Question about Medical
I recently changed the Halogen bulb on my BELMONT X-CALIBUR TRACKLIGHT Model HLT. But the light still won't go on. The Fuses are fine.
I also tried the to swap the bulbs with another HLT... and now both don't work. What went wrong? The Bulbs are new and are the Correct Bulbs. It seems as though there is no power going to the bulbs. I have uncovered the transformer. How do I check this? What should I be reading on Equus Digital Multimeter (Model #4320)?
SOURCE: Lighting prblem
MY BRAKE LIGHTS DONT WORK. I CHECKED FUSES AND THEY WORK. I CHECKED BULB AND ARE GOOD. WHEN I TURNED MY HEAD LIGHTS THEY WORK BUT WHEN I PUSH THE BRAKE PEDAL THEY DONT.
Posted on Nov 08, 2008
SOURCE: brake lights went out, changed bulbs, checked fuse, still wont work
You have to check the brake light switch which should be around the brake pedal on the upperside.
Ones located rremove the wires tht go to the switch and jump them by using a piece of wire, thn check if the brake lights come 'on'. If they do , thn its the switch tht may need replacing or even sometimes adjusting inorder to operate.
Hope this helps.
Posted on May 10, 2009
  • 4 Answers
SOURCE: nissan almera brake lights not working,checked
Check the brake light switch under the dash at the brake peddle and make sure its working if it does not close when you depress the brake peddle the lights will not work You may hve to remove the lower cover for the dash to get at the switch
Posted on Sep 03, 2009
SOURCE: Town & Country reading light bulbs power rating
The lamp holders in my 2002 Dodge Grand Caravan are brown. The correct lamp is a PC579.
Posted on Mar 21, 2010
johnjohn2
  • 5763 Answers
SOURCE: brake lights don't work
This sounds like a bad brake light switch, this switch is located on the bracket that holds brake pedal,you can test for power at switch,also if you remove connector and jump terminals with a wire and see if lights lite, if lights light then switch is bad,
Posted on May 27, 2010
Instruction manual KuKoocooker hood light bulbs
Just look this youtube video, and it can't be more clear.
Don't forget to unplug the hood, or switch it of. Although the halogen lamps are only 12 volt. In the hood are dangerous voltages. How to replace cooker hood halogen bulb or lamp
Sep 22, 2014 | Kitchen Ranges
1979 gmc truck van no brakelights
Check your blinker switch in the steering column. I had an old Ford Galaxy that the brake lights quit working on and it turned out to be that.
Jul 13, 2014 | E92 Halogen Brakelight/Stoplight Kit for...
Fog lights don't work new bulbs
If they worked before you put in the new bulbs and not after, you may have blown the fuses. The fuses are for a 55 Watt halogen bulb. Many people replace them with 100 watt bulbs which blow the two fuses. Replace the 7.5 amp fuses with 10 amp fuses, but nothing bigger or you could damage the wiring if you get a short.
Nov 03, 2013 | 1997 BMW 328
Portable Cabinet Light, Model DCMS-10. How do you change out the halogen bulb?
most fixed halogen bulb units are either held in place with a spring around the glass or a pop tab ring around the glass, these should be carefully pried away leaving the glass to fall out, once the glass is out then bulb replacement can be achieved, remember not to touch the halogen bulb replacement with your bare fingers, use a tissue or similar as the natural oils on our skin can cause a bulb to fail prematurely refitting is a reversal of removal
Sep 21, 2012 | Cars & Trucks
How do have you change an headlight bulb?
LOOK IN YOUR GLOVE COMPARTMENT FOR THE OWNERS MANUAL. LOOK IN THE BACK INDEX OF MANUAL LOOK UP BULB REPLACEMENT. IT WILL SHOW AND TELL YOU HOW TO REPLACE HEAD LIGHT BULBS. YOU NEED TO WEAR CLEAN LATEX GLOVES WHEN CHANGING HALOGEN BULBS BECAUSE OILS FROM FINGERS AND HANDS WILL CAUSE THE HALOGEN HEADLIGHT BULBS TO OVER HEAT AND BLOW OUT. HALOGEN BULBS ARE EXPENSIVE THEY COST FROM $10.00 - $20.00 BE SURE TO WEAR CLEAN GLOVES WHEN HANDLING THEM.
Jun 18, 2011 | 2003 Oldsmobile Alero
I have two dimmer switches in the same box side by side. one goes to three pot lights, the other goes to a halogen track light. these have been working for 5 years. the lights have burnt out and been...
Sounds like the transformer in your track light. In the box where the green light is, the voltage is converted by a small transformer from 120v to 12v for the halogen lights. With the breaker off, try jumping out the dimmer going to the track light (disconnect the dimmer and connect the two loose wires from box together). With the breaker back on, if you have 120v power on the wires (black/white) going into the track light transformer (measured at the track light), and the green light won't come on, I'd say it's the track light transformer. You may have to replace the whole track if you can't get the transformer as a part.
Apr 22, 2017 | Lutron ELECTRONICS MAW-600H-LA SMART...
Hi, we have a 2001 Tiburon, yesterday our son attempted to change the high beam bulbs.After completion he tried them, both the high beams and running lights were not working.The bulbs he used were...
Thanks for the quick response. The problem has been solved. I rechecked the fusebox and found a blown 15A fuse I missed on the right side of box. Replaced the fuse and everything works fine!
Thanks again.
Dave
Dec 21, 2009 | Hyundai Tiburon Cars & Trucks
How do you change the inside light bulb in the advantium 120 mocel # sca1001hss01? The cooking is fine, the speedcook light works. I just need to know how to change the interior light
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
But bulbs can usually be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Jul 14, 2009 | GE JVM1650 1000 Watts Microwave Oven
Medical Logo
537 people viewed this question
Top Medical Experts
Andrew Taylor
Andrew Taylor
Are you a Medical Expert? Answer questions, earn points and help others
