Question about Electronics - Others
I have a new 6000w power star w7 inverter, have wired it up following the instructions. I only get 39vac out which only just turns a small power saw.It will run the saw if the charger is on and connec
I have a new 6000w power star w7 inverter, have wired it up following the instructions. I only get 39vac out which only just turns a small power saw.It will run the saw if the charger is on and connected to the grid.
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: can i connect 2 inverters together?
Are you trying to tie the two outputs together? that is a no no.
Posted on Nov 24, 2011
gopakumarg43
  • 75452 Answers
SOURCE: Who can repair my Power star w7 6000/18000 48v inverter charger.
Any electronic equipment service technician can do it.
Gopakumar Gopalan Google
Posted on Jan 14, 2015
My 1500 watt cobra power inverter shows "olp" wuth nothing connected. bought a new one also 1500 watt and as soon as i turn it on shows "olp" also.
Pop is over load protection. You may have gotten a bad inverter. When you do connect something to it does it go away? If so what size wires are you using? To small a gauge wires cause all kinds of problems.
Feb 27, 2017 | Cobra Electronics - Others
My power star w7 inverter charger wont charge off genset
there are things you would need to check
1, Does your inverter charge over any other power source?
if no, your inverter input power source has a problem
if yes , then
a, check the input voltage/frequency rating of your inverter then compare it to the output rating of your gen set
i believe there would be a difference between them
use a multimeter tester{ac}
inverters reject strange voltages or high voltage to protect itself from damage
May 29, 2014 | Electronics - Others
Sunna 3000TL inverter , red led light flashing ,
Unplug the inverter, and have the outlet tested. After being unplugged for a while, the inverter should reset when it is plugged into a grounded outlet.
Nov 26, 2013 | SMA Sunny Boy 6000US Inverter, 6000W,...
I have a Power Star W7 3000w 48v inverter/charger which has stopped working,thepower comes on and goes off almost right away, no fault lights at all but a continuious beep,the manual fault finding...
Hi, I repair inverters for a living. Some of the comments here simply mystify me... The symptoms that you describe are a classic case of shorted MOSFETS. When a MOSFET dies, it usually goes short circuit and what is happening when you switch on the inverter is that the DC overload check circuitry/routine is shutting down the unit. Not to worry; Two things firstly;
1.) Warranty.
2.) Repair.
Open the case, do a sniff test, do a thorough visual check, turn the unit over without the lid on and see if component fragments drop out on the bench. Turn the unit on and observe what is happening it may be obvious, use your hearing as a diagnostic tool, have plenty of bright light and a torch handy.
Then, if you are able, check the MOSFETS with a multimeter. If you are not able to, then have some who knows what they are doing perform this. Garden IRFZ44 MOSFETS are compatible with this device.
This is not a complex device, straight forward diagnostic routines will quickly locate the problem. Try and post back here how you get on.
Feb 16, 2013 | Electronics - Others
I need to move from an old pc XP to a new pc Windows 7 I have pcrelocator 2003
Since you have the 2003 version, it may not work with W7.
One of the new features of Windows 7 is that one does not need third party software to migrate from XP to W7. On the W7 machine, just click on the start orb and type in "windows easy transfer" in the "search programs and files" box., click on same and follow the instructions to migrate from XP to W7. I've done it more than a few times without any problems.
Jan 25, 2011 | Eisenworld Alohabob PC Relocator Ultra...
I have just bought an Astrolon telescope 288 power. I've assembled it following the instructions and I can't see anything. Inside the house I can pick few images but they appear upside down rather than...
All astronomical telescopes show upside down images --- it's normal.
Stars are always points of light no matter what telescope you own. Download this star chart:
www.skymaps.com
Objects in the sky are tiny, smaller than the tip of your finger held at arm's length, try for the moon FIRST which is large. Then try Jupiter which is that very bright "star" to the Southeast after dark.
Read my tips on my profile page.
Dec 26, 2010 | Edu-Science (10166) Telescope
Im a installer of kitchen and bedroom cabinets some one at work said about a inverter instead of a generator for i havent got enough space in the van for a generator and i go onto sites without power ive...
I and welcome to FixYa. I am Kelly. If you have a single load at 1430 watts and possibly some other item using power figure your max working load at 2000W. I would recommend a 3000W inverter.
The problem your going to have with an inveter that size is a single battery is probably going to die an early death trying to keep up with it. Your prbably going to need to parallel a 2nd battery into your work vehicle.
This inverter is what I would recommend so that no matter what you did to it (6000W burst load) you are not getting it fixed or replacing it.
http://www.invertersrus.com/vec051d.html
At $329.00 it isn't cheap but you spend the money ONCE vs repeatedly.
Kelly
Apr 23, 2010 | Inverter Pure Sine Wave 1500w Inverter
My laptop toshipa A135 has died. when i push power
In this case you need to check the inverter, defective inverter will cause the following symptoms:
No Display
dim screen
Screen Flash on and Off between 1/2 to a few seconds
Actually you need to replace the inverter buy a new inverter which is compatible to the old one. Installing the inverter is easy, it does not require any technical skills. In fact, it is a lot easier then changing the I/O Card in your PC System because there is no driver ( Software) Involve.
Tools:
Philips screw driver
Small Flat screwdriver
Preparation:
Make sure your have enough space on your desk and it must be clean.
Disconnect AC Adapter and Remove Battery from Laptop Computer.
Procedures:
This procedure is based on Toshiba Satellite A105-S4284 (with 15.4 inch Screen)
Removing the front bezel on Laptop screens is easy. Usually, these screws are covered by small rubber pad; so, all you need to do is remove these rubber pad and screws. To do this procedure you can find some instructions as shown on the next few photos to the link that i can provide below.
http://www.lcdparts.net/howto/instruction/IInverterDetail.aspx?Model=A105-S4284
Good luck, thanks for using fixya
Regards
nicole
Oct 02, 2009 | Toshiba Satellite A135-S4527 Notebook
Electronics - Others Logo
46 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
