Question about Cameras
What does the positions High,Medium. and Low on photo mode mean?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Without knowing the make and model of the camera this is only a guess, but I would say it's either the image quality or image compression for the JPEG files.
Just about every camera stores photos as JPEG files (many cameras also offer other options, but JPEG is almost universal). JPEG uses a lossy compression scheme. This means that files are compressed to save space on your memory card. This compression throws away some data. Usually this is not noticeable. For example, if one point of a blue sky comes out a different shade of blue (but still close to its neighbors). It would be noticeable if a patch of sky came out green, however.
High image quality applies minimal compression, at the expense of file size. Low image quality applies more compression, saving file space but sacrificing quality.
Compression is the other way around. High compression saves file space at the expense of quality. Low compression gives higher quality at the expense of file space.
Whether these settings on your camera determine the image quality or the image compression, I can't say. You'll have to look in the manual for your camera.
If you require further assistance, please add a comment to this question and specify the make and model of your camera.
Posted on Nov 07, 2014
What do the 3 mode speed colors mean
It just indicates which speed you have chosen from low medium to high
May 29, 2014 | Haier CPRB08XCJ 8000 BTU Portable Air...
Fan control switch only works on high
If you blower fan will only work on high know that most blower motors are power by a basic electrical circuit that utilizes a multi resistor or a solid-state resistor to control different fan speed modes (low, medium low, medium and high). If the resistor malfunctions it may lose one or more of the lower fan speed settings. First check the fuse and change if needed. If that doesn't fix things change the resister.------------------------------------------------------------------------------------
Launch CResetter Oil Lamp Reset Tool
Mar 07, 2013 | Cars & Trucks
Scanning quality options
Photos should be high resolution..max or high
Dec 31, 2012 | Lexmark X6100 Flatbed Scanner
Hello there,i have a samsung cell phone model SCH-R351.My phone is on silent mode.What can i do to get it off silent mode and turn the ringer on
In the Settings menu, select Sounds. The Sounds menu appears in the display.
Select the Master Volume sub-menu which allows you to set the default volume for incoming
calls, messages and alarms. You can set the volume to Silence All, Vibrate, Low, Low/Medium, Medium, Medium/High, or High. The Vib. on soft key allows you select vibrate in addition to the sound.
Hope this helps. If so, please rate this solution.
-best regards,
M
Mar 10, 2011 | Cell Phones
Hi, I have a samsung cell phone R450 that says silent mode activated and I don't know how to disactivated can you help me please?
Silence the tones your keypad makes when you press a key.
To enter Silent Mode:
In standby mode, press and hold . # button,“Entering Silent Mode” briefly appears in the display and your phone returns to standby mode
To exit Silent Mode:
While in Silent mode and standby mode, press and hold # button “Exit Silent Mode” briefly appears in the display and your phone returns to standby mode.
Adjust the Ringer:
1. In standby mode, press the volume key on the right side of the phone up or down. Options are:
Ringer Off
Vibrate
Low
Low/Medium
Medium
Medium/High
High
Vibrate/High
2. When you are satisfied with the setting, press OK.Your phone returns to standby mode.
Thank You
Aug 17, 2010 | Cell Phones
Heater fan only works on "high speed"
All cars are designed with a blower fan motor that pushes air through the ventilation system. This air is processed by a series of vents to direct the air to various positions. Example: heater, air conditioner and defrost modes. Most blower motors are power by a basic electrical circuit that utilizes a multi resistor or a solid-state resistor to control different fan speed modes (low, medium low, medium and high). If the resistor malfunctions it may lose one or more of the lower fan speed settings.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Mar 02, 2010 | 1999 Buick Century
Low does not work, medium and high do
You probably cant fix it, this sounds like a multispeed blower with hi/medium/lo settings. You
can either replace the motor or connect one of the
working speeds to low/med or low/hi. or bump med to low and high to medium.
Jan 12, 2010 | Desa International Blower Glow Warm Wall...
Why does blower fan speed switch lock-out off and low speed positions on 1998 chevy silverado? It stopped working altogether then I replaced a 10 amp fuse and now only medium high and high will work but,...
Sounds like you may have a bad blower motor resistor.  When they go bad, they usually wipe out all speeds except high.  But could knock out just one or two of the speeds.  It should be located near the blower motor.
Sep 10, 2009 | 1998 Chevrolet K1500
AC comes on in low to medium but shuts off on high.
It could possibly be the switch. Many automotive a/c blowers have a relay to engage the highest fan speed because the high current required will necessitate the use of heavy wiring to and from the blower motor and a heavy duty switch. Check for a high-speed relay and also there might be a circuit breaker in the blower system.
Hope this helps, rhais
Jun 28, 2009 | 2002 Dodge Durango
Unit not cooling on medium or high fan
pls if you change the fan speed from low to meduim or to high on cool position and the compressor stop non these two psitions means the selector swith must be changed.
Apr 28, 2009 | Whirlpool ACQ108XL Air Conditioner
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
