Question about Canon PIXMA MP830 All-In-One InkJet Printer
Lock switch error code
When I switch the printer on it come's up with error code "release lock switch and re start printer". when I do so it gives me the same message again. please help.
El Duderino
  • 47 Answers
SOURCE: lock switch
Hi muffin, Turn off the machine, open the document cover, and then release the scanner lock switch. You'll see it. Any other problems let me know. Peace, Dude
Posted on Nov 26, 2006
  • 8 Answers
SOURCE: pixma ip500 error message 5C00 - what does it mean?
I have the same message and print haed does not move at all.
I will pay for it to be fixed next week (after Easter) and let you know the cause.
Cheer's Steve
Posted on Mar 22, 2008
mybox258
  • 63 Answers
SOURCE: E 2 and service error 5100 on Pixma mp160 printer
You can try to clean out the printer check to see if there is any paper jammed in it somewhere
Then realighn the printer cartridges and run a test page.
Make sure that the paper tray is not overloaded
Posted on Dec 24, 2008
  • 1602 Answers
SOURCE: i850 printer error message 5100
GO ONLINE AND TYPE IN
CANON 850i PRINTER ERROR MESSAGE 5100
ENTER
ROD
Posted on Feb 04, 2009
  • 3230 Answers
SOURCE: error code 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Posted on Oct 01, 2009
Where is the "scanner lock switch" located on a Canon Pixma MP980 printer? I cannot seem to locate the switch "under the hood" so I need assistance.
The scanner lock on the MP980 is on left hand side of the scanner unit. It's closer to the hinge of the document cover and almost centered between the scanner glass and the edge of the printer. If you lifted the entire scanner unit, you won't see the switch. You should be able to push the switch towards the open lock symbol with your finger or thumb. The Getting Started guide has a pretty good picture of where the switch is in Step One. The guide is available on the product page, http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp980#BrochuresAndManuals , in the Brochures & Manuals section. The current link to the Getting Started Guide is http://gdlp01.c-wss.com/gds/2/0300001552/01/MP980_GS_EN-US_V3.pdf . After moving the switch, turn off the all-in-one. Then unplug the power cord to clear the error message from the printer's memory. After a few minutes, plug the power cord back in and turn on the printer.
If the error persists and the scanner is unlocked, the scanner mechanism may be damaged. If that's the case, your MP980 needs service. If the unit is under warranty, contact Canon. (If it isn't under warranty, you'll need to decide if the unit is worth the shipping and handling fees and the minimum $50 or so charge just to determine the problem at a service center. (That fee will be applied to the cost of fixing the printer, if you decide to have the technician continue to work on the unit.)
I hope this helps.
Sep 21, 2015 | Canon PIXMA MP980 All-In-One InkJet...
Will a flow switch stop the tub of any operation
Is the board getting power, is the control lighting up?
Do you see any error codes on the top side control?
Improper flow will give you an error code, caused by flow issues or a faulty flow switch. Make sure all gate valves are open and the water can flow freely.
If not then check your Hi Limit sensor. This is the overheat safety sensor if it fails the tub will not function at all.
Sep 23, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
Hello, I have a Canon MP810 printer and the screen shows there is an error with that number: 5020. It says that I have to unlock the locker of the scanner and then restart. I have done it many times...
I have just read it on the other forum..try this one
Error Code 5020:
Scanner lock switch locked. [5020] Release the scanner lock switch and turn the power
off and back on.
Turn the machine off, unlock the scanner lock
switch, then turn the machine on again.
Hope it helps.
Sep 09, 2011 | Canon PIXMA MP810 All-In-One InkJet...
I have a designjet 800ps 42" and send me the 79:04 error code, after this happen i change the belt and all the printheads, but it still send me the same error, it said Error Code:79:04 ...
Who told you to change the belt? 79:04 is a Firmware error.
Switch the Printer Off and wait a few minutes. Switch the Printer On again and check if the Error Code has disappeared. If the Error Code reappears, check for a new Firmware release. If the new Firmware release does not solve the problem, or if new Firmware release was not available, then contact the HP Response Center supplying the following information: - Model and Serial Number of the Printer. - Firmware release of the Printer
- The complete Error Code information, including the linefeed where the error occurred
Aug 19, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
I am having a problem with my printer. When I turn it on the copy light is on and the feed switch light and the alarm light and it says in the screen release the scanner lock switch and turn the power off...
Issue: ERROR LCD: Release the scanner lock switch and turn the power off and back on.
Solution: Unlock the scanner lock switch
The scanner must be unlocked before turning the unit on.
Turn off the power.
Lift the document cover.
The scanner lock switch is on the left hand side of the underside of the document cover.
Slide the scanner lock switch to the release mark (an open padlock icon).
Lock the switch before transporting.
Close the document cover.
Turn the machine on.
If machine still is not working repeat the power off / on cycle waiting 5 seconds in between.
Jan 25, 2011 | Canon MP830 All-In-One Printer
Error 5020 scanner lock switch will not turn off.I am using printer pixma mp810
Does anyone know how to fix error 5020 release the scanner lock switch and turn the power off & on.The Cannon MP810 Printer. Please Help!Thanks
Dec 07, 2008 | Office Equipment & Supplies
Error: Release the scanner lock switch:
The scanner lock is locked pls unlock it dude...
Mar 15, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Scanner seems stuck and causes error
you can always try to install the printer on a friend's pc as a test of the printer...do you have the install cd? if not try canon's site to download it.
Aug 10, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Lock switch
Nov 24, 2006 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
63 people viewed this question
old marine
old marine
