Question about Meade Optics
Meade autostar not been used for a while and now will not start
It lights up - i can move the telescope with the arrow keys but the hand held set show no information
    Novelist:
  • 167 Answers
Letting any electronic device set is the hardest thing you can do to it. However, most electronic devices will regain their functions if you leave them powered up long enough. It make take a while but it will probaby eventually start working again. Be sure and check any battery terminals for acid build up and clean them good. Hopefully it will come alive again
Col. Dana Gillespie
Posted on Nov 07, 2014
Testimonial: "Thanks for your kind comment. I am doing what you suggested. Hope it will wake up again !"
SOURCE: MEADE LX90 TELESCOPE
Had the same problem. Took it to a dealer and we put a new controller on but the funny thing was that my old controller worked fine on another scope but it would not work on mine. Agreed with "Guest" above - Mead's after sales service is bad.
Posted on Apr 08, 2008
  • 1027 Answers
SOURCE: meade LX200GPS telescope
The front panel for the telescope has an internal fuse. Remove the screws and look at the circuit board for a fuse. Replace with the same type and rating. The telescope has a diode with the fuse that gives some protection against reverse polarity, and the telescope should function on this fix.
Posted on May 22, 2008
jrcolbert
  • 73 Answers
SOURCE: vista will not work with autostar 494
I did some research on meade 506 astrofinder software
Read this...
Customer Review:
Rating: stars-1.0.gif
Summary: outdated software
The software this kit comes with is old and outdated. It is not supported by Windows XP nor Windows Vista. The latest supported version of Windows is Windows 98.
It also appears that the included software is a limited trial software. It is limited to the included 3 catalogs (star maps). The complete set of catalogs must be purchased additionally at quite some expense.
The cable connection kit couldn't be reviewed because it was missing from the package I received, but keep in mind when you order this kit, that neither Windows XP nor Windows Vista support serial ports anymore. The additional USB to serial adapter would be required.
That last line would suggest to me that if one had a USB to Serial adapter it might work? but I really do not know for sure. checking into some more stuff...
Found another article that states "It requires a PC running Windows 98SE through Windows XP. It will not run under Windows 95 or earlier, nor will it run under Windows Vista."
OK I found this site, you might be able to make some sense of it. But I did read in there that they do make USB serial adapters that will work with Vista OS.
Good Luck and happy star gazing! If you find something new out there maybe you could name it after me if you get it working. lol
Posted on Mar 07, 2009
  • 16 Answers
SOURCE: Computer control and pointing with NorthStar Goto & Autostar
Your reseller is correct. The wire (Meade cable #505) goes from an RS232 serial port on PC to a 4pin RJ plug. This plugs into the 2nd socket on the bottom of an Autostar 497 handset, the other socket being used for the curly lead to the telescope. So it goes PC to Autostar to telescope.
A common error is to try plugging the serial wire into an "AUX" ort on the telescope control panel - same connector. Not only does this not work, it can cause a lot of damage.
Wired like this you can control the scope from Meade's Autostar Suite (or many other planetarium softwares). You can also update the Autostar software to the latest 2009 version.
What else can go wrong? Well, many people want to control from a laptop, and modern ones don't have RS232 serial ports. Then you need a USB-to-serial convertor dongle, which effectively add a serial port to a laptop. But they often give it a very high port number (eg COM17) that the planetarium software does not find. Use Control Panel to reset the USB-serial-port to COM 1, 2, 3 or 4 and all should be well. But it can be a right fiddle!
Posted on Aug 15, 2009
  • 4090 Answers
SOURCE: Meade Autostar handbox
removeformat.gifBecause this is a new purchase i would suggest getting the handbox replaced under warranty. If the guy was rude, then mention this to their management. There have been quite a few prolems with meade gear on our site here. Handbox included.
If you are up to it you can open it up. if so inspect the board for damage, shorts or loose solder joints. Some of these things can be repaired, some cannot. On this last statement it would seem sensible to get the replacement then start again from scratch. I have found about 7 recent problems with this unit, so be aware this is not a fault free unit.
nettiser
Posted on Feb 27, 2010
My question is, I have a Meade Autostar #494 How do I see through the lenses?
The 494 is the HAND CONTROLLER NUMBER--- not the telescope. What Meade telescope do you own??
Aug 20, 2011 | Meade 494 AutoStar Telescope Control Unit...
I bought a used etx90 with autostar. The scope works with the basic controler. When I plug in the autostar it beeps & lights up the number panels, but I can't see anything in the led screen. is...
The contrast and brightness can be reset --- here is the manual -- how to do this is listed in the manual. If this does not repair the controller then you will need to buy a new hand controller-- the 497 hand controller is available used on Ebay from time to time.
http://www.meade.com/manuals/TelescopeManuals/ETXtelescopes/ETX-90%20w-autostar%20man.pdf
Manual down load above--
May 06, 2011 | Meade ETX-90EC (325 x 90mm) Telescope
I have an older Meade LX200 GPS with autostar II handset. The telescope was working fine and last night I got an error message on the handset "Error: Inv. Heap" and the telescope locks up with no further...
