Question about Tally Matrix T2280 Printer
Kindly provide solution for Tally T2280+ printer display hardware alarm 00032+385
2 Suggested Answers
gooditguy
  • 6 Answers
SOURCE: hardware alarm
One likely cause is a blocked optical sensor . Try these three things, in order, and check the printer after each:
- Pick up the printer, turn it upside down, and shake it. If 40 pounds is too much for you to lift, get a friend to help. Or, better yet, get a friend to do it without your help.
- Using an air compressor with a blow gun attachment, direct air to the paper path entry and exit, and to the sides of the platen. Then look for torn-off tractor feed bits of paper in the crevices. You may need tweezers or needle-nose pliers.
- Take the cover off and repeat the previous step with the air compressor. This is tricky. Use this as a last resort, as the printer may not be usable after a troublesome disassembly. Do this only if you're going to have to replace it otherwise.
Posted on Nov 16, 2009
Hardware alarm -4045 +131
That error means the that Printhead is not where the printer expected it to be. Clean the emitter grid (under the Printhead) with a soft cloth and clean the sensor with canned air. If that does not clear it up it is normally the Main Board Assembly.
There is a T2280 and a T2280+ they take different Main Boards so make sure you get the right one.
T2280 MRP provides IT Parts Product Supplies and Services
T2280+ MRP provides IT Parts Product Supplies and Services
Aug 13, 2015 | Genicom Tally 2280-2t Dot Matrix Printer...
Hardware Alarm Wrong Board tally 2280
Hi Denis,you are having wrong board tally because you fixed the wrong part.pls check the part number and get a new one and fix it back.
Apr 11, 2014 | Tally Matrix T2280 Printer
1. hardware alarm in tally2280 printer 2.AGA error
  1. Switch off the printer and Clean the encoder strip ( a transparent film strip Located bellow the cartridge )
  2. switch on the printer.
  3. if the problem is still there contact tally Service team.
Jun 02, 2011 | Tally Matrix T2280 Printer
Driver Tally T2280
You can download the drivers for the T2280 Dascom web site, please visit the following page;
http://www.dascom.co.uk/printer-drivers/serial-matrix/223-t2280.html
Dec 15, 2009 | Tally Matrix T2280 Printer
Hardware alarm
Sep 08, 2009 | Tally Matrix T2280 Printer
Describe your Tally Matrix T2280 Prion power up
Calibrating the temperature resolves the THS error in most cases.
The ‘Temp Cal’ functions can be carried out in the following way;
· Start with the printer powered OFF and at normal room temperature
· Hold down the ONLINE and SETUP button and power the printer back on
· Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
· Press the button under ‘TEMP CAL’ (button 3)
· Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
· Then press SET to save the settings.
If the printer continues to display the THS error, the problem can be caused by;
Incorrectly seated print head
Damaged or incorrectly seated head cable
Fault with Main Board, Interconnect Board or the print head.
Jul 09, 2009 | Tally Matrix T2280 Printer
Tally Printer setup
tally packager how to change print area in page set up
Jun 01, 2009 | Tally Matrix T2280 Printer
Tally sprint pro
Please tell me the hardware alarm number . The number will display onthe control pannel LCD of your printer. Then only I can help you.
Aug 26, 2008 | Tally Matrix T2280 Printer
Talley t2280 sprintpro giving error " Hardware Alarm +0253 094--- 114032+0377+0268
Hai
This is parhtiban
Contact NO : 09663390004
I faced same problem & I solved the issue
Solution : Replace the AGA sensor and AGA flag
Jan 17, 2008 | Tally Matrix T2280 Printer
Tally Matrix T2280 Printer Logo
93 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
