defined thermistor
is less than 0 ° C for 5 s.Temperatura fixing reaches + 15 ° C (
center) or + 12 ° C (at the edges) 5 times for 2 min after the lamp Fuser.
Login to the service-yellow, 107 red (hold 3 seconds) 5-810-1.
Enter SP 5-810 (SC code reset) and select "1". Then hold down the Original type key and the OK or! key at the same time (this does not require the main switch to be turned off and on).
If the reset - does not help, clean the thermistor!nail varnish cautiously take off with it, only - film does not tear ... can also cautiously cloth soaked in acetone scrub
Posted on Nov 07, 2014
ctf1800
  • 4402 Answers
SOURCE: ricoh photocopier 1075 code sc541
500's usually means overheating problem
contact service support from your local authorized dealer
Posted on Jan 10, 2008
Cogz
  • 1326 Answers
SOURCE: about ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Posted on Apr 23, 2008
SOURCE: printer is showing a system
I had the same problem & found the solution of HP's website. It solved the problem.
HP Website & solution:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00489814&dlc=en&product=1153494
Solution one: Reset the product
Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Nov 10, 2008
SOURCE: Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
Posted on May 11, 2009
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
Ricoh copy, printer,fax sp100sfe all in one is showing error code sc541. how do i clear
this was translated from Russian by Goggle so.....read it carefully they construct sentences differently than we do...
Google Translate
Nov 07, 2014 | Ricoh Aficio Office Equipment & Supplies
Ricoh error sc541
Fuser Error. Check fuser thermistor. reset fuser error. go to service mode press clear modes, 1, 0, 7, hold clear/stop. once in service mode turn off main power switch on the left side. turn back on.
Aug 05, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
I have nashuatec1805aficio, it have sc541 error display on the screen.I have tried clear by using yellow key then 107 then red key hold down for 3sec.after that i press 1 on SPmode display then it display...
sc541/541 is a fixing problem, check if your thermistor or thermal fuse are defective, if yes replace them or clean the thermostat/thermistor. then reset it by pressing the yellow key then 107 then red key hold down for 3sec.after that press copy sp then exit turn off machine after 10 sec on. hope this helps
May 28, 2011 | Ricoh Aficio 1035 Copier
Gives code sc541 on Ricoh 1035
Clean the fuser thermistors.For reset enter in the service mode : press total clear (yellow)key-107-clear(red)key,touch SP mode,open the front door and turn OFF the power switch.Unplugged the machine,wait 10 sec.,plugged the cords,close the front door amd turn ON the power switch.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Erro code SC541
Fuser error.
May 11, 2009 | Ricoh Aficio 450 Copier
Getting SC541 code on our copy machine. what does that mean?
It must be a Ricoh copier,and the model doesn't matter. This code is a fuser warm-up error, and can only be reset in service mode by a technician after the problem is fixed.
Mar 24, 2009 | Office Equipment & Supplies
About ricoh copier problem
Apr 22, 2008 | Ricoh Aficio 450 Copier
74 people viewed this question
k24674
