Question about Pool & Spa
My pacer baracuda turns upsige down on its back and stays like that during filtering
  • 2,760 Answers
Lay out hose straight as possible in water and see if hose has "memory" to twist one way or other , this causes swimmers to turn over , also ck speed if it's over (point) .5 inch per second then swimmer is set too fast , slow setting
Posted on Nov 08, 2014
4 Suggested Answers
  • 106 Answers
SOURCE: Baracuda Pacer does not work. does not do
Replace diaphragm
Posted on Jan 14, 2010
Testimonial: "It is winter here now so I cant actually go test it..but in the summer the suction was minimal and it would start to vibrate a little and then stop."
  • 106 Answers
SOURCE: I have a baracuda pacer pool cleaner and it seems
A coupe of things you can try. Either add one hose length or take one off. If that doesn't help, you can reverse the hose positions.(take the first one off, and put it last. Change all of them) Also, changing the amount of suction may help.
Posted on Apr 19, 2010
Testimonial: "thank you for your suggestion I will try this solution of changing the hoses around"
  • 333 Answers
SOURCE: The Zodiac Pacer Baracuda keeps turning on its
Probably not getting enough suction to hold it down on the bottom. Have you backwashed your filter ? Try that and see what happens
Posted on Jun 15, 2010
Baracuda pacer is moving to fast
There is a regulator available that fits on the end of the hose in the skimmer. The more suction the wider the valve opens maintaining a consistent flow through the hose. Part #W60050 about $30
Jan 09, 2013 | Pool & Spa
My baracuda classic falls on its side and stays that way being useless on the bottom of the pool. How do I solve this?
This information applies to a Baracuda G4 model only. My G4 would climb the wall at the deep end, lose suction, fall to the bottom of the pool and invariably land on its side or back.
The problem was the blue egg shaped buoy, as its called. Mine had signs of wear and there was even a hole in it. I replaced it and the G4 now works fine.
Feb 27, 2011 | Zodiac Pacer Pool Cleaner
Baracuda stopped working. it is not vibrating but
Could be a small rock or stick stuck in the diaprahm. If you pull the head you can look down both ends, use a ling stick or wire to clear or take the unit apart to find and clear this.
Aug 01, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Our cleaner works for 5-10 minutes and then does not work anymore..we replaced the diaphram, cleaned the filter, etc (G3)
Since you've already replaced the diaphragm, it sounds like a filter problem. Try acid washing the filter and see if that solves your problem. A suction gauge is supplied with the cleaner and you can compare readings when working or not. If reading goes down, it's a filter problem If it stays the same it's a cleaner problem. Could be a crack someplace on cleaner housing.
Jul 31, 2010 | Zodiac Baracuda G3 Automatic In Ground...
The Zodiac Pacer Baracuda keeps turning on its side of upside down. what is causing this?
Jun 02, 2010 | Zodiac Pacer Pool Cleaner
I have a baracuda pacer pool cleaner and it seems to run in the same direction and doesn't clean the whole pool how do I solve the problem
Apr 19, 2010 | Zodiac Pacer Pool Cleaner
Flips over
There is a float in the body of the cleaner that keeps it upright. Uour pool store will have this and can change it for you also.
Aug 02, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Baracuda G4 won't clean whole pool. goes to a corner and stays
Maybe your hose needs to be reprogrammed by unhooking and lying it in the sun for several hours.
Apr 25, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Pool & Spa Logo
60 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
