Question about Gear Hausbell TM Mini H7 2.4GHz Wireless Entertainment Keyboard with Touchpad for PC, Pad, Andriod TV Box, Google TV Box, Xbox360, PS3 & HTPC/IPTV
Trying to connect a hasbell H7 keyboard. Plugged in reciever, turned on keyboard. Red light flashes for 15 seconds then nothing. When I touch any button, red light flashes again. No connection
Trying to use with an android media box for xbmc
TV wont turn on
The main power supply is failing or it is shutting down because of a fault on the output side of it and it is trying to protect itself from overload which can cause a fire. Contact Zenith customer service and describe the problem, particularly the flashing LED which may be giving you an error code.
Sep 04, 2009 | Zenith E44W46LCD 44" Rear Projection...
Sony amplifier STR DA2000ES protector code 22
go to your manual and repeat connection and setup and try with new cables because may be the cat bite something hidden from your eyes.
Apr 10, 2009 | Audio Players & Recorders
Mouse is recognised but key board is not.
Normal 0 Press the Receiver button (and the lights will start flashing.
Turn the Keyboard over and press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver. Should work okay then.
Hope this helps. Bud
Feb 18, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
Have a denon avr 588 surround reciever that does not stay on the on/stand by button has a red light that is flashing it powers on for about 3 seconds then shuts off and then the red light starts flahing
this could be two wires touching on the back connections. one wire touching another ...just one will do this! look close and causing a short (its shutting off is a safety feature so the unit does not overheat)
Dec 08, 2008 | Televison & Video
I have purchased a Microsoft Wireless Optical Desktop 700 (Keyboard & mouse). I have plugged the wireless receiver in, and get a flashing green light when I press the button on the front. The green...
When you say you pressed the connect buttons on both the keyboard and mouse, do you mean you pressed the connect button on the receiver, and then you pressed the connect buttons on the mouse and keyboard? If not, then that's what you have to do. The 30 seconds of blinking on the receiver is normal, as it gives you time to find and press the buttons on the mouse and keyboard.
I hope this helps, and good luck!
Jul 16, 2008 | Computers & Internet
Keyboard suddenly died
try the connect button under keyboard and on reciever.press the two within seconds! good luck
Jun 13, 2008 | Logitech LX 710 Keyboard/Mouse
Flashing Red Light
the drive is just connecting to your pc. now if it always stayed red, you'd have a problem.
Jun 06, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Can not get mouse to move and buttons will not work on keyboard. batteries are all good
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Dec 12, 2007 | Microsoft Optical Desktop 1000 (BV3000003)
Gear Hausbell TM Mini H7 2.4GHz Wireless Entertainment Keyboard with Touchpad for PC, Pad, Andriod TV Box, Google TV Box, Xbox360, PS3 & HTPC/IPTV Logo
80 people viewed this question
Top Gear Computers & Internet Experts
David Payne
David Payne
Are you a Gear Computer and Internet Expert? Answer questions, earn points and help others
