Question about Vehicle Parts & Accessories
I have a 2004 explorer it will not crank and fule pump will not come on went to turn key on the next day there is no power the only light that will come on is the airbag?
We changed the starter and checked fuses
    Problem Solver:
  • 8 Answers
Is it making any noises? Like when you turn the key does it click once and than nothing? This could be the starter relay, starter wich you say you have allready replaced------ or does it click repetivly untell you you stop turning the key? This is usaly the battery
Posted on Nov 07, 2014
Testimonial: "it does not make noise it dont do nothing"
Cranks over but wont start
fuel pump went out just like mines
Feb 01, 2013 | 2002 Pontiac Montana
Fule pump bad??
If you pressed on the valve and no fuel came out that means there is no fuel getting up To the fuel rail. The reason could very well be a bad fuel pump, no power to the fuel pump or a bad groundor simply out of gas. Check your fuses and relay. Also with the car in park and with the parking brake applied bang on the tank while someone tries to start the vehicle if it starts replace the pump. The fuel filter should be replaced as well
Mar 13, 2012 | 2004 Oldsmobile Alero
Hard starting--like not getting gas
probably fule pump check valve not keeping pressure after shut down. Try turning key to ON and wait 5 seconds before cranking. If this helps, it is the check valve. Replace pump in tank.
Oct 24, 2011 | 2001 Ford Explorer Sport
My 2004 ford explorer wont start, theft light on dash blinks fast when key is turned on to start. all dash lights come on, just nothing to the starter. hear a clicking under dash fuse box thats it. what...
got a 2004 ford explorer it wont start but it turns over put fuel pump starter evap canister and purge valve it was broke,and a battery fuel filter,tac system and it still wont crank
Mar 27, 2011 | Ford Explorer Cars & Trucks
CHANGED THE FUEL PUMP,THE FUEL FILTER,THE O2 SENSOR,THE SPARK PLUGS,THE ECT SENSOR, THE IAT SENSOR, NEW FUEL PUMP FUSE, BUT IT DOES NOT WANT TO CRANK
IS THERE POWER TO THE FULE PUMP DID YOU CHECK THE FULE PUMP RELAY YOU CAN CLICK OFF AND ON WHEN TURN THE KEY OFF AN ON ITS UNDER THE HOOD DO YOU HEAR IT CYCLE WHEN TURN THE KEY TO ON POSITION HAVE SOME ONE TAKE THE GAS CAP OFF AND LISTEN FOR THE FULE PUMP TO RUN FOR FIVE SECONDS IF THEY HEAR IT THEN PUMP IS RUNNING AND OK WHEN YOU TURN THE KEY BACK OFF WAIT 10 SECONDS FOR IT TO RESET AND IT WILL CYCLE AGAIN WHEN YOU TURN THE KEY ON .. IF THAT IS OK CHECK FOR SPARK AT A PLUG IF YOU HAVE SPARK AT THE PLUG THEN ONE SHOT EITHER IN THROTLE BODY AND TRY TO START IF IT FIRES THEN WE CAN TAKE FROM THERE LET ME KNOW HOW YOU DO HERE POHLCAT
Mar 04, 2011 | 1995 Isuzu Rodeo
I have a 1998 ford wind star new fule pump but still not geting fule , wont crank engine turns ove but won;t start
INSTALL PRESSURE GUAGE THEN CK, VOLTAGE TO PUMP PCM TURNS ON PUMP RELAY FOR 2 SECONDS WHEN KEY CYCLED ON ,, IF NO POWER CK INERTIA SWITCH ( MAY BE TRIPPED ) IF NO POWER TO INERTIA SWITCH CK FUEL PUMP RELAY IF NO VOLTAGE AT PUMP RELAY THEN CHECK FOR SPARK AT PLUGS IF NO SPARK CK PCM POWER RELAY IT SUPPLIES VOLTAGE TO PCM THAT INTURN POWERS FUEL PUMP RELAY
HOPE THIS HELPS
Aug 08, 2010 | 1998 Ford Windstar
Have an 85 chevy 4x4. I just had the 305 engine rebuilt with a new intake and carb. It was working fine for a couple days and one morning I went to start er up and the engine just cranked and cranked,...
When you turn the key front. Listen for the fuel pump to prime. It should sound like a low humming noise that lasts about 3 seconds. If it does then check for spark by pulling one of our sparkplug wires and putting an extra spark plug in it. Place the end of the wire down somewhere safe and crank the motor. If you can't seek spark in the plug, it is most likely your coil failing. So, check fuel pump and fuel pump relays first, then spark. Good Luck.
Mar 08, 2010 | 1983 GMC K2500
Loss Of Power & Unable to Crank Beyond 2-3 Seconds...
You have an issue with your throttle actuator, try cleaning in the area with carb cleaner but more than likely the actuator will have to be replaced
Oct 27, 2009 | 2004 Ford Explorer
I have a peugeot 206 1.4 hdi 2004 getig no fule to injectors is ther a fule pump in boot .do they have a fule cut off button
You can check the pump anyway, turn the key in ignition so dash lights come on, you should hear the pump come on for a few seconds. This sounds silly but have you also checked the fuse, also have you had the fuel filter changed? I am guessing there is fuel in the tank??...lol.
Oct 17, 2009 | Peugeot 405 Cars & Trucks
Vehicle Parts & Accessories Logo
71 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
