Question about Sony Handycam DCR-TRV740 Digital Camcorder
My Sony DCR-TRV740 camera I just purchased (used), has a playback problem with my 8mm's. When I got the unit I cleaned it well with chamois swaps and MG video cleaner(Recommended by all experts it see
My Sony DCR-TRV740 camera I just purchased (used), has a playback problem with my 8mm's. When I got the unit I cleaned it well with chamois swaps and MG video cleaner(Recommended by all experts it seems for head cleaning), I cleaned the heads and put my tape in, the tape played fine for a few minutes. I then rewound the entire tape and when I played it back, the LCD was blue and I didn't see anything. When I fastforward or rewind, I can see the picture, when i let go of the rewind/fastfoward function, the playback slowly speeds down and as its coming back to regular play speed, the picture is perfect for a second and then the picture goes away back to the blue screen. I am not sure how a head misalignment could be happening now, when the tape played fine prior to rewind?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 31 Answers
You have a clogged video head. It happens. Do not use the chamois again. Instead, purchase an 8mm head cleaner and give that a try. Only use a brand name cleaner - no generics, and make sure it doesn't come from China!
Posted on Nov 25, 2014
4 Suggested Answers
Rexdreamer
  • 76 Answers
SOURCE: my sony ccd-trv218e hi-8 video camera shows blue
Definitely sounds like a dirty video head or a bad video head. You are headed in the right direction with the cleaning tape but you may not be able to get it thoroughly with the cleaning tape. You can try a q-tip dipped in alcohol and try to cleaned the video heads on the drum assembly yourself, just kinda soak the heads with the alcohol and gentle scrub the heads if the heads are clogged this may help. If it doesnt then you may need a drum assy. I have researched it for you and the part number is "A7048988A" from partstore.com. I hope this helps.
Posted on Sep 06, 2010
Davidivory1
  • 338 Answers
SOURCE: Sony DCR- HC18E Camcorder
Hello there, you are not alone in this problem, I get 100's of other people write on this matter, the tape head cleaners sold are mostly a bit of non abrasive tape type stuff that would not clean a bit of dust off a shiny table, let alone a dirty camera head.
You need to get a proper head cleaning kit with the tape that looks like a white flat shoe lace, run that for 30 sec in camera in seconds your heads will be like new.
from
David
Posted on Jun 19, 2010
Testimonial: "I didn't realise that there were options when purchasing head cleaning tapes so this was extremely useful. Thank you"
  • 29 Answers
SOURCE: sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
Posted on Jan 12, 2010
Having three grey bars when playback
hello, wow .....is it horizontally bar? if yes that mean :
1. the head drum have two channel reading that is Ch A and Ch B
one of them there a dead channel, try to change head drum that
will solve your problem.
2. your head drum may dirt, cleaning using paper and alcohol and let it dry naturally. do not insert cassette before you using cleaning cassette. and i hope it will work.
thanks
otto
Oct 09, 2013 | Sony Handycam DCR-TRV740 Digital Camcorder
Video camera will not playback tape smoothly - jumps along
Please get into town, and buy the 8mm Camera cleaning tape from W.H. Smiths, Currys, Comet, Maplins, put that in your camera on record mode for 20 seconds and then remove it, and carry on filming, it is just dirty heads you have got, take care.
from
David
May 25, 2010 | Sony Handycam DCR-TRV520 Digital Camcorder
I can't play a hi8 cassette recorded in another camera y my camera, what can i do?
DCR-TRV130 is not capable of playing back 8mm or Hi8 tapes recorded on analog camcorders. Digital recording playback only.
Feb 16, 2010 | Sony Handycam DCR-TRV130 Digital Camcorder
My sony dcr-trv250 ntsc does not play videos that were recorded on my old samsung scx904 or alittle older sony that my father in law had let us borrow before we got ours...why? and is there some way to...
Your DCR-TRV250 uses a Digital 8 system to record and playback information on its cassette whereas the older Analog 8mm machines used the analog system. Unfortunately the two are incompatible.
Jan 02, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
How do I transfer 8mm & Hi8 tapes to DVD using my computer?
just go to this link:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV740&SelectOS=7
download the usb driver for your camcorder. install. Set power switch to Camera or VCR. Select USB Stream to ON in the menu settings. then connect camcorder to pc.
Mar 31, 2009 | Sony Handycam DCR-TRV740 Digital Camcorder
Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Aug 01, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Camcorder won't playback most Hi8 tapes
may be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
Aug 11, 2007 | Sony DCR-TRV285E Digital-8 Digital...
DCR-TRV740 handycam
heads are dirty , tension may be a little low. worth having Video Tech service in sacramento look at it.
May 28, 2007 | Sony Handycam DCR-TRV740 Digital Camcorder
No picture during playback on LCD or TV from my Sony DCR-TRV255E
Just use good quality Video Head Cleaning Cassette. Video head is dirty/ clogged.
Feb 17, 2007 | Sony Handycam DCR-TRV255 Digital Camcorder
Sony Handycam DCR-TRV740 Digital Camcorder Logo
104 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
