My Goodman furnace red light keeps on flashing continously.
    Problem Solver:
  • 7 Answers
Immediately call a professional. That is a VERY serious problem.
Posted on Nov 07, 2014
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman furnace I think
Ok, a flashing 3 on a Goodman control board usually means that the pressure switch is tripping. A few things will cause this. One being a restriction in the exhaust or combustion air inlet. The second could indicate a faulty inducer blower motor and the third would be a blocked or bad pressure switch.
With the front cover off and door switch taped down, Have a helper turn the thermostat up to 75. You will be watching the circuit board for flashing lights and in a few seconds the inducer motor (the small fan hooked to the exhaust) will start. If this does not happen, we either have a bad circuit board or blower motor. If the fan starts rotating, inspect the hoses going to the small circular pressure switch. Sometimes they may get either water or debris in the hose and not allow the switch to sense pressure. If the hoses look OK, the igniter will glow an orange color and you will see this if you look thru the small viewing port. IF no glow, you could have a bad pressure switch, a bad ignition relay (found on the circuit board) or a bad igniter. OK so if the igniter glows, a few seconds later the gas valve should click open and send gas to the burners. The orange will turn to blue. If this does not happen, you have either a bad gas valve or bad circuit board. Finally if you get flame but it will not stay lit more than a few seconds, you may have a restriction in the burner gas train, a bad gas valve, a dirty or bad flame sensor or not enough gas pressure.
Knowing the sequence of operation will give you the needed information to talk with a service technician and cut down on diagnostic costs.
Try looking on the back of the furnace access panel for both model number and a diagnostic schematic. This will confirm what the flashing 3 code means for your unit.
Sorry, without knowing the model number, this is the best I can do for you. Good Luck!
Posted on Oct 29, 2007
  • 5 Answers
SOURCE: led keep on flashing
What is the model #. Sounds like your polarity is reversed. Do you know how to check for this.
Posted on Nov 19, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: furnace won't stay running
1 FLASH
Furnace fails to operate.
• Integrated control module
diagnostic LED is
flashing ONE (1) flash.
• Furnace lockout due
to an excessive
number of ignition
“retries” (3 total)1.
• Failure to establish flame.
Cause may be no gas to
burners, front cover
pressure switch stuck open,
bad igniter or igniter
alignment, improper orifices,
or coated/oxidized or
improperly connected flame
sensor.
• Loss of flame after establishment.
Cause may be
interrupted gas supply, lazy
burner flames (improper gas
pressure or restriction in flue
and/or combustion air
piping), front cover pressure
switch opening, or improper
induced draft blower
performance.
• Locate and correct gas
interruption.
• Check front cover
pressure switch
operation (hose, wiring,
contact operation).
Correct if necessary.
• Replace or realign
igniter.
• Check flame sense
signal. Sand sensor if
coated and/or oxidized.
• Check flue piping for
blockage, proper
length, elbows, and
termination.
• Verify proper induced
draft blower performance.
Posted on Nov 25, 2008
  • 333 Answers
SOURCE: goodman furnace leaking water
Yes you can use regular pvc glue. You should use pvc primer before you glue it.
Posted on Jan 21, 2009
  • 29 Answers
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Posted on Jun 21, 2009
Goodman heater red light blinks 5 times is a blower heater, it says is the sennsor flame, i keep changing it but it keeps burning it over and over doesnt work
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering
Nov 05, 2011 | Goodman GMS90703BXA Heater
My furnace blows cold air constantly even in heat mode. It's led light flashes 4 times in a set, what could it be?
On Goodman furnaces, 4 flashes usually means open high limit. Look for any burnt or loose wires or any resettable limits, they should have a red button that clicks when you push on it and wire going in and out of it with spade clips. If the open limit is not resettable, jump it out to verify its open and if that fixes the problem, replace the defective limit. Best of luck.
Mar 18, 2010 | Goodman GDS80703ANA Open Flame Mid-Size...
I HAVE A 45000 BTU GOODMAN FURNACE RED LIGHT
There may not be a call for heat being registered by the control board. Take the R and W terminals on the control board and put a jumper between the two. If the heater starts, you have either a broken thermostat wire or a bad thermostat or connection.
Jan 25, 2010 | Goodman Heating & Cooling
Goodman furnace new in 07 flashed three code..It
you will neede to defrosted the flue clear any bushes or trees from flue if there ther eshould be a window on the front where you can see the lights hope this helps
Jan 10, 2010 | Goodman GDS80703ANA Open Flame Mid-Size...
Goodman furnace
Jun 02, 2009 | Goodman GMS90703BXA Heater
Goodman GMPB-75-4 Rev 13
Is there a diagnostic chart either on the reverse side of the blower door or in your owners manual. It may help you to narrow down what is going wrong.
Operate the furnace with the access door off of the furnace and the blower door switch taped on. Watch the furnace and document what happens. Note if the flame starts but goes out in a few seconds and let me know what you experienced.
Nov 17, 2007 | Goodman GMS90703BXA Heater
No heat, trouble shooting light has continious flash.
Try replacing the filter. Low air flow will allow the furnace to overheat. Sounds like a simple answer. Wish I had tried it before buying a flame sensor and controller. Live and learn I guess.
Nov 16, 2006 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
