Question about Vizio m420nv 42 in. LCD HDTV
Wel the Vizio Tv lost Sound.
Have tried everything also the advice with the knop. still no sound
    Top Expert:
  • Vizio Master
  • 74,383 Answers
Check whether the audio is muted by accidently. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on Nov 07, 2014
I replaced the T-con board on my Vizio TV, but I still don't have any picture, just sound. What else could it be?
Think something may have gotten unhooked when you put everything bacK together? Check out all connections and ribbons between boards for proper contact.
Jun 22, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Vizio tv has sound no picture
Hi Brenton,
You have sound and no picture. It appears to be a case of backlight failure which is common in LED TVs. The problem is technical and involves opening the tv, diagnosing and replacing or repairing the defective board. Please consult some good local TV tech. Good Luck.
Apr 28, 2015 | Vizio Razor E461-A1 46" LED TV 1920x1080,...
Hi. I have a M420NV everything works but no sound
Please specify what source you are trying to connect to the TV, and what method of connection you are using (HDMI, Component Video, or Composite-RCA).
Nov 07, 2014 | Vizio 42 in. LCD TV
My vizio VW42L has a picture, but the sound went out....how can we get the sound back
Use your remote and find RESET from the settings. I have a tendency to reset the sound on my TV's with all of my remotes, sometimes a different remote for a different TV or stereo will do something funky and turn off my sound the only way to get it back is to reset the settings and reprogram the channels.
Nov 19, 2011 | Vizio L32 32 in. LCD HDTV
No sound coming from my Vizio Model #E320VL HDTV. Tried everything I can think of. I have Direct TV and it just stopped working one day. Any advice?
We just had the same problem with our tv, we switched tv's and it still didn't work. We reset our att uverse box, and the sound works. I don't know how direct TV works, but the problem may lie there instead of your TV
Sep 09, 2011 | Vizio VF550M 55 in. LCD HDTV
I cannot get any audio from my tv / cable at all. I hae unplugged everything and reconnected. I can see the volume control on the screen and can see it go up and down from the tv and from the cable...
Hello
Either your tVs speaker of its audio output IC has damaged. Check the TV by onnecting its audio out jack to any other audio source, like amplifier or so, and see whether there is sound output comes through the outer source or not. If there is sound from the amp; and no sound output from the TV, check the speaker first. If it is OK, replace the audiou output IC. If there is no sound through outer amplifier, the audio detectcion section inside your TV is faulty. You must have a thorough knoledge and skill to repair it. OK.
May 23, 2011 | Vizio VA22LFHDTV10T LCD TV
My vizio 42" all of a sudden lost sound on the
I can see good video, but I hear no audio with my XWH200 adapters?
Published 11/21/2011 06:46 AM
Updated 11/21/2011 02:26 PM
While most HDMI sources work with good audio and video, we have a compatibility issue with audio from a few specific products (eg, DirecTV HD DVR satellite set-top box, DISH Networks satellite set-top-box, and TiVo Premiere XL cable set-top-box). If you are experiencing problems with no audio or muted audio with one of your HDMI sources, then please try changing the audio settings on your problematic HDMI source to PCM or LPCM. Then turn off the TV, remote power from the WirelessHD adapters, and power off the HDMI source. Now power everything back on. If you are still experiencing no audio then please write down the model number of your HDMI source with no audio and contact VIZIO customer support.
Oct 27, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vizio tv w/direct tv lost sound is there a reset button
Vizio does not have a RESET button, the best approach is unplug the TV.
1. Make sure nothing is muted
2. Hook up a dvd to it and try playing it if you got sound reboot your direct tv box by unplugging it.
3. Go to step 1
4. if DVD does not have sound then the tv will need to be looked at for other causes.
Please be considerate when leaving postive feedback and ratings, for your FREE answer today, thank you
May 27, 2010 | Vizio L37 Television
Vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
May 18, 2009 | Vizio VO47L 47 in. LCD TV
Open Questions:
See all Vizio m420nv 42 in. LCD HDTV Questions
Vizio m420nv 42 in. LCD HDTV Logo
103 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