You may have Corrupted firmware in the hand controller- that's why they want you to do a RESET.
You might have to reload the correct firmware to fix this problem.
I believe if you hold down the ENTER KEY and the SCROLL DOWN arrow key and then turn on the scope you enter SAFE LOAD where you can reload the firmware.
Sep 02, 2010 | Meade Optics
My telescope/autostar not working ,will only display startup info on handbox ,then nothing happens !.
This is sometimes caused by a bad hand controller cable and or corrupted firmware in the hand controller.
Get a new cable first and try it-- if this does does work then RESET the hand controller and reload the firmware using the proper computer cable and Autostar Updater Version 5.9 available here:
http://www.meade.com/support/auto.html
http://www.meade.com/support/Win7_ASU592_Installation.pdf
Aug 31, 2010 | Meade LX200GPS Telescope
Nothing seems to work on my LX90
You may need to purchase a new hand unit.
go to meade.com for purchase.
May 15, 2010 | Meade 8" LX90 LNT Schmidt Cassegrain...
Blank screen no screen output at all after a software upgrade
Did you update the 494 controller improperly with 497 controller firmware. You must use this updater software :
http://www.meade.com/support/auto/Au2ver59.exe
Hold down the ENTER key and the scroll down arrow key at the same time abd power on the scope. This will place the hand controller into the SAFE load function and you will be able to do another update.
If you plugged or unplugged the controller cable with the scope turned on you may have burned out the controller. Contact Meade:
http://www.meade.com/support/index.html
Apr 26, 2010 | Meade 494 AutoStar Telescope Control Unit...
Meade autostar hand unit fails after 2 seconds changed hand units
You damaged the circuits inside the hand controller-- unless you are an electronics whiz these cannot be repaired.
However you can find them for sale directly from Meade and on Ebay (used) usually for about $80.
Mar 04, 2009 | Meade 494 AutoStar Telescope Control Unit...
Meade LX200GPS 8" won't initialize on power up.
Try doing either a garbage collect or a safe load-- and then reinstall the hand controller firmware--
Instructions-- depending on the type of controller
Autostar 495 or 497: You enter Safe Mode by holding the [enter] and
[scroll down] keys pressed when you power up the telescope. The
Autostar will say "Flash Load Ready"... now go start the ASU.
Autostar II: if you need to use Safe Mode to recover from a disaster,
turn on the telescope, and key 999 before it says "Initializing"
The Autostar will say "Flash Load Ready"... now go start the ASU.
LX200gps: BEFORE proceeding further, click on the OPTIONS item on the Top Bar.
Now click on "Garbage Collect Hbx" ... this will perform data cleanup
within the Autostar which will avoid potential mess-ups.
Feb 27, 2009 | Meade LX200GPS Telescope
Autostar 497 freezes
When warm and indoors (!) connect Autostar to scope and by serial lead to a PC, allow Meade Autostar suite to update the Autostar Firmware to the latest version (2009!!)
Frome www.meade.com/support/auto.html :
How To Upgrade Your Handbox
To upgrade your Autostar first click on the link below to download the Autostar Update (ASU) Client Application for Windows. If your web browser allows you to open the installation file, you may choose that option when prompted. Otherwise, just save the install file to your local hard disk drive. When downloading is complete, double click on the saved file to start the installation. Follow the instructions provided to install Autostar Update (ASU) on your machine. When installation is complete, start ASU by selecting "Start Menu" -> "Programs" -> "Meade Inst" -> "ASU". If you have an active Internet connection and your telescope with Autostar is connected using the appropriate cable as listed above, ASU will detect and install the correct Autostar code directly from Meade's web site via the "Upgrade Autostar Software Now" button.
Autostar Update
Autostar Update is an application that functions to transfer the event files and software updates from your computer, through the serial port, USB or Connector Cable Set depending on your telescope model. The Autostar Update application is available as a stand-alone client application for Windows. The most recent versions of AutoStar Update automatically check for the newest versions of the AutoStar Updater and download it if necessary. It is critical that you use the most recent AutoStar Updater to ensure that you get the proper software updates for your system.
06/02/09 Autostar Update (ASU) Client Application for Windows, Version 5.6 (1,654 KB). This is the latest Autostar Update. Rev. 5.6 is compatible with the ETX-LS and #497EP Hand Controllers. This version is compatible with all versions of AutoStar II and #497 AutoStar computer controllers. This installation will automatically update the Update Client Application in AutoStar Suite™ Software. If you have previously installed the Autostar Update (ASU) Client Application for Windows, Uninstall the old version before installing this new version. 07/27/09 #497 AutoStar hand controller software update. Version 5BE2 (1,039 KB).
General update. Fixes many known bugs. Real time clock corrections. LXD75 polar alignment. Various LX90 pointing and tracking fixes. Adds new magnetic/true north alignment.
REQUIRES VERSION 5.6 AUTOSTAR UPDATER.
Jan 17, 2008 | Meade Autostar Suite Autostar Suite...
Optics Logo
102 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
