Question about Fisher and Paykel Washing Machines
What does it mean when my fisher and paykel washing machine stops mid wash cycle and starts beeping the lights that show up are 2 and 7 it's a gw611 model
  • 1 more comment
  • gospelstuff Nov 10, 2014
    Well depends is it front load or top load ? front load will be more difficult. but u have to remove the housing or top panel and run cycle to watch it spin, then listen carefully for where the noise comes from? u can inspect the balancers by observing
    if there is any residue of oil or sticky material coming out tops of them, if its a center counter balance made of cement as some are then u can inspect for cracks, u can also look at bottom where hub is braced to housing and look for any breaks, like if the metal brace has broken thus causing an inbalance
  • gospelstuff Nov 23, 2014
    let me check on ur model and get back with u? u might have a suds sensor issue?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
I would normally say a clothes balance issue but if its happening all the time. u may have an issue with the counter balance weights or rods depending on ur type of appliance. If they go bad they tend to shut down applaince mid cycle after some amount of movement or shaking. and what happen is it contantly throw machine into unbalance position
Posted on Nov 09, 2014
Testimonial: "Any advice on how to fix or check the problem out"
  • Dean Moon
    Dean Moon Nov 10, 2014
    Any advice on how to fix it
3 Suggested Answers
  • 14 Answers
SOURCE: fisher and paykel washing machine stopped
If the light that stays on when beeping is 7th from the right then the machine has a pressure transducer which is out of range, the motor controller module (electronic) will need to be replaced.
Posted on Apr 22, 2010
  • 713 Answers
SOURCE: washing machine stopped during spin cycle
Hi just read your posting.Now on the wash progress line of lights ,there will be 8 in this row.Starting from the left to the right which lights are lit.Is it the 2nd ,3rd and 7th or the 1st, 4th and 8th ---etc---?Please reply with additional information and I can help you rectify this fault on your machine.Looking forward to your reply
Posted on Jul 27, 2010
I have fisher paykel GW611 making a terrible squeaking sound when washing. It seems to be coming from under the white plastic fan like thing under the machine. Need help to get it off Thanks
Go to www.repairclinic.com and enter GW611. You will see a list of common replacement parts and may be able to view a video showing disassembly of a generic F & P washing machine.
Aug 01, 2016 | Fisher and Paykel Washing Machines
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel model no GW611 washes but won't spin nor lid locks
Sounds like the lid lock has gone bad. Check the wire connections to it and if you should need to order the lock, here is their website.
Nov 05, 2012 | Fisher Paykel EcoSmart GWL15
I have a fisher and pykel top loader model GW611, when starting on any cycle, on filling the maching the water will pause every so often and may not fill. when it decides to, it starts beeping and shows...
Your fault code is 112
Info for your fault code.
112. (01110000) Motor Current Sense Too High
This fault occurs if the Motor Control Module detects that the motor current has reached an
unrealistically high level for greater than 2 seconds. This suggests that the motor current
sense circuit is faulty.
Primary source: Motor Control Module.
Action: Replace Motor Control Module.
Oct 25, 2012 | Fisher and Paykel Washing Machines
I have lost my instruction manual. It is Fisher & Paykel model GW611 I want to know how to turn off favorites and reprogram it in again
From what I can tell, GW611 is an Ecosmart:
http://www.fisherpaykel.com//admin/pdfs//pdf_usecares/420653_US_Ecosmart_UC.pdf
There are a few different Ecosmart manuals on the Fisher & Paykel website, so you might be able to find one that matches the button shapes you have. They all seem to have the same Favorite instructions:
To set your Favorite Cycle
1. Press the POWER Button.
2. Press the FAVORITE cycle button. Hold down for 4 seconds until you hear two quick beeps and the Favorite light flashes.
3. Select your favorite cycle (eg Regular or Delicate).
4. Select the wash options (eg soak, time saver). Use Advance if you want part of a cycle (eg spin only).
5. Press FAVORITE again to store your favorite cycle.
Note: Your Ecosmart will remember your favorite cycle, or any other cycle that has been customized, even when unplugged from the wall. It is not possible to program a delayed start into the Favorite cycle.
http://www.fisherpaykel.com/customercare/userguide/index.cfm
Jul 16, 2011 | Fisher and Paykel Washing Machines
Washing machine stopped during spin cycle. now when i turn it on it beeps and has 3 lights on, 2 wash lights and the spin light. model number is GW611 excellence. fisher & paykel top loader
Jul 27, 2010 | Fisher and Paykel Washing Machines
Fisher and paykel washing machine stopped mid-cycle and beeps constantly. 2nd button in is solid green.... 5.5kg smart drive model.
Apr 22, 2010 | Fisher Washing Machines
Stops mid cycle
CHECK DRAIN PUMP AND DRAIN HOSE FOR RESTRICTION
Jun 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
140 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
