Question about Wells Kitchen Appliances - Others
How to wire my wells fryer ...?
I have a wells drop in fryer ..power terminal has L1 L2 ...line coming in is 8wg 40a breaker black white n ground ...which goes where ? Thought I knew jus Looking for sure ..
  • Wells Expert
  • 684 Answers
Wells Fryer manuals can be downloaded free at www.wells-bloomfield.com
Posted on May 20, 2015
3 Suggested Answers
  • 125 Answers
SOURCE: HELP PLEase
Hello. Here is the link to your units manual, page 3, 7, and 13 tell most of the specs, page 13 has a part number, and specifications for the proper cord.
http://www.wells-mfg.com/~WELLS/WELLS%20LIBRARY/Wells%20OpM/301(b)%20307588%20OpM%20CT%20Std%20Fryer.pdf
Lowes probably does not have that high an amperage plug first of all, find an electrical supply house, or have an electrician get it and install it for you. You may actually have a 3 phase unit, but it does not specify that unit as being set for 3 phase, older units from a certain restaurant were though. If you want to find the terminal block, remove the pot, and then remove the inside rear cover, once removed you should find the terminal block inside, your wiring for the cord should go here ( a wiring diagram ).
http://www.wells-mfg.com/~WELLS/WELLS%20LIBRARY/Wells%20Wir%20Diag/307309.pdf
Hope this helped, and thank you.
If you need more help, ask me.
Posted on Apr 13, 2009
  • 23 Answers
SOURCE: Electrical terminal and wiring
2 wires go to overtemp and 2 to thermostat
Posted on Feb 27, 2011
Testimonial: "Thanks so much your a "Champ""
How to wire this PS4060 correctly ?
You should have 4 terminals and 2 green grounding screws. 2 terminals are marked Line or L1 and L2 etc, the black from the power supply goes to L1 and the white to L2. Other 2 terminals are marked Motor or M1 and M2 etc. Balck from motor goes on M1 and White on M2, The ground wires from both cables go one to each green screw.
Jul 20, 2014 | Water Source 40/60 Pressure Switch PS4060
How to connect the power to the dryer
most likely 240volts as most 120 volt dryers are already wired,depending on if its a 3 or 4 wire system depending on local electrical codes,but if its a 3 wire cord,take the RED to terminal L1 and Black to L2 terminal on the dryer terminal board HINT:(the RED and Black can go on either L1 or L2 they are interchangable) ,then the White wire to the N neutral terminal on the dryer terminal board usuall between the L1 and L2 terminal,if theres a Green Wire on the cord this is safety ground and can be attached to any metallic part on the dryer,if its a gray flat cord the 2 outside wires are L1 and L2 the center is Neutral,
so its:
RED=L1 or L2
BLACK=L1 or L2
WHITE=N or Neutral
GREEN=Safety Ground the metal dryer frame
Dec 09, 2012 | Dryers
I need to hookup up a Grasslin GM40 timer controlling one load and a 120vac application. Just wondering if someone could verify the hookup terminals as I cannot read the schematic as it is mostly gone. ...
Open following links to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#GM
GM40 can be used for 120V or 240V 277V applications for single-phase and some 3-phase applications.
For 120Volt, set all 4 dip switches to ON position BEFORE applying power.
ON position is pushed to left.
120Volt cable from breaker box has black hot and white neutral wire.
Black hot typically connects to terminal L1
White neutral connects to terminal L2/N
This action will power the time clock and relays.
Other terminals on GM40 are the relay terminals, and these terminals are dry.
Dry means they receive no power when wires are connected to L1 and L2/N.
There are two independent relays and each relay has 3 terminals: NC NO and COM.
If you are controlling one 120volt Load, then use one relay.
Run a jumper wire from terminal L1 to COM terminal.
So COM terminal is connected to Hot.
Cable going to 120V Load has black and white wire.
Connect black Load wire to terminal NO (normally open).
Connect white Load wire to L2/N.
Jul 19, 2011 | Intermatic GM40 - 24 Hour/7-Day Dial...
How to install a power cord to a Hayward 1hp Power Flo Matrix pump.
One line lead wire to the L1 terminal, the other line lead wire to the L2 terminal and the green ground wire to the green grounded screw above the motor terminal board. It does not matter which wire, white or black, is on which terminal, L1 or L2, so long as one wire is on each terminal.
John
May 24, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
My pool originally had a 2 speed AO Smith pump motor. Several years back it was replaced with an AO Smith single speed motor. I am replacing that motor with a new AO Smith single speed Centurion Switchless...
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
May 23, 2011 | AO Smith 2 hp 3450rpm 56C Frame 230 Volts...
Trying to convert from 3 prong to 4 I have green wire grounded, then red, then white,then black. I still have no power what am I doing wrong? It is not a whirlpool, it is a Kenmore. please assist me...
RED and BLACK are the two 120 volt power lines(that make up the 240 volts needed by the dryer) that go to connections L1 & L2 in the dryer &( it doesn't matter which wire goes to which terminal),then the WHITE wire goes to the Neutral terminal,this is usually the terminal in between the L1 & L2 terminals,and GREEN is the case ground wire on the unit
Jan 09, 2011 | Whirlpool LER5636P Electric Dryer
Wiring new motor
The L1 and L2 are the load terminals. Connect the black wires to the L1 and L2 and the green one to the green colored screw.
May 14, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
Install power cord - color sequence . Converting a 3 prong to a four prong power outlet.
a 3 prong has a black/red wire for L1 and L2 hots... then white for neutral- in the four wire setup it will be as follows black L1/red L2 both hot wires, white neutral or "N" terminal and /Green for safety ground to unit case
Sep 15, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Need help wiring new pressure switch for craftsman air compressor
Assuming that you are wiring for 115v. Lets start with the ground. The cord that attaches to the wall outlet will have three wires, green, black , and white. Insert the cord thru one of the openings of the pressure switch and attach the green wire to the ground screw. Next look very closely at the contacts and notice that they are arrainged in pairs. There is a small brass bar with two contacts that completes the circuit for each line. Start with L1 and attach white wire from cord, then attach white wire from motor to the screw terminal that small brass bar bridges to (should be T1). Next attach black wire from cord to L2 and black wire from motor to remining screw. Remember that the small brass bar with two contacts is the bridge and simply connects white to white and black to black. Enjoy
Dec 16, 2008 | Air Tools & Compressors
Kitchen Appliances - Others Logo
147 people viewed this question
Top Wells Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Raymond Koonce
Level 1 Expert
Dennis Boxerman
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
