Question about Delta 3 Function Showerhead & Grail On-Wall Tub Mixer *Trim Kit...
I need the screw top that goes around the flusher, where can I get one????
Plumbing Supply House-- the contractors go to
Ask there
Have the make,model,etc
Posted on Nov 07, 2014
My toilet is not filling up properly. what might the problem be?
may not be sealing around the rubber ring on the inside of tank or the chain could be broken. may just need a new flusher.
Jul 08, 2015 | Home
Can't get the top off of a Thetford toilet
If it's a top flusher screw the flusher anti clockwise as its attached to the internal parts once in screwed the top will just lift off
Sep 22, 2014 | Sport & Outdoor - Others
How do I open my Maytag Dryer model # SDE305DAYW heavy duty legacy series with lint trap on bottom?
Always unplug the dryer before working on it and watch for sharp corners.
There should be two spring clips between the top and front panels.
Insert a flat object like a putty knife about 6 inches from each side. Push in and top should raise. Once both are done top will hinge back.
The front panel should have two screws, either at the bottom front or inside top. Remove. The inner bulkhead will have four screws. Remove top two and feed belt through the face, then replace the top screws. then remove the lower screws, feeding the belt the rest of the way through. Doing it this way keeps the drum from falling. Complete belt installation. The belt goes completely around the drum , turning the around the motor with the idler arm to keep tension on it.
Sep 17, 2014 | Maytag Dryers
Belt change on a Maytag DE410
Most of the time these models have screws in the back of the machine on the top lid. You'll need to get over behind the dryer to access this panel. You'll need a "star" type screwdriver (most come in a set). Remove the top lid to expose the drum. The belt will run around the drum and down around the safety cut out switch. This switch is most likely a teflon or plastic wheel that the belt loops around. After installing the belt, replace all of the screws and you're good to go!
Dec 11, 2009 | Dryers
Why does the water go over the top of the float
bend float down to adjust water level if water is covering float and still not stopping some flushers have an adjustment screw on top also turn slowly a 1/4 turn at a time if still doesnt stop lift float until stop bend rod to adjust if water doesnt stop from lift than diaphragm in flusher bad and have to change out again
Oct 06, 2009 | Home
I NEED EASY ACCESS OR ENTRY TO REPLACING DRUM BELT DRYER
depending on your model . the frt panel must be removed to access the belt. belt goes around top of drum down th
o the btm over the motor pulley then thru your idler pulley. if this does not help or need more info, send us model # that will help .
Sep 23, 2009 | Maytag Dryers
I need to raplace belt
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 19, 2009 | Dryers
Delta 3 Function Showerhead & Grail On-Wall Tub Mixer *Trim Kit... Logo
512 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
